11-19-2012, 14:12 | #1 (permalink) |
Registered User Join Date: Jul 2012
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | Nokia E63 (RM-437) Cant Repair WD Timer Enabaled I tried 3.5.2.1 it's say error when do Repair SD SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. Updating SUPERDONGLE_KEY ...error 0x3 Authenticating to SUPERDONGLE ... Wrong response to SD verify request Please do not tell me to use 5.2.1.3 because it must using MXBOX for interface. Please how to fix this problem? Thanks |
The Following User Says Thank You to viewprofile For This Useful Post: |
11-19-2012, 14:46 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi, Post Full & Unedited Buscheck Logs if want help here. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
11-19-2012, 14:48 | #3 (permalink) |
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C0871221 Using device: HTI, FW ver: 00.50, SN: 01005DAE Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 13300112699900521DC816EDA75DEE79F29D6A78 ASIC MODE ID: 00 ROOT KEY HASH: C70CB07324056BC66A824347F40DB2D5 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.50.0 revision: 2.0 size: 0x3B40 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 9.50.0 revision: 2.0 size: 0x70C62 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 Original Imei: 35339704475312 Original Product code: 059B8P2 Bluetooth ID: 6C9B02418C08 SIMLOCK PA identifier: [0] PA_SL2 [1] PA_SL3 Phone type: RM-437 (Nokia E63) SW version: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia ApeCoreSw: 510.21.010 Imei plain: 35339704475312-0 Product code: 059B8P2 Battery voltage: 4683 mV, current: 0 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 353397044753120 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
11-19-2012, 14:49 | #4 (permalink) |
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C0871221 Using device: HTI, FW ver: 00.50, SN: 01005DAE Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Phone type: RM-437 (Nokia E63) SW version: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia ApeCoreSw: 510.21.010 Using cached productData. PUBLIC ID: 13300112699900521DC816EDA75DEE79F29D6A78 PRIVATE ID: 00544CB875C1C044418E5F7684B858B9575EA191 Updating SUPERDONGLE_KEY ...error 0x3 Authenticating to SUPERDONGLE ... Wrong response to SD verify request |
11-19-2012, 15:10 | #5 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Hi, Where is Latest Mxkey Software Ver3.5 Rev2.4 ? You're using Older, So Download & Install Latest one will solve it or post Buscheck Logs if not. BR, ZUBER |
11-19-2012, 15:10 | #6 (permalink) | |
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | check this out from gbluez............... Quote:
Ok, i will download latest release and post result... | |
11-20-2012, 04:12 | #7 (permalink) |
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | MXKey Can't Repair WD Timer Enabled (Repair SD) mobileEx_setup_v3.5_rev2.4(20121026).exe Code: MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C0871221 Using device: HTI, FW ver: 00.50, SN: 01005DAE Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012) Phone type: RM-437 (Nokia E63) SW version: V ICPR71_09w47.11 14-02-11 RM-437 (c) Nokia ApeCoreSw: 510.21.010 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 13300112699900521DC816EDA75DEE79F29D6A78 ASIC MODE ID: 00 ROOT KEY HASH: C70CB07324056BC66A824347F40DB2D5 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6 PUBLIC ID: 13300112699900521DC816EDA75DEE79F29D6A78 PRIVATE ID: 00544CB875C1C044418E5F7684B858B9575EA191 E-FUSE: 3862B6E4 SEC ROM CRC: 3E691FF8 Restarting phone ... Updating SUPERDONGLE_KEY ...error 0x3 Authenticating to SUPERDONGLE ... Wrong response to SD verify request |
11-22-2012, 04:55 | #12 (permalink) |
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | is there any related with HW? selftest pass... WD only can be repaired with SD Repair, super SD is for auth PM. Well, i dunno why im facing this problem. Maybe corrupted RPL or PM, dunno... |
11-22-2012, 05:35 | #13 (permalink) |
Freak Poster Join Date: Jan 2011
Member: 1488757 Status: Offline Thanks Meter: 98 | Phone Type: RM-827 (Nokia 110) SW Version: V 03.26 27-06-12 RM-827 (c) Nokia Imei plain: 35365605695862-4 Product Code: 059N3R1 Battery voltage: 2886 mV, current: 213 mA Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35365605695862 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000004000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Nokia C2-00 USB Phonet detached. SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. |
