11-27-2011, 19:06 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: saudiarabia/india
Member: 185396 Status: Offline Sonork: 100.1618832 Thanks Meter: 33 | nokia E7 flashing error Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: nmwcdnsuc, ver: 7.1.32.70 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Processing MCU file: RM-626_025.007_79.92_prd.core.fpsx [BB5,XSR 1.6] size: 124.20 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 845FDD4 CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 10800105E83A57407272305FEC757F7A78378982 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0068 - 0000 0031 [ST LH28F160BG] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0068 - 0000 0031 [ST LH28F160BG] type: FLASH,MuxOneNAND, asic:CMT Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 845FDD4 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x0 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x0 bytes). Reading CMT HWC (0x0 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Invalid Certificate Data, backup will not be created. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning.... Partitioning complete Erase size: 508.06 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [00DC0000-0FC7FFFF] CMT FLASH,MuxOneNAND area [2E100000-3E5FFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 8EABFDA6 [RAP Certificate v1 248] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 24.719 s Processing PPM file: RM-626_025.007_26.01_Hebrew_QW_79.92_prd.rofs2.fpsx [BB5,XSR 1.6] size: 48.11 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 67.50 MB CMT FLASH,MuxOneNAND area [0A580000-0E8FFFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 9.032 s Processing PPM file: RM-626_025.007_00.01_79.92_prd.rofs3.fpsx [BB5,XSR 1.6] size: 4.80 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 19.50 MB CMT FLASH,MuxOneNAND area [0E900000-0FC7FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.093 s Processing CNT file: RM626_APE_ONLY_ENO_11w15_v0.033.fpsx [BB5,XSR 1.6] size: 4.15 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 5 MB CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 1.343 s Processing CNT file: RM-626_025.007_U01.01_79.92.uda.fpsx [BB5,XSR 1.6] size: 133.72 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 484.50 MB CMT FLASH,MuxOneNAND area [0FC80000-2E0FFFFF] Flash programming ... Error while programming [00] at 0x0FC80000, Result: 0000 |
11-27-2011, 19:09 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | possible error on usb: battery dried out while flashing. make sure battery is fully charged. or use fbus, better. BR |
The Following User Says Thank You to gbluez For This Useful Post: |
12-05-2011, 15:17 | #3 (permalink) |
Freak Poster Join Date: Apr 2009
Member: 1014821 Status: Offline Sonork: 100.1603462 Thanks Meter: 66 | have same prob how to solve MXKEY [FT SCR2000 0], SN: C0810xxx Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.67 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Processing MCU file: RM-626_025.007_79.92_prd.core.fpsx [BB5,XSR 1.6] size: 124.20 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 153FDAA5 CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1] CMT EM0 ID: 00001040 CMT EM1 ID: 00001030 CMT PUBLIC ID: 2650020D5CD60344C759FBF5130826F4A1613E15 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0068 - 0000 0031 [ST LH28F160BG] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0068 - 0000 0031 [ST LH28F160BG] type: FLASH,MuxOneNAND, asic:CMT Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 153FDAA5 FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning.... Partitioning complete Erase size: 508.06 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [00DC0000-0FC7FFFF] CMT FLASH,MuxOneNAND area [2E100000-3E5FFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: 8EABFDA6 [RAP Certificate v1 248] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 21.563 s Processing PPM file: RM-626_025.007_08.01_French_AZ_79.92_prd.rofs2.fpsx [BB5,XSR 1.6] size: 45.81 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 67.50 MB CMT FLASH,MuxOneNAND area [0A580000-0E8FFFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 7.828 s Processing PPM file: RM-626_025.007_C21.01_Skip_Cherry_79.92_prd.rofs3.fps x [BB5,XSR 1.6] size: 9.80 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 19.50 MB CMT FLASH,MuxOneNAND area [0E900000-0FC7FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.094 s Processing CNT file: RM626_APE_ONLY_ENO_11w15_v0.033.fpsx [BB5,XSR 1.6] size: 4.15 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 5 MB CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 0.782 s Processing CNT file: RM-626_025.007_U01.01_79.92.uda.fpsx [BB5,XSR 1.6] size: 133.72 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 484.50 MB CMT FLASH,MuxOneNAND area [0FC80000-2E0FFFFF] Flash programming ... Error while programming [00] at 0x0FC80000, Result: 0000 |
09-27-2012, 19:27 | #6 (permalink) | |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | Quote:
try this step 1.battery fully charge 2.untick safe and fast flash 3.use only 3 files like mcu ppm cnt still same use phoenix with dead usb flash otherwise use fbus follow option 2 and 3 That's All. BR. Arsalan gsm2000 | |
09-27-2012, 19:36 | #7 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Back to back 3 Posts replying to old ones, Now it's more older than before, You're 1 Year back. | |
