Old 03-17-2011, 15:04   #1 (permalink)
Member: 478387
Thanks Meter: 2
Nokia C5-03 contact the retailer. help pls (ANSWERED)
Hy. I have a Nokia c5-03 RM-697, he fell from my hand on the stairs, and now when i try to start on, i get this message Phone startup failed. Contact the retailer.
i have try to flash it via usb with mxkey, but i get an error BOOT STRAP FAILED
I try to flash with GPG Cable c5-03 but i get this:
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010)
Processing MCU file: RM-697_11.0.024_prd.core.C00
[BB5,XSR 1.6] size: 96.78 MB
Supported Ids: 600C192102031104
Boot error: 03 00 72 00
- Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar.
- Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables.
- On rare occasions phone might be damaged or dead. So, if possible, try with another phone.
Bootstrap failed!
Flashing terminated with error(s) in 51.328 s
or this:
Version from phone: 10.0.031
Version from file: 11.0.024
Reading phone`s ID ...
Restarting phone ...
Read Certificate failed.
NPC_DATA is empty.
SIMLOCK_DATA saved OK
SIMLOCK_KEY_DATA saved OK
WMDRM_PD_DATA saved OK
RF_DATA saved OK
WARRANTY_DATA saved OK
PROD_DATA saved OK
BT_DATA saved OK
LOCK_DATA saved OK
LOCK120_DATA saved OK
BB_DATA saved OK
WLAN_DATA saved OK
when i perform operation scan is ok, but BUS Check doesn't work
This is the Scan info:
Phone Type: RM-697 (Nokia C5-03)
SW Version: V ICPR82_10w39.1 08-10-10 RM-697 (c) Nokia
Imei plain: 35434904273397-5
Product Code: 059C513
ApeCoreSw: V 10.0.031
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354349042733975
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
i need help. please, if you have any solution!
thank you in advance!
Old 03-17-2011, 21:01   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,059
hi,
from the logs all ok.
press image DL to download latest current version:
Phone Type: RM-697
TimeStamp: 2010-12-23T09:41:55+00:00
SW Version: 11.0.024
use USB ROM to flash.
The Following 2 Users Say Thank You to gbluez For This Useful Post:
Old 03-20-2011, 19:48   #3 (permalink)
Member: 478387
Thanks Meter: 2
Originally Posted by gbluez View Post
hi,
hy. i have flash it with the latest version but still the same message at start up Phone startup failed. Contact the retailer.
do you have other solution, please?
kind regards!
The Following User Says Thank You to fabianx For This Useful Post:
Old 01-15-2012, 14:19   #4 (permalink)
{X-MAN}'s Avatar
Member: 1169043
Sonork: 100.1586033
Thanks Meter: 58
Phone type: RM-645 (Nokia C5-00)
SW version: V ICPR82_11w16.4 02-06-11 RM-645 (c) Nokia
Imei plain: 3537920?????????
Product code: 0593436
Battery voltage: 4749 mV, current: 105 mA
ApeCoreSw: 071.005
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST failed!
Old 01-15-2012, 14:39   #5 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 679
ApeCoreSw: 071.005
Language Pack:
- not available.
SIMLOCK invalid!
u r not repir phone without rpl if u have backup then write other wise buy -------
Old 01-15-2012, 15:08   #6 (permalink)
{X-MAN}'s Avatar
Member: 1169043
Sonork: 100.1586033
Thanks Meter: 58
how to buy rpl .
Old 01-15-2012, 16:52   #7 (permalink)
BIGUNLOCKSERVER's Avatar
Member: 1542932
Sonork: 100.1621006
Thanks Meter: 53
may be hardware problam...
chek for water damage...
Old 01-25-2012, 15:03   #8 (permalink)
johnkill's Avatar
Member: 49226
Thanks Meter: 9
how can this be answered no solution posted....what did u do with this, i have same problem now
Old 12-08-2014, 12:51   #9 (permalink)
Syifa.Cell's Avatar
Member: 624037
Sonork: 100.1608764
Thanks Meter: 41
need help C5-03 phone start-up failed contact the retailer.
backup vital data is OK, using ATF, how solving this phone using USB mode? I mean the step by step.
The Following User Says Thank You to Syifa.Cell For This Useful Post:
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 52 12-30-2016 07:17
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 30 02-24-2016 09:21
Page generated in 0.39940 seconds with 8 queries
