Old 10-13-2012, 15:51   #1 (permalink)
Member: 81868
Thanks Meter: 7
nokia c5 flashing failed
proble nokia c5 rm645 cintact retailer problem flash failed error hdr block flash processs interrupt cor file metod used usb and fbus same error
ake sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00000C35
CMT EM1 ID: 00000C30
CMT PUBLIC ID: 19D0020927770E494524C0A0705E152ABA489273
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2BBAC554
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x0 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x0 bytes).
Reading CMT HWC (0x0 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Invalid Certificate Data, backup will not be created.
Error saving backup !
CMT PAPUBKEYS is blank/erased.
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 170.06 MB
CMT FLASH,MuxOneNAND area [00020000-0003FFFF]
CMT FLASH,MuxOneNAND area [00060000-004DFFFF]
CMT FLASH,MuxOneNAND area [008E0000-0AE3FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: D7D05CFC [RAP Certificate v1 249] sent
CMT GENIO_INIT block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Undefined Hdr: 00000000 [00]
Error while programming [00] at 0x06BC0400, Result: 0000
Task failed at (0800001C)!!!
Last RX buffer: 80 10 6F 00
Old 10-13-2012, 20:07   #2 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,136
CMT PAPUBKEYS is blank/erased. Already blank your chip.
Try to recovered Fbus cable post log here.
BR.
Arsalan gsm2000.
Page generated in 0.19137 seconds with 7 queries
