Old 10-08-2012, 08:28   #1 (permalink)
Member: 747386
Thanks Meter: 30
nokia n 85 rm 333 contect service
nokia n 85 rm 333 contect service please need your help
Old 10-08-2012, 08:31   #2 (permalink)
iftikhar_246's Avatar
Member: 384949
Sonork: 1611265
Thanks Meter: 365
where is log post heer log
Old 10-08-2012, 09:14   #3 (permalink)
Member: 747386
Thanks Meter: 30
logs is here
MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C0840F2D
Using device: HTI, FW ver: 00.50, SN: 010016CF
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 14100016EA9F01589C83EE98623FBF979BEE47CF
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.8.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.8.0 revision: 2.0 size: 0x8B49D
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: B5385A493D2188678E1FD88DA506480F874E2949
Original Imei: Empty
Original Product code: Empty
NPC_DATA invalid !
SIMLOCK PA identifier:
[0] PA_SL2
Old 10-08-2012, 09:40   #4 (permalink)
..:: Devil_king ::..'s Avatar
Member: 696623
Sonork: 100.1601050
Thanks Meter: 498
NPC_DATA invalid !
bro your npc (imei) goes to nill...
first restore rpl backup (if you have)
otherwise need to buy new one ......
Old 10-08-2012, 10:06   #5 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,263
Originally Posted by geovicky View Post
logs is here
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
NPC_DATA invalid !
[0] PA_SL2
Flash it with Latest Firmware of Phone,
Use FBus cable, some times Phone recovers if shows all Sections Empty,
Post Logs of Flash operations.
BR,
ZUBER
Old 10-10-2012, 11:05   #6 (permalink)
Member: 747386
Thanks Meter: 30
BR,
ZUBER
hrer is flash logs i have backup rpl and pm
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
Processing MCU file: RM-333_31.002_prd.core.fpsx
[BB5,XSR 1.5] size: 101.19 MB
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 155.31 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-09F7FFFF]
Formating partition ...
Prog.status for Asic CMT ...
NAND: OK
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: B5385A49 [RAP Certificate 104 v1] sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
NAND: OK
Programming completed in 3 min 28.109 s
Processing PPM file: RM-333_31.002_008_prd.language.fpsx
[BB5,XSR 1.5] size: 11.98 MB
Erase size: 24.37 MB
CMT FLASH,MuxOneNAND area [07D20000-0957FFFF]
NAND: OK
CMT SOS+ROFS2 block sent
NAND: OK
Programming completed in 25.719 s
Processing PPM file: RM-333_31.002_53.1_prd.customer.fpsx
[BB5,XSR 1.5] size: 9.01 KB
Erase size: 10 MB
CMT FLASH,MuxOneNAND area [09580000-09F7FFFF]
NAND: OK
CMT SOS+ROFS3 block sent
NAND: OK
Programming completed in 0.266 s
Processing CNT file: rm333_ENO_x_2009wk20v0.A014.fpsx
[BB5,XSR 1.5] size: 2.59 MB
Erase size: 4 MB
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
NAND: OK
CMT SOS*ENO block sent
NAND: OK
Programming completed in 5.609 s
Processing CNT file: RM-333_31.002_001_000_U005.uda.fpsx
[BB5,XSR 1.5] size: 9.81 MB
Erase size: 87.62 MB
CMT FLASH,MuxOneNAND area [09F80000-0F71FFFF]
NAND: OK
NAND: OK
Programming completed in 21.750 s
Total time for flashing process(boot+erase+write) was 4 min 51.172 s
Phone type: RM-333 (Nokia N85)
SW version: V ICPR72_09w18.6 15-10-09 RM-333 (c) Nokia
ApeCoreSw: 31.002
Imei plain: 12345610654321-?
Product code: 0560502
Battery voltage: 4574 mV, current: 150 mA
Language Pack:
- not available.
SLPA ver[3]: PA_SL2/PA_SL3 (15 digit NCK)
SIMLOCK invalid!
SIMLOCK_TEST passed
SECURITY_TEST failed!
Old 10-10-2012, 11:08   #7 (permalink)
Member: 1413534
Sonork: 100.1604889
Thanks Meter: 5
try to repair sd with mx or another tool
Old 10-10-2012, 11:24   #8 (permalink)
Member: 747386
Thanks Meter: 30
ApeCoreSw: 31.002
Battery voltage: 4393 mV, current: 155 mA
Language Pack:
- not available.
Imei plain is invalid !!!
SIMLOCK_DATA corrupted!
Old 10-10-2012, 11:27   #9 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,263
Bro.
Your Backup RPL Corrupted,
Needs to buy Factory RPL is only option.
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Page generated in 0.32304 seconds with 7 queries
