08-31-2011, 21:33 | #1 (permalink) |
Junior Member Join Date: May 2007
Member: 512548 Status: Offline Thanks Meter: 0 | Nokia C5-00 Flasing Problem (ANSWERED) My nokia c5-00 Giving strange problem . If we press power button, it just Vibrates, No reaction. so i flashed with MobileEx, all ok but phone not responding . Here is my log file:: MXKEY Serial: [FT SCR2000 0] - C0811F83 Driver: NMWCD, ver: 7.1.32.65 Module ver: 1.0.0.17743(23-06-2011), Library ver: 1.0.0.11773(23-06-2011) Processing MCU file: rm645_032.010_prd.core.fpsx [BB5,XSR 1.6] size: 90.95 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1ED68E41 CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 093001128D9C0344221017EBE76BD83AE8226617 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1ED68E41 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35379204386632_CE RT.rpl). CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 170.06 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0AE3FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: D7D05CFC [RAP Certificate v1 249] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 14.453 s Processing PPM file: rm645_032.010_16.01_Vietnam_prd.rofs2.fpsx [BB5,XSR 1.6] size: 34.15 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Erase size: 51 MB CMT FLASH,MuxOneNAND area [06D40000-0A03FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 5.469 s Processing PPM file: rm645_032.010_C00.01_DEFAULT_prd.rofs3.fpsx [BB5,XSR 1.6] size: 7.94 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Erase size: 14 MB CMT FLASH,MuxOneNAND area [0A040000-0AE3FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.062 s Processing CNT file: rm645_032.010_U000.000_prd.uda.fpsx [BB5,XSR 1.6] size: 1.76 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Erase size: 72 MB CMT FLASH,MuxOneNAND area [0AE40000-0F63FFFF] Flash programming ... Programming completed in 0.719 s Processing CNT file: rm645_ENO_v_0.NCP17_APEONLY.fpsx [BB5,XSR 1.6] size: 2.35 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104 Erase size: 4 MB CMT FLASH,MuxOneNAND area [004E0000-008DFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 0.422 s Total time for flashing process(boot+erase+write) was 36.656 s Waiting for device boot up ... Phone not found, retrying ... Phone not responding ! i tried with latest version also.. it gives same problem :-( Kindly help me... |
08-31-2011, 22:59 | #2 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Tashkent, Uzbekistan Age: 35
Member: 1487727 Status: Offline Sonork: 100.1607104 Thanks Meter: 38 | i had same problem, first chek cable connection. before flash phone dead or live? if phone not dead before flash then flash lastest version (071.005) if simlock not corrupted. |
11-17-2011, 23:30 | #4 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | I have a dead c5 after flash...this patch dosen't help me eather...what's wrong?....how to repair this phone wich was ok before trying to change the language???? |
The Following User Says Thank You to dragosgsm For This Useful Post: |
