nokia c7 after flash phone startup failed contact the retailer nokia c7 after flash phone startup failed contact the retailer Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011) Processing MCU file: RM-675_013.016_79.92_prd.core.fpsx [BB5,XSR 1.6] size: 128.82 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 28A77700 Device IO error: The device is not connected (code: 1167) Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 28A77700 CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 1410000CEC8E03449B309A74376C59AB91FF5131 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: rapuv11_2nd.fg [BB5] version: 10.22.0 revision: 3.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 00EC 0068 - 0000 0131 [Samsung LH28F160BG] type: MuxOneNAND,CMT ALG [35]: XSR 1.6 Loading CMT update server data Algorithm: rapuv11_xsr17_alg.fg [XSR 1.6] version: 10.22.0 revision: 3.0 size: 0xAC123 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 28A77700 Verifying communication to device OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x178 bytes). Reading CMT HWC (0xD4 bytes). Rpl(Certificate) backup (C:\mobileEx\3.4\data\backup\BB5_35375504224435_CE RT.rpl). CMT PAPUBKEYS HASH: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 489.06 MB Flash programming ... CMT PAPUBKEYS: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F (RAP Certificate v1 263) written. Programming completed in 18.141 s Processing PPM file: RM-675_013.016_13.01_MEA_A_79.92_prd.rofs2.fpsx [BB5,XSR 1.6] size: 29.79 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 59.25 MB Flash programming ... Programming completed in 4.016 s Processing PPM file: RM-675_013.016_C04.01_MEA_1_79.92_prd.rofs3.fpsx [BB5,XSR 1.6] size: 6.30 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 15.00 MB Flash programming ... Programming completed in 0.031 s Total time for flashing process(boot+erase+write) was 37.500 s Waiting for device boot up ... Device found: nmwcdc\Nokia USB Generic, ID: 195FE78C Verifying communication to device OK. Phone Type: RM-675 (Nokia C7-00) SW Version: V 92PS1_10w46.7 26-01-11 RM-675 (c) Nokia Imei plain: 35375504224435-2 Product Code: 059B7V7 Battery voltage: 3884 mV ApeCoreSw: 013.016 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! |
Had you try to unlock the phone or phone was perfectly working? Had you taken backup? |
if u have pm backup of phone restor them.BR SHIVA_KESARi |
26_02_2011_23_SIM.rpl 353xxxxxxxxxxx352_rpl.pm after restore give me SUPERDONGLE_KEY invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. Can Mx-key repair superdongle of c7 |
Br, div_859 |
