Member: 671937
Sonork: 100.1613181 Thanks Meter: 94 | Nokia E90 power on & only vibrate..... Nokia E90 RA-6 power on & only vibrate......keypad light on but no display & do nothing else........ BUSCHECK Quote: MXKEY [FT SCR2000 0], SN: C0849DC2
Using device: HTI, FW ver: 00.50, SN: 0000407F
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14203(16-07-2012)
APE Data :
SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2]
ASIC MODE ID: 00
PUBLIC ID: B65B533805ED8919D511DD61026D05B357E5D84F
ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1B40010130850058E04434A479D272BEF58DE6B5
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: A8C1D6713E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
eBB5ProtocolType: OLD
Storage0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
CMT PAPUBKEYS HASH: CCE4D6D72835B461FE6259BFF52C5566B3FAB11C
TransmissionMode: DDR&TX2
SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00
Supported Ids: 24200703, 24200704, 24200705, 24200706
Storage0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,NAND, asic:APE
Suggested algorithm: OMAP2420 UNISTORE-II-1.5.1 ALG
Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248
APE PAPUBKEYS HASH: CCE4D6D72835B461FE6259BFF52C5566B3FAB11C
Selected firmware certificate matched.
Original Imei: 35365901535638
Original Product code: 0544406
Bluetooth ID: 001A89C53C10
WLAN ID: 001A89F302D0
SIMLOCK PA identifier:
[0] PA_SL
Phone type: RA-6 (Nokia E90)
SW version: V 300.41.50 19-08-08 RA-6 (c) Nokia
Imei plain: 35365901535638-5
Battery voltage: 4130 mV, current: 139 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 353659015356385
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN | SELFTEST Quote: Phone Type: RA-6
ID Test name Startup Result
46 UEM_CBUS_IF Y PASSED(00)
3 EAR_DATA_LOOP Y PASSED(00)
12 SIM_CLK_LOOP Y PASSED(00)
13 SIM_IO_CTRL_LOOP Y PASSED(00)
33 SIM_LOCK N PASSED(00)
93 SECURITY N PASSED(00)
90 PWR_KEY N !NOT EXECUTED(03)
2 CURRENT_CONS N !NOT EXECUTED(03)
20 BACKUP_BATT N !NOT EXECUTED(03)
58 CMT_APE_WAKEUP N !NOT EXECUTED(03)
56 SLEEPCLK_FREQ N !NOT EXECUTED(03)
42 RADIO N !NOT EXECUTED(03)
96 HOOKINT N !NOT EXECUTED(03)
101 BTEMP N !NOT EXECUTED(03)
8 MBUS_RX_TX_LOOP Y !NO SIGNAL(06)
108 EXT_DEVICE N !NOT EXECUTED(03)
86 CDSP_RF_BB_IF N !NOT EXECUTED(03)
83 CDSP_RF_SUPPLY N !NOT EXECUTED(03)
85 CDSP_TX_IQ N !NOT EXECUTED(03)
74 CDSP_TXC_DATA N !NOT EXECUTED(03)
82 CDSP_PWR_DETECTOR_BIAS N !NOT EXECUTED(03)
79 CDSP_RX_PLL_PHASE_LOCK N !NOT EXECUTED(03)
80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03)
75 CDSP_WCDMA_TX_POWER N !NOT EXECUTED(03)
81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03)
77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03)
Phone Type: RA-6
46 UEM_CBUS_IF Y passed
3 EAR_DATA_LOOP Y passed
12 SIM_CLK_LOOP Y passed
13 SIM_IO_CTRL_LOOP Y passed
33 SIM_LOCK N passed
93 SECURITY N passed
90 PWR_KEY N passed
2 CURRENT_CONS N passed
20 BACKUP_BATT N passed
58 CMT_APE_WAKEUP N !no signal
56 SLEEPCLK_FREQ N passed
42 RADIO N passed
96 HOOKINT N passed
101 BTEMP N passed
8 MBUS_RX_TX_LOOP Y !no signal
108 EXT_DEVICE N passed
86 CDSP_RF_BB_IF N passed
83 CDSP_RF_SUPPLY N passed
85 CDSP_TX_IQ N passed
74 CDSP_TXC_DATA N passed
82 CDSP_PWR_DETECTOR_BIAS N passed
79 CDSP_RX_PLL_PHASE_LOCK N passed
80 CDSP_TX_PLL_PHASE_LOCK N !not ready
75 CDSP_WCDMA_TX_POWER N !not ready
81 CDSP_RX_IQ_LOOP_BACK N !not ready
77 CDSP_GSM_TX_POWER N !not ready | is it software or hardware problem.........pcb fresh.......also changed lcd.......what to do now......... |
