nokia e71 blank screen problem hi i have problem with nokia e71 when i start camera only blank screen comes up i saw this thread but does not help http://forum.gsmhosting.com/vbb/f299...lem-pm-859159/ any other suggestions ? |
try to flash with eno firmware and then flash again with complete mcu,ppm and cnt if problem still same post the logs here so anybody can help you |
what is "eno" firmware? |
ENO software handles all basic functions inside the device. It is required to be flashed into the device when Combo Memory is Changed due to by some wrong operations like; Downgrade Phone wrongly, Flash with wrong Firmware, Erase Phone with wrong file or Phone is on White or Blank display. After flash with ENO Firmware your phone will be normalized and then you simply flash again with correct firmware package, select any product code according to your choice and press Flash button. |
this eno for e71 rm-346 4shared.com - online file sharing and storage - download RM346_ENO_0741.10_08wk42.a34.fpsx |
haven't used before can you tell me where to load it ? |
just put this eno flash in ape v and click flash |
reading boot config 1 failed! Flashing terminated with error(s) in 11.837 s |
1st you make bus check and then scan save simlock..put the eno firmware as mcu and then flash after succesfully flash the eno firmware flash again with complete flash mcu,ppm,and cnt post result |
when i try to flash or bus check i get this error above |
flash phone with ded usb |
what should we do ? If dont have back up than write eno firmware imei no is not gone sorry for my english |
http://forum.gsmhosting.com/vbb/f550...y-here-726058/ Please visit the thread more oftenly. BR |
no bro just flash eno sw imei will not going |
i have e 71 after flash its going in blank screen befor flash it work fine but slow than i flash it |
