11-22-2012, 17:11 | #1 (permalink) |
No Life Poster Join Date: Dec 2005 Location: mt brazil
Member: 211017 Status: Offline Thanks Meter: 312 | Nokia e5 SECURITY TEST failed MXKEY [MxKey Team HTI PLUS Flasher Interface 5], SN: C0XXXX78 Using device: HTI, FW ver: 00.50, SN: 01XXXX5A Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 12200206B1D60344C33647B6CB568B36BA60C386 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0050 - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD4569 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C Selected firmware certificate matched. Original Imei: 353399045XXXX65 Original Product code: 059B854 Bluetooth ID: A8E018B1FDDA SIMLOCK PA identifier: [0] PA_SIMLOC30 Phone type: RM-634 (Nokia E5-00.2) SW version: V ICPR82_11w16.3 19-05-11 RM-634 (c) Nokia Imei plain: 353399045XXXX6-5 Product code: 059B854 Battery voltage: 4648 mV, current: 97 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 353399045XXXX65 Version: SIMLOCK SERVER Provider: Tess , Country: Brazil Counter: 0/3, 0/10 CONFIG_DATA: 7240600086388183 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN BLOCK2: 1=OPEN BLOCK3: 1=OPEN BLOCK4: 1=OPEN BLOCK5: 1=OPEN BLOCK6: 1=OPEN BLOCK7: 1=OPEN BLOCK8: 1=OPEN BLOCK9: 1=OPEN BLOCK10: 1=OPEN BLOCK11: 1=OPEN BLOCK12: 1=OPEN BLOCK13: 1=OPEN BLOCK14: 1=OPEN MXKEY [MxKey Team HTI PLUS Flasher Interface 5], SN: C0XXXX78 Using device: HTI, FW ver: 00.50, SN: 01XXXX5A Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Phone type: RM-634 (Nokia E5-00.2) SW version: V ICPR82_11w16.3 19-05-11 RM-634 (c) Nokia Using cached productData. PUBLIC ID: 12200206B1D60344C33647B6CB568B36BA60C386 PRIVATE ID: C4557A4D7B93DB6EDC9CE9BC1EA0EAF9F2F7AC51 SUPERDONGLE authorized ! Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (116 bytes) Warning: failed to write 1 - 2 (12 bytes) Warning: failed to write 1 - 4 (112 bytes) Warning: failed to write 1 - 6 (12 bytes) Warning: failed to write 1 - 7 (216 bytes) Warning: failed to write 1 - 8 (112 bytes) Warning: failed to write 1 - 13 (12 bytes) Warning: failed to write 1 - 16 (208 bytes) Warning: failed to write 1 - 18 (208 bytes) Warning: failed to write 1 - 20 (208 bytes) Warning: failed to write 1 - 22 (16 bytes) Warning: failed to write 1 - 23 (4 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 26 (112 bytes) Warning: failed to write 1 - 28 (12 bytes) Warning: failed to write 1 - 29 (12 bytes) Warning: failed to write 1 - 31 (208 bytes) Warning: failed to write 1 - 33 (36 bytes) Warning: failed to write 1 - 34 (376 bytes) Warning: failed to write 1 - 35 (16 bytes) Warning: failed to write 1 - 37 (4 bytes) Warning: failed to write 1 - 39 (36 bytes) Warning: failed to write 1 - 40 (16 bytes) Warning: failed to write 1 - 41 (184 bytes) Warning: failed to write 1 - 42 (4 bytes) Warning: failed to write 1 - 43 (36 bytes) Warning: failed to write 1 - 44 (184 bytes) Warning: failed to write 1 - 45 (184 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (4 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 3 (36 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Completed in 1.547 s Phone Type: RM-634 SW version: V ICPR82_11w16.3 19-05-11 RM-634 (c) Nokia ID Test name Startup Result 15 SLEEP_X_LOOP N passed 46 UEM_CBUS_IF N passed 3 EAR_DATA_LOOP N passed 12 SIM_CLK_LOOP Y passed 33 SIM_LOCK N passed 93 SECURITY N !failed ! 90 PWR_KEY N passed 2 CURRENT_CONS N passed 96 HOOKINT N passed 101 BTEMP N passed 8 MBUS_RX_TX_LOOP Y passed 23 KELVIN_BATVOLTAGE N passed 19 KELVIN_VIBRA N !no signal 26 KELVIN_CAPACITOR N !no signal 29 KELVIN_MISC N passed 27 KELVIN_AUDIO N passed 116 KELVIN_XEAR N passed 32 AMB_LIGHT_SENSOR N passed 34 USB_CHARGING N passed 119 IIC N passed 117 DIGIMIC N passed 64 RAM_IF N passed 222 LED_CONTROLLER N passed 128 CDSP_SLEEPCLOCK_FREQ N passed 86 CDSP_RF_BB_IF N passed 83 CDSP_RF_SUPPLY N passed 85 CDSP_TX_IQ N passed 74 CDSP_TXC_DATA N passed 79 CDSP_RX_PLL_PHASE_LOCK N passed 80 CDSP_TX_PLL_PHASE_LOCK N passed 75 CDSP_WCDMA_TX_POWER N !NOT EXECUTED(03) 81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03) 77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03) |
11-22-2012, 17:21 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Try this way: Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-634.PM file, Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result. BR, ZUBER |
11-23-2012, 08:21 | #4 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: KOLHAPUR, MAHARASTRA,INDIA
Member: 71502 Status: Offline Sonork: 100.1650667 Thanks Meter: 587 | Quote:
BR. I FACE SAME PROBLEM WITH C5-00 WHEN I WRITE GOOD PM PM WRITE OK BUT SAME PROBLEM SECURITY_TEST failed! I CREATE NEW TRICK WHEN I WRITE 1&309 PM I SELECT PM TICK TO ONLY 1 & WRITE OK & AFTER TICK TO 309 & WRITE OK SET IS OK SECURITY_TEST PASSED PLS. TRY THIS METHOD & LOG HERE | |
11-23-2012, 14:32 | #5 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | Same problem MXKEY [MxKey Team HTI PLUS Flasher Interface 6], SN: C0XXXX78 Using device: HTI, FW ver: 00.50, SN: 01XXXX5A Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Phone type: RM-634 (Nokia E5-00.2) SW version: V ICPR82_11w16.3 19-05-11 RM-634 (c) Nokia ApeCoreSw: 071.003 Using cached productData. PUBLIC ID: 12200206B1D60344C33647B6CB568B36BA60C386 PRIVATE ID: C4557A4D7B93DB6EDC9CE9BC1EA0EAF9F2F7AC51 Updating SUPERDONGLE_KEY ...OK Now you can write RFBB/PM data to the phone. Done. Writing PM from Node ... Section: 1 - Key: 0, size 114 bytes written. - Key: 2, size 10 bytes written. - Key: 4, size 110 bytes written. - Key: 6, size 10 bytes written. - Key: 7, size 214 bytes written. - Key: 8, size 110 bytes written. - Key: 13, size 10 bytes written. - Key: 16, size 208 bytes written. - Key: 18, size 208 bytes written. - Key: 20, size 208 bytes written. - Key: 22, size 16 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 84 bytes written. - Key: 26, size 110 bytes written. - Key: 28, size 10 bytes written. - Key: 29, size 10 bytes written. - Key: 31, size 208 bytes written. - Key: 33, size 36 bytes written. - Key: 34, size 376 bytes written. - Key: 35, size 16 bytes written. - Key: 37, size 4 bytes written. - Key: 39, size 36 bytes written. - Key: 40, size 16 bytes written. - Key: 41, size 182 bytes written. - Key: 42, size 4 bytes written. - Key: 43, size 36 bytes written. - Key: 44, size 182 bytes written. - Key: 45, size 182 bytes written. - 239 skipped Completed in 3.453 s MXKEY [MxKey Team HTI PLUS Flasher Interface 6], SN: C0XXXX78 Using device: HTI, FW ver: 00.50, SN: 01XXXX5A Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) Phone type: RM-634 (Nokia E5-00.2) SW version: V ICPR82_11w16.3 19-05-11 RM-634 (c) Nokia ApeCoreSw: 071.003 Using cached productData. PUBLIC ID: 12200206B1D60344C33647B6CB568B36BA60C386 PRIVATE ID: C4557A4D7B93DB6EDC9CE9BC1EA0EAF9F2F7AC51 Updating SUPERDONGLE_KEY ...OK Authenticating to SUPERDONGLE ... SUPERDONGLE authorized ! Now you can write RFBB/PM data to the phone. Done. Writing PM from Node ... - 239 skipped Section: 309 - Key: 0, size 4 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 12 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 12 bytes written. - Key: 7, size 12 bytes written. - Key: 17, size 12 bytes written. Completed in 2.422 s MXKEY [MxKey Team HTI PLUS Flasher Interface 6], SN: C0XXXX78 Using device: HTI, FW ver: 00.50, SN: 01XXXX5A Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 12200206B1D60344C33647B6CB568B36BA60C386 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0050 - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD4569 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C Selected firmware certificate matched. Original Imei: 353399045XXXX6 Original Product code: 059B854 Bluetooth ID: A8E018B1FDDA SIMLOCK PA identifier: [0] PA_SIMLOC30 Phone type: RM-634 (Nokia E5-00.2) SW version: V ICPR82_11w16.3 19-05-11 RM-634 (c) Nokia Imei plain: 353399045XXXX6-5 Product code: 059B854 Battery voltage: 4694 mV, current: 97 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 353399045614665 Version: SIMLOCK SERVER Provider: Tess , Country: Brazil Counter: 0/3, 0/10 CONFIG_DATA: 7240600086388183 PROFILE_BITS: 0000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=72406F [Brazil-Tess ] BLOCK2: 1=CLOSED(MCCMNC), DATA=72410F [Brazil-ATL Algar ] BLOCK3: 1=CLOSED(MCCMNC), DATA=72406F [Brazil-Tess ] BLOCK4: 1=CLOSED(MCCMNC), DATA=72410F [Brazil-ATL Algar ] BLOCK5: 1=CLOSED(MCCMNC), DATA=72411F [Brazil-Telems Cel ] BLOCK6: 1=CLOSED(MCCMNC), DATA=72411F [Brazil-Telems Cel ] BLOCK7: 1=CLOSED(MCCMNC), DATA=21407F [Spain-Telefónica Móviles España, SAU ] BLOCK8: 1=CLOSED(MCCMNC), DATA=21407F [Spain-Telefónica Móviles España, SAU ] BLOCK9: 1=CLOSED(MCCMNC), DATA=21402F BLOCK10: 1=CLOSED(MCCMNC), DATA=21402F BLOCK11: 1=CLOSED(MCCMNC), DATA=26806F [Portugal-TMN - Telecomunicaçôes Movéis Nacionais, S.A. ] BLOCK12: 1=CLOSED(MCCMNC), DATA=26806F [Portugal-TMN - Telecomunicaçôes Movéis Nacionais, S.A. ] BLOCK13: 1=CLOSED(MCCMNC), DATA=72423F [Brazil-Telest Cel ] BLOCK14: 1=CLOSED(MCCMNC), DATA=72423F [Brazil-Telest Cel ] |
11-27-2012, 13:31 | #8 (permalink) |
Member: 211017 Status: Offline Thanks Meter: 312 | CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 12200206B1D60344C33647B6CB568B36BA60C386 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0050 - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD4569 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C Reading CMT NPC (0x190 bytes). Original Product Code: 059B854 Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Product Code: 059B854 CCC seems to be valid Reading CMT HWC (0xD4 bytes). Product Code: 059B854 HWC seems to be valid MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C0XXXX78 Using device: HTI, FW ver: 00.50, SN: 01XXXX5A Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C35 EM1 ID: 00000C30 PUBLIC ID: 12200206B1D60344C33647B6CB568B36BA60C386 ASIC MODE ID: 00 ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B ROM ID: E693EF0DAC22615B SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0050 - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD4569 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: CCD9F80559BA50D9B3E274F9E7120BE1EE4EEA7C Original Imei: 353399045XXXX6 Original Product code: 059B854 Bluetooth ID: A8E018B1FDDA SIMLOCK PA identifier: [0] PA_SIMLOC30 Phone type: RM-634 (Nokia E5-00.2) SW version: V ICPR82_11w16.3 19-05-11 RM-634 (c) Nokia Imei plain: 3533990456XXXX-5 Product code: 059B854 Battery voltage: 4603 mV, current: 78 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 353399045614665 Version: SIMLOCK SERVER Provider: Tess , Country: Brazil Counter: 0/3, 0/10 CONFIG_DATA: 7240600086388183 PROFILE_BITS: 0000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=72406F [Brazil-Tess ] BLOCK2: 1=CLOSED(MCCMNC), DATA=72410F [Brazil-ATL Algar ] BLOCK3: 1=CLOSED(MCCMNC), DATA=72406F [Brazil-Tess ] BLOCK4: 1=CLOSED(MCCMNC), DATA=72410F [Brazil-ATL Algar ] BLOCK5: 1=CLOSED(MCCMNC), DATA=72411F [Brazil-Telems Cel ] BLOCK6: 1=CLOSED(MCCMNC), DATA=72411F [Brazil-Telems Cel ] BLOCK7: 1=CLOSED(MCCMNC), DATA=21407F [Spain-Telefónica Móviles España, SAU ] BLOCK8: 1=CLOSED(MCCMNC), DATA=21407F [Spain-Telefónica Móviles España, SAU ] BLOCK9: 1=CLOSED(MCCMNC), DATA=21402F BLOCK10: 1=CLOSED(MCCMNC), DATA=21402F BLOCK11: 1=CLOSED(MCCMNC), DATA=26806F [Portugal-TMN - Telecomunicaçôes Movéis Nacionais, S.A. ] BLOCK12: 1=CLOSED(MCCMNC), DATA=26806F [Portugal-TMN - Telecomunicaçôes Movéis Nacionais, S.A. ] BLOCK13: 1=CLOSED(MCCMNC), DATA=72423F [Brazil-Telest Cel ] BLOCK14: 1=CLOSED(MCCMNC), DATA=72423F [Brazil-Telest Cel ] |
11-27-2012, 16:38 | #10 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi Bro., Extract & Copy this RM-634.PM file in C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb\ Now do Repair SD with my Method: Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-634.PM file, Click Repair SD & click no to Pop Up Window, Now Click Write, must work for you. Best of Luck. BR, ZUBER |
