06-24-2013, 12:53 | #1 (permalink) |
No Life Poster Join Date: Aug 2006 Location: gsmchaudhrayarshad Age: 43
Member: 328688 Status: Offline Thanks Meter: 2,282 | nokia e90 stuck on nokia Version from phone: 400.41.03 Version from file: 400.34.93 xxxxxxxxxMXKEY [FT SCR2000 0], SN: Cxxxxx Using device: HTI, FW ver: 00.50, SN: xxxxxxxxxxxxx Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) RPL backup already exist (C:\mobileEx\3.5\data\backup\RPL\BB5_3536590148221 1_BACK.rpl). APE Data : SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2] ASIC MODE ID: 00 PUBLIC ID: 1D892C265927D835EC8D62DE57E868AB088448A6 ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 16200103518600582444E94D9FD193BE00A8E35E ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: A8C1D6713E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 eBB5ProtocolType: OLD Storage0: 0001 0043 - 0000 6A21 [AMD ] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520 Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105 CMT PAPUBKEYS HASH: CCE4D6D72835B461FE6259BFF52C5566B3FAB11C TransmissionMode: DDR&TX2 SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00 Supported Ids: 24200703, 24200704, 24200705, 24200706 Storage0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,NAND, asic:APE Suggested algorithm: OMAP2420 UNISTORE-II-1.5.1 ALG Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248 Supported Ids: 24200703, 24200704, 24200705, 24200706 APE PAPUBKEYS is blank/erased. Processing MCU file: ra6_400.34.93_prd.c00 [BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 55.97 MB Supported Ids: 0003192101001003, 000C192101001003, 0003192101001103, 000C192101001103, 0003192101001203, 000C192101001203, 0003192101002003, 000C192101002003, 4003192101001203, 400C192101001203, 4003192101002003, 400C192101002003, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103 Supported Ids: 24200705 Storing certificate [NPC, HWC, CCC, R&D]; @...OK Partitioning ...OK Erase size: 123.08 MB CMT FLASH,NOR area [00080000-007C26C5] CMT FLASH,NOR area [00000000-0005FFFF] CMT FLASH,NOR area [00880000-00FDFFFF] erased in 26.053 s Prog.status for Asic CMT ... NOR: OK NAND: OK Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: CCE4D6D7 [RAP Certificate v.1.0] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent APE X-LOADER block sent APE KEYS block sent APE PRIMAPP block sent APE X-LOADER block sent APE KEYS block sent APE PRIMAPP block sent APE SOS+XZIP block sent APE PASUBTOC block sent Selecting first APE PAPUB block with matching RootKey. APE PAPUBKEYS: CCE4D6D7 [APE Certificate v.1.0] sent APE SOS+UPDAPP block sent APE SOS*CORE block sent APE SOS+ROFS block sent Prog.status for Asic APE ... NOR: OK NAND: OK Programming completed in 4 min 9.961 s Processing PPM file: ra6_400.34.93_prd.v16 [BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG] size: 15.89 MB Supported Ids: 4003192101002003, 400C192101002003, 400C192101011103, 400C192101021103, 400C192101031103 Supported Ids: 24200705 Partitioning ...OK Erase size: 33.25 MB erased in 0.100 s Prog.status for Asic APE ... NOR: OK NAND: OK Flash programming ... APE SOS+ROFX block sent Prog.status for Asic APE ... NOR: OK NAND: OK Programming completed in 1 min 10.767 s Total time for flashing process(boot+erase+write) was 5 min 53.846 s After Flash Processing ... Phone type: RA-6 (Nokia E90) SW version: V 400.41.03 09-02-09 RA-6 (c) Nokia Imei plain: 35365901482211-4 Product code: 0552396 Battery voltage: 3741 mV, current: 301 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid SECURITY_TEST passed Imei net: 353659014822114 Version: SIMLOCK SERVER Provider: Vodafone Ltd. , Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2341500000000000 PROFILE_BITS: 0100000000000000 BLOCK1: 1=OPEN BLOCK2: 1=OPEN FULL FACTORY... Failed! (0103) Please Set mode to "TEST MODE" and retry! Completed in 3.761 s FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 3.221 s Formating FS: ... Completed in 0.660 s |
06-24-2013, 13:33 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. You have already FS with Software, need Manually now to work, So try to Hard Reset with (* 3 Send Power) Buttons, If not solve, then Flash it with ENO File. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
