05-29-2012, 22:33 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Belgrade
Member: 326139 Status: Offline Thanks Meter: 4 | nokia e-5 rm-632 working eno file verru urgent? |
05-30-2012, 18:25 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | no, can not use that way. just flash it with the most recent firmware version. no more need eno. http://forum.gsmhosting.com/vbb/f550...losed-1365412/ |
05-30-2012, 22:39 | #3 (permalink) |
Member: 326139 Status: Offline Thanks Meter: 4 | Hi, fiirst of all, thanks for replay. But problem is that this phone are full erased and after that no access in test mode via usb for example and after flash no reboot in norml mode. But on this moment this phone first need to repair, now is dead. here is logs Phone type: RM-632 (Nokia E5-00) SW version: V ICPR82_10w18.13 16-07-10 RM-632 (c) Nokia ApeCoreSw: 042.007 Imei plain: 35485904738028-3 Product code: 059D955 Battery voltage: 4788 mV, current: 58 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid Phone version(042.007) outdated, selected version is: 42.7 Imei net: 354859047380283 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN warning: the file you selected(042.007) is outdated, latest version on server is: 071.003 Latest software release for Nokia E5-00 is 071.003 RPL: "C:\mobileEx\3.5\data\backup\354859047380283.r pl" Imei: 35485904738028 Updating SIMLOCK(PA_SL3)...OK Phone type: RM-632 (Nokia E5-00) SW version: V ICPR82_10w18.13 16-07-10 RM-632 (c) Nokia Imei plain: 35485904738028-3 Product code: 059D955 Battery voltage: 4788 mV, current: 100 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 354859047380283 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Done. MXKEY [FT SCR2000 1], SN: C080939A Using device: HTI, FW ver: 00.48, SN: 00018FCE Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 1C900118A0A4034433F454B2378BF3D168281749 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.2.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.2.0 revision: 3.0 size: 0xD44E9 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C CMT FLASH,MuxOneNAND area [00000000-00FDFFFF] Erase size: 15.87 MB Prog.status for Asic CMT ... NAND: OK MXKEY [FT SCR2000 1], SN: C080939A Using device: HTI, FW ver: 00.48, SN: 00018FCE Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 1C900118A0A4034433F454B2378BF3D168281749 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.2.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: FFFF FFFF - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.2.0 revision: 3.0 size: 0xD44E9 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS is blank/erased. Processing MCU file: rm632_091.001_prd.core.fpsx [BB5,XSR 1.6] size: 103 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning ...OK Erase size: 227.31 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0E77FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: CCD9F805 [RAP Certificate v1 238] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 4 min 36.922 s Processing PPM file: rm632_091.001_49.01_Balkans_QW1_x2_prd.rofs2.fpsx [BB5,XSR 1.6] size: 57.88 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Erase size: 71.50 MB CMT FLASH,MuxOneNAND area [08980000-0D0FFFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 2 min 38.860 s Processing PPM file: rm632_091.001_C00.01_DEFAULT_prd.rofs3.fpsx [BB5,XSR 1.6] size: 8.43 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Erase size: 22.50 MB CMT FLASH,MuxOneNAND area [0D100000-0E77FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS3 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 23.328 s Processing CNT file: rm632_091.001_U005.000_prd.uda.fpsx [BB5,XSR 1.6] size: 24.16 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Erase size: 265.75 MB CMT FLASH,MuxOneNAND area [0E780000-1F13FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 1 min 6.969 s Total time for flashing process(boot+erase+write) was 8 min 58.422 s Phone type: RM-632 (Nokia E5-00) SW version: V ICPR82_11w16.3.10 13-03-12 RM-632 (c) Nokia ApeCoreSw: 091.001 Imei plain: 12345610654321-? Product code: 059D955 Battery voltage: 4788 mV, current: 101 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed Imei plain is invalid !!! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Imei: 35485904738028 Updating SIMLOCK(PA_SL3)...error 0x17 Trying to write SIMLOCK as PM(PA_SL3)...Updating WMDRM_PD ...OK MXKEY [FT SCR2000 1], SN: C080939A Using device: HTI, FW ver: 00.48, SN: 00018FCE Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 1C900118A0A4034433F454B2378BF3D168281749 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.2.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.2.0 revision: 3.0 size: 0xD44E9 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Prog.status for Asic CMT ... NAND: OK Phone type: RM-632 (Nokia E5-00) SW version: V ICPR82_11w16.3.10 13-03-12 RM-632 (c) Nokia Imei plain: 35485904738028-3 Product code: 059D955 Battery voltage: 4788 mV, current: 101 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SECURITY_TEST failed! Imei net: 354859047380283 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Restoring SIMLOCK from PM ... Updating SIMLOCK(PA_SL3)...OK Done. Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 2 (10 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 6 (10 bytes) Warning: failed to write 1 - 7 (214 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (10 bytes) Warning: failed to write 1 - 16 (208 bytes) Warning: failed to write 1 - 18 (208 bytes) Warning: failed to write 1 - 20 (208 bytes) Warning: failed to write 1 - 22 (16 bytes) Warning: failed to write 1 - 23 (4 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 26 (110 bytes) Warning: failed to write 1 - 28 (10 bytes) Warning: failed to write 1 - 29 (10 bytes) Warning: failed to write 1 - 31 (208 bytes) Warning: failed to write 1 - 33 (36 bytes) Warning: failed to write 1 - 34 (376 bytes) Warning: failed to write 1 - 35 (16 bytes) Warning: failed to write 1 - 37 (4 bytes) Warning: failed to write 1 - 39 (36 bytes) Warning: failed to write 1 - 40 (16 bytes) Warning: failed to write 1 - 41 (182 bytes) Warning: failed to write 1 - 42 (4 bytes) Warning: failed to write 1 - 43 (36 bytes) Warning: failed to write 1 - 44 (182 bytes) Warning: failed to write 1 - 45 (182 bytes) Section: 2 - Key: 0, size 2080 bytes written. Section: 4 - Key: 1, size 1020 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 18, size 80 bytes written. - Key: 19, size 4 bytes written. - Key: 28, size 2 bytes written. Section: 6 - Key: 0, size 32 bytes written. Section: 8 - Key: 0, size 2 bytes written. - Key: 1, size 16 bytes written. - Key: 2, size 16 bytes written. - Key: 3, size 128 bytes written. - Key: 4, size 128 bytes written. - Key: 5, size 8 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 8 bytes written. - Key: 9, size 8 bytes written. - Key: 10, size 32 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1058 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 26 - Key: 0, size 16 bytes written. - Key: 1, size 68 bytes written. Section: 31 - Key: 4, size 14 bytes written. Section: 44 - Key: 0, size 1 byte written. Section: 50 - Key: 0, size 2 bytes written. - Key: 1, size 22 bytes written. Section: 54 - Key: 0, size 2 bytes written. - Key: 2, size 24 bytes written. Section: 88 - Key: 0, size 36 bytes written. Section: 96 - Key: 0, size 2 bytes written. - Key: 1, size 20 bytes written. Section: 107 - Key: 0, size 41 bytes written. - Key: 1, size 89 bytes written. - Key: 2, size 89 bytes written. - Key: 3, size 70 bytes written. - Key: 25, size 236 bytes written. - Key: 26, size 12 bytes written. Section: 117 - Key: 0, size 4 bytes written. - Key: 1, size 3 bytes written. - Key: 2, size 6 bytes written. - Key: 3, size 1 byte written. - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 8, size 42 bytes written. - Key: 13, size 3 bytes written. - Key: 14, size 3 bytes written. - Key: 16, size 40 bytes written. - 120 skipped Section: 153 - Key: 0, size 68 bytes written. - Key: 1, size 68 bytes written. - Key: 2, size 68 bytes written. - Key: 3, size 68 bytes written. - Key: 4, size 68 bytes written. - Key: 5, size 68 bytes written. - Key: 6, size 68 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 217 - Key: 0, size 32 bytes written. - 239 skipped Section: 291 - Key: 0, size 92 bytes written. - 308 skipped Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 3 (36 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Section: 313 - Key: 0, size 173 bytes written. Section: 322 - Key: 0, size 1 byte written. Section: 327 - Key: 0, size 2 bytes written. Section: 329 - Key: 0, size 8392 bytes written. Section: 334 - Key: 0, size 1 byte written. Section: 341 - Key: 0, size 1 byte written. - Key: 3, size 4 bytes written. - Key: 4, size 4518 bytes written. Section: 354 - Key: 0, size 15 bytes written. Section: 356 - Key: 0, size 2 bytes written. - Key: 1, size 8 bytes written. Section: 360 - Key: 0, size 1 byte written. - Key: 1, size 2 bytes written. - Key: 2, size 3 bytes written. Section: 369 - Key: 0, size 40 bytes written. Completed in 1 min 2.531 s Phone type: RM-632 (Nokia E5-00) SW version: V ICPR82_11w16.3.10 13-03-12 RM-632 (c) Nokia Imei plain: 35485904738028-3 Product code: 059D955 Battery voltage: 4788 mV, current: 100 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid Phone version(091.001) outdated, selected version is: 91.1 Phone version(091.001) outdated, latest version on server is: 071.003 Imei net: 354859047380283 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Selected image is up-to-date Latest software release for Nokia E5-00 is 071.003 Phone type: RM-632 (Nokia E5-00) SW version: V ICPR82_11w16.3.10 13-03-12 RM-632 (c) Nokia ApeCoreSw: 091.001 Imei plain: 35485904738028-3 Product code: 059D955 Battery voltage: 4788 mV, current: 64 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Imei net: 354859047380283 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Latest software release for Nokia E5-00 is 071.003 Confirmation Found RFBB data in local storage, Do you want to write this file to phone? i click yes... Scanning local SX4 Card ... No SX4 Card found. SERVER->MXKEY - BLADE X at host1, agent version 1.2 revision 0.4 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 82.208.237.108 SUPERDONGLE authorized ! warning: SD authorized but verify failed ! Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 82.208.237.108 SUPERDONGLE authorized ! Writing RFBB data: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb\C5_RM-632.txt ... Writing RF settings to phone ...OK, finished. 28 Records found. Writing BB settings to phone ...OK, finished. 7 Records found. Done. Scanning local SX4 Card ... No SX4 Card found. SERVER->MXKEY - BLADE X at host1, agent version 1.2 revision 0.4 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 82.208.237.108 SUPERDONGLE authorized ! Writing RFBB data: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb\C5_RM-632.txt ... Writing RF settings to phone ...OK, finished. 28 Records found. Writing BB settings to phone ...OK, finished. 7 Records found. Done. Scanning local SX4 Card ... No SX4 Card found. Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 82.208.237.108 SUPERDONGLE authorized ! Writing RFBB data: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb\C5_RM-632.txt ... Writing RF settings to phone ...OK, finished. 28 Records found. Writing BB settings to phone ...OK, finished. 7 Records found. Done. SERVER->MXKEY - BLADE X at host1, agent version 1.2 revision 0.4 Updating RFBB data ... Writing section 1... Error 0 Writing section 309... Error 0 Done. |
