10-11-2012, 01:42 | #1 (permalink) |
No Life Poster Join Date: Oct 2009 Location: NIGERIA
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | C6-00 dead,need help pls. it only vibrates but does not power on.i have done wt i should do but no success. See attachment.also it does not enter local mode. |
The Following User Says Thank You to austinejiasa For This Useful Post: |
10-11-2012, 09:57 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Before playing in Software, Reflow Flash IC & Check, If not solve, post reply. Will try to resolve it in Software. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
10-11-2012, 22:52 | #5 (permalink) |
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | SEE USB LOG. MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C08067FA Using device: USB ROM and HTI, FW ver: 00.50, SN: 0100ADEA Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Processing MCU file: RM-612_42.0.004_prd.core.C00 [BB5,XSR 1.6] size: 111.93 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 19D00115DB8B10528BCDD7F594D55F2CDBDC98A3 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 CMT ROM ID: 4B9B75103E691FF8 Loading CMT secondary boot code SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0050 - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Loading CMT update server data Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 Update server code loaded. FUR: Adding Asic CMT as client OK. CERT backup skipped. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 207.44 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-0D39FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 505A5C85 [RAP Certificate v1 228] sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 2 min 35.110 s Processing PPM file: RM-612_42.0.004_prd.rofs2.V29 [BB5,XSR 1.6] size: 31.35 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 48 MB CMT FLASH,MuxOneNAND area [094A0000-0C49FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 44.703 s Processing PPM file: RM-612_42.0.004_C01_prd.rofs3.fpsx [BB5,XSR 1.6] size: 7.96 KB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 15 MB CMT FLASH,MuxOneNAND area [0C4A0000-0D39FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.031 s Processing CNT file: RM612_APE_ONLY_ENO_11w42_v0.020.fpsx [BB5,XSR 1.6] size: 2.68 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 4 MB CMT FLASH,MuxOneNAND area [00400000-007FFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 3.812 s Processing CNT file: RM-612_42.0.004_uda_2_001.uda.fpsx [BB5,XSR 1.6] size: 56.79 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 283.75 MB CMT FLASH,MuxOneNAND area [0D3C0000-1EF7FFFF] Flash programming ... Programming completed in 1 min 26.000 s Total time for flashing process(boot+erase+write) was 5 min 4.157 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Phone not found, retrying ... Warning: Phone did not reboot to normal mode. |
10-13-2012, 13:45 | #6 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
BR. Arsalan gsm2000. | |
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post: |
