08-19-2011, 11:21 | #1 (permalink) |
No Life Poster Join Date: Jul 2009 Location: PAKISTAN Age: 34
Member: 1082907 Status: Offline Sonork: 100.1606954 Thanks Meter: 342 | nokia e52 phone startup failed contact retailer (SOLVED) mx key scan log Phone type: RM-469 (Nokia E52-1) SW version: V ICPR82_11w16.3 19-05-11 RM-469 (c) Nokia Imei plain: 35932703625862-6 Product code: 0592455 Battery voltage: 4795 mV, current: 57 mA ApeCoreSw: 071.004 Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 359327036258626 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN bus chak log MXKEY Serial: [FT SCR2000 0] - C084CAE9 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Connection status: UHCI:HUB:HUB:USB 1.10 (Full-speed) Driver: UFS2XX, ver: 2.0.0.0 , NTMP ver: 2.0.0.1 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1] EM0 ID: 00001040 EM1 ID: 00001030 PUBLIC ID: 1B800213DB6C0344FB27F7A211F19DCF9E445F42 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3AC0 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 eBB5ProtocolType: OLD Storage0: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage content: D057 3AA6 EF60 625F E060 05AB BD30 B503 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Flash ID not supported for this loader (RAPUv11_algo_xsr16.fg) Algorithm: RAPUv11_algo_xsr16.fg [XSR 1.6] version: 1.40.0 revision: 0.0 size: 0x2CB60 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Original Imei: 00000000000000 Original Product code: |
04-09-2014, 08:52 | #7 (permalink) |
Junior Member Join Date: Apr 2014
Member: 2163984 Status: Offline Thanks Meter: 1 | i have the same problem with my nokia e52.... kindly help........... go to pm section select load from Rfbb... server then repair SD then write data............ Please more instruction!!! |
The Following User Says Thank You to zoranj For This Useful Post: |
