Old 02-27-2013, 03:40   #1 (permalink)
.:Sanjh Phoenix:.'s Avatar
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,042
Thumbs up Nokia c6-00 error
Nokia c6-00 error
see this log
Version from phone: v
Version from file: 42.0.004
MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C087E4C4
Using device: HTI, FW ver: 00.50, SN: 0100F400
Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
RPL backup already exist (C:\mobileEx\3.5\data\backup\BB5_35790104501914_BA CK.rpl).
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 18700001DB8B105240F70E8963C1C84DA99FD077
ASIC MODE ID: 00
ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.50.0 revision: 2.0 size: 0x3B40
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 9.50.0 revision: 2.0 size: 0x70C62
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: 505A5C85580A6322C103BFE4E67B73EF478E791C
Processing MCU file: RM-612_42.0.004_prd.core.C00
[BB5,XSR 1.6] size: 111.93 MB
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Storing certificate [NPC, CCC, HWC, R&D] ...ERROR: Packet Error(0xAA), code 0xA3000003
Error
Erase size: 207.44 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-0D39FFFF]
Error while erasing, Result: 00000000000000 , 0
Old 02-27-2013, 10:19   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,059
Please post buscheck logs.
I suspect your TX2 pin not connected properly.
Old 02-27-2013, 13:53   #3 (permalink)
..:\\lucky//:..'s Avatar
Member: 1864000
Thanks Meter: 2,818
Ufc cable will give better result in your case.
Old 02-28-2013, 05:51   #4 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,261
Originally Posted by Advantage View Post
Nokia c6-00 error
see this log
Bro.
Please post Buscheck Logs too,
Clean all Flashing Terminals of Cable & Phone PCB for contact problem,
Mainly TX contact Error,
Check or change FBus Cable for good result.
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Page generated in 0.19123 seconds with 7 queries
