11-29-2011, 17:08 | #1 (permalink) |
Junior Member Join Date: Dec 2005 Location: FANCE
Member: 205312 Status: Offline Thanks Meter: 2 | nokia E 72 help me please (SOLVED) I flashed a nokia E72 with MXKEY with the latest version and it does boot up help me please MXKEY [USB Smart Card Reader 0], SN: C0842D59 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.72 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Processing MCU file: rm530_054.005_prd.core.fpsx [BB5,XSR 1.6] size: 104.53 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1502E05D CMT SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 1310010C296603449ED6C270A54BDCA44A5C41F3 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 CMT ROM ID: 3E273BF637BE26FA Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0058 - 0000 0121 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1502E05D FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35523903344151_CE RT.rpl). CMT PAPUBKEYS HASH: 660D81A4455F6F7F9B81D5D10F5336B14B50635E Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 227.31 MB CMT FLASH,MuxOneNAND area [00020000-0003FFFF] CMT FLASH,MuxOneNAND area [00060000-004DFFFF] CMT FLASH,MuxOneNAND area [008E0000-0E77FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 660D81A4 [RAP Certificate 175 v.1] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 34.687 s Processing PPM file: rm530_054.005_08.01_French_QW_prd.rofs2.fpsx [BB5,XSR 1.6] size: 67.29 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 81 MB CMT FLASH,MuxOneNAND area [07CC0000-0CDBFFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 20.969 s Processing PPM file: rm530_054.005_C00.01_DEFAULT_prd.rofs3.fpsx [BB5,XSR 1.6] size: 7.55 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 25.75 MB CMT FLASH,MuxOneNAND area [0CDC0000-0E77FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 2.172 s Processing CNT file: RM530_ENO_APE_ONLY_09wk35_v0.038.fpsx [BB5,XSR 1.6] size: 2.58 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104 Erase size: 4 MB CMT FLASH,MuxOneNAND area [004E0000-008DFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 0.985 s Processing CNT file: rm530_054.005_U007.000_prd.uda.fpsx [BB5,XSR 1.6] size: 9.99 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104 Erase size: 265.75 MB CMT FLASH,MuxOneNAND area [0E780000-1F13FFFF] Flash programming ... Programming completed in 5.454 s Total time for flashing process(boot+erase+write) was 1 min 22.703 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Phone not found, retrying ... Warning: Phone did not reboot to normal mode. |
11-29-2011, 19:51 | #2 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 47
Member: 170098 Status: Offline Thanks Meter: 15 | reflash with this flash all will be ok Nokia E72 RM-530 Version History |
The Following User Says Thank You to chambolet For This Useful Post: |
11-30-2011, 05:50 | #3 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | higher firmware version for E72 is available than current version you flashed. press download on mobileex to get it, or use fire agent http://forum.gsmhosting.com/vbb/f550...guide-1365412/ BR |
The Following User Says Thank You to gbluez For This Useful Post: |
06-19-2012, 08:00 | #6 (permalink) |
Junior Member Join Date: Sep 2008 Location: Jodhpur(INDIA)
Member: 869495 Status: Offline Sonork: 12345 Thanks Meter: 14 | go here how to hack your phone.. to install unsigned application.. teja729255 - peperonity.com than go mostwanted software. |
