Old 10-21-2011, 11:00   #1 (permalink)
Member: 459869
Thanks Meter: 47
Exclamation Nokia E5 after flash blank screen & not power on. help! ##
My Nokia E5 RM632 after usb flash completed become when power on only vibrate 1 time then blank screen not power on, please help & advice
flashing status:
MXKEY Serial: [FT SCR2000 0] - C0807309
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: nmwcdc, ver: 7.1.32.67
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
Processing MCU file: rm632_071.003_prd.core.fpsx
 [BB5,XSR 1.6]  size: 102.95 MB
 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 600C192102031104, 6003192102031104
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 10699746
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1]
CMT EM0 ID: 00000C35
CMT EM1 ID: 00000C30
CMT PUBLIC ID: 12700105FAA403444AA9BC0B6C1A6B7D22154995
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
 SecondaryBoot: RAPUv11_2nd.fg [BB5]  version: 11.14.0 revision: 3.0 size: 0x3B40
 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000  - 0000 0000  type: RAM, asic:CMT
Storage1: FFFF 0000  - 0000 0000  type: MMC, asic:CMT
Storage2: 0000 0000  - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001  - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0050  - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6]  version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x18F bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35485904109489_CERT.rpl).
CMT PAPUBKEYS HASH: CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 227.31 MB
CMT FLASH,MuxOneNAND area [00020000-0003FFFF]
CMT FLASH,MuxOneNAND area [00060000-004DFFFF]
CMT FLASH,MuxOneNAND area [008E0000-0E77FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: CCD9F805 [RAP Certificate v1 238] sent
CMT GENIO_INIT block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 18.828 s
Processing PPM file: rm632_071.003_33.01_APAC_QW1_prd.rofs2.fpsx
 [BB5,XSR 1.6]  size: 64.10 MB
Erase size: 71.50 MB
CMT FLASH,MuxOneNAND area [08980000-0D0FFFFF]
CMT SOS+ROFS2 block sent
Programming completed in 11.812 s
Processing PPM file: rm632_071.003_C00.01_DEFAULT_prd.rofs3.fpsx
 [BB5,XSR 1.6]  size: 8.43 MB
Erase size: 22.50 MB
CMT FLASH,MuxOneNAND area [0D100000-0E77FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 1.625 s
Processing CNT file: rm632_071.003_U005.000_prd.uda.fpsx
 [BB5,XSR 1.6]  size: 20.76 MB
Erase size: 265.75 MB
CMT FLASH,MuxOneNAND area [0E780000-1F13FFFF]
Programming completed in 4.875 s
Total time for flashing process(boot+erase+write) was 53.906 s
Waiting for device boot up ...
Device connected: nmwcdc\Nokia E5-00 USB Phonet, PORT_ID: 350EF883
Verifying communication to device OK.
Phone type: RM-632 (Nokia E5-00)
SW version: V ICPR82_11w16.3 19-05-11 RM-632 (c) Nokia
Imei plain: 35485904109489-8
Product code: 0595444
Battery voltage: 3793 mV, current: 140 mA
ApeCoreSw: 071.003
Language Pack:
- not available.
Detected as PA_SL3 phone.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354859041094898
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 10-21-2011, 11:05   #2 (permalink)
unlock phones's Avatar
Member: 1552610
Sonork: 100.1604734
Thanks Meter: 1,370
try with best dongle
Old 10-21-2011, 11:29   #3 (permalink)
Member: 459869
Thanks Meter: 47
Exclamation
I don't undrestand what you mean?
is there my mxkey dongle not best or cannot use?
Old 10-21-2011, 11:43   #4 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
the log seems normal, try using fbus cable bro, then go to quickfix tab, then do bb5 rap3nand erase user area and bb5 sw downgrade fix if needed as well. try these 2 magic buttons from mxkey
good luck bro
br
Old 10-21-2011, 12:32   #5 (permalink)
sankhla871's Avatar
Member: 1438538
Thanks Meter: 39
FLASH WITH ENO FILE TESTED BY ME http://forum.gsmhosting.com/vbb/f299...ailer-1313113/
Old 10-21-2011, 13:56   #6 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
he means: MXKEY is the BEST DONGLE
- check battery, check battery pins.
Old 01-16-2014, 05:57   #7 (permalink)
rana00's Avatar
Member: 997268
Sonork: 100.1661167
Thanks Meter: 113
fast check bsi...
check lcd
replace lcd connectore
Page generated in 0.16378 seconds with 9 queries
