Old 01-05-2011, 20:12   #1 (permalink)
Member: 140922
Thanks Meter: 6
nokia E72 SUPERDONGLE_KEY invalid!
hi to all i have e72 can not read with rj45 cabel and with usb ok i read this data
Phone Type: RM-530 (Nokia E72-1)
SW Version: V ICPR82_10w22.6 23-11-10 RM-530 (c) Nokia
Imei plain: 355*************
Product Code: 0599651
ApeCoreSw: 053.001
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
- WD timer enabled, phone will reboot itself after 3 min.
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 355************
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
when i want to repair sd with usb cabel he said
Interface not supported for current operation.
any body can tell me salutation
Old 01-05-2011, 20:25   #2 (permalink)
shahabuddin's Avatar
Member: 407782
Sonork: 100.1586820
Thanks Meter: 1,052
u must need to use interface and rj45 for this operation
and better to use ATF.
gudluck
Old 01-05-2011, 21:25   #3 (permalink)
n2roy's Avatar
Member: 1175794
Thanks Meter: 186
if ur rj cable not working.. then try to do manually with pinouts..
The Following User Says Thank You to n2roy For This Useful Post:
Old 01-05-2011, 23:40   #4 (permalink)
mogrem.soft's Avatar
Member: 914426
Sonork: 01017474627
Thanks Meter: 235
Thnks bro, useful post
Old 01-06-2011, 09:38   #5 (permalink)
Member: 140922
Thanks Meter: 6
i have solved the rj45 cabel problem but now mxkey he said
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9019(20-11-2010), 1.0.0.(20-11-2010)
Product: V ICPR82_10w22.6 23-11-10 RM-530 (c) Nokia
ApeCoreSw: 053.001
SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPU ver: 1.1]
ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695
ROM ID: 3E273BF637BE26FA
Custom loader not available for this ID !
Old 01-06-2011, 09:48   #6 (permalink)
Member: 583492
Thanks Meter: 125
just do repair sd in mx-key
Old 01-06-2011, 11:12   #7 (permalink)
smorbe's Avatar
Member: 132735
Thanks Meter: 88
not supported sl3 phone.
Page generated in 0.20575 seconds with 9 queries
