04-09-2013, 10:15 | #1 (permalink) |
No Life Poster Join Date: Jul 2007
Member: 551619 Status: Offline Thanks Meter: 136 | Nokia C5-00 Vibrate Only Code: Processing MCU file: rm645_071.005_prd.core.fpsx [BB5,XSR 1.6] size: 96.64 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 16800001B9A40344A674B49706D3B45ACE7E28E2 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ... Device connected: nmwcdnsucx64\Nokia USB Flashing Generic, PORT_ID: 1C6A413 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_355358XXXXXXXX_CERT.rpl" CMT PAPUBKEYS HASH: D7D05CFC982BF1491F4BE3FE0F28D3016DA5E057 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 170.06 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0AE3FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: D7D05CFC [RAP Certificate v1 249] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 19.196 s Processing PPM file: rm645_071.005_01.01_Euro1_prd.rofs2.fpsx [BB5,XSR 1.6] size: 40.99 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 51 MB CMT FLASH,MuxOneNAND area [06D40000-0A03FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 7.784 s Processing PPM file: rm645_071.005_277.02_CV_FR_prd.rofs3.fpsx [BB5,XSR 1.6] size: 1.31 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 14 MB CMT FLASH,MuxOneNAND area [0A040000-0AE3FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.316 s Processing CNT file: rm645_071.005_U000.000_prd.uda.fpsx [BB5,XSR 1.6] size: 1.32 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 72 MB CMT FLASH,MuxOneNAND area [0AE40000-0F63FFFF] Flash programming ... Programming completed in 0.683 s Processing CNT file: RM645_ENO_10wk48v0.001.fpsx [BB5,XSR 1.6] size: 2.25 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 4 MB CMT FLASH,MuxOneNAND area [004E0000-008DFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 0.490 s Total time for flashing process(boot+erase+write) was 44.462 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdnsucx64\Nokia USB Flashing Generic, PORT_ID: 1C6A413 Waiting for USB device removal ... Warning: Phone did not reboot to normal mode. |
04-09-2013, 11:24 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. What was Phone condition when came to you ? Do you have Backup for this Phone ? This Phone need to Erase ones to Solve it, So please provide above information for assistance. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
04-09-2013, 11:41 | #3 (permalink) |
Member: 551619 Status: Offline Thanks Meter: 136 | Set was in Dead Condition when came... I Made RPL Backup by USB Interface in Same [Dead] Condition so Not Sure Backup will Work or Not. Then I Flashed with v71.5 but Set didn't Power On. Vibrate Only. |
04-09-2013, 11:44 | #4 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Dadu Sindh Pakistan Age: 37
Member: 1322713 Status: Offline Sonork: 100.1663786 Thanks Meter: 254 | Dear Download same Product code Flash Files and flash it.......... |
The Following User Says Thank You to lucky2010 For This Useful Post: |
04-09-2013, 12:06 | #6 (permalink) | |
Freak Poster Join Date: Dec 2008 Location: lahore
Member: 923792 Status: Offline Thanks Meter: 20 | Quote:
The Following User Says Thank You to shahid mobile For This Useful Post: |
04-09-2013, 15:16 | #9 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Reflash the phone, use FBUS, Apply Quick FIx > Rap3NAND Erase. if still end up with the same error, means bad flash chip. reflow, on most case solved the problem. |
The Following User Says Thank You to gbluez For This Useful Post: |
04-10-2013, 07:56 | #12 (permalink) | |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Your Phone can be done easily, You have Backup, So Erase Phone with following steps from here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ Download Lower Version Firmware of same Product Code of your Phone, Version 61.5 or 62.1 Firmware, After Erase, Flash it with the above Firmware, Restore Backup at the last, Post reply. BR, ZUBER | |
