Old 08-31-2012, 13:24   #1 (permalink)
Member: 830047
Thanks Meter: 6
Nokia E6-00 only vibrate
here a log:
MXKEY [MxKey Team HTI PLUS Flasher Interface 7], SN: C0853...
Using device: HTI, FW ver: 00.50, SN: 0100D...
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Processing MCU file: RM-609_025.007_79.92_prd.core.fpsx
[BB5,XSR 1.6] size: 121.23 MB
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
CMT Data :
SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
EM0 ID: 00001040
EM1 ID: 00001030
PUBLIC ID: 0A40020CB9DC03444C8045D7661A8CC6C604712F
ASIC MODE ID: 00
ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
ROM ID: E693EF0DAC22615B
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0060 - 0000 0032 [Samsung LH28F800BG] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD4569
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: 327C6B67C95DA04A763DEFD4BA15C19FF16D9AE7
Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK
Partitioning ...OK
Erase size: 531.56 MB
CMT FLASH,MuxOneNAND area [00040000-0007FFFF]
CMT FLASH,MuxOneNAND area [000C0000-008BFFFF]
CMT FLASH,MuxOneNAND area [010C0000-116FFFFF]
CMT FLASH,MuxOneNAND area [2E100000-3E5FFFFF]
Formating partition ...
Prog.status for Asic CMT ...
NAND: OK
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 327C6B67 [RAP Certificate 219 Ver] sent
CMT GENIO_INIT block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
NAND: OK
Programming completed in 3 min 37.000 s
Processing PPM file: RM-609_025.007_18.01_Hungarian_QW1_79.92_prd.rofs2.fp sx
[BB5,XSR 1.6] size: 33.75 MB
CMT Data :
EM0 ID: 00001040
EM1 ID: 00001030
ASIC MODE ID: 00
Erase size: 67.50 MB
CMT FLASH,MuxOneNAND area [0C000000-1037FFFF]
NAND: OK
CMT SOS+ROFS2 block sent
NAND: OK
Programming completed in 59.547 s
Total time for flashing process(boot+erase+write) was 7 min 0.093 s
Old 09-01-2012, 16:21   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Most of the reason for this Error is due Flashed with Unmatched Firmware.
So Download & Flash with Latest Firmware with same Product Code of your Phone, most of them resolve with this.
Post reply after Flash with Logs if not solve.
BR,
ZUBER
Old 10-24-2012, 21:28   #3 (permalink)
Mustansar's Avatar
Member: 1081067
Thanks Meter: 107
if not then what one should do?
Old 08-28-2013, 14:29   #4 (permalink)
Member: 1172949
Sonork: felix
Thanks Meter: 7
my e6 just vibrates, but when i plug to usb it comes up. no system communication, could not flash. any solution?
Old 08-28-2013, 15:21   #5 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Check USB Pin Ways, refer to Schematic,
BTW Use FBus Cable or Jig to Flash & select HTI as Interface,
Post reply.
BR,
ZUBER
Page generated in 0.18611 seconds with 9 queries
