08-22-2010, 15:45 | #1 (permalink) |
Freak Poster Join Date: Jul 2009 Location: nokia n82 Age: 38
Member: 1070908 Status: Offline Sonork: bogha Thanks Meter: 29 | nokia n72 sim card not valid i have n72 not charging i changed tahvo its now ok charging but. now when sim card lnserted (((sim card not valid))) this is mx key log Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) APE Data : SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: 5AE417877CB09535BA07B2E5B6BB70BBF2DF7AD8 ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 RAP Data : SYSTEM ASIC ID: 000000010000022600010006000C192101012200 [RAP3G ver: 3.01] EM0 ID: 00000232 EM1 ID: 00000341 PUBLIC ID: 0560011442825151CF510B5AA8752A9F1E0D5A98 ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported RAP Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 0001 0002 - 0000 0111 [AMD NA] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D TransmissionMode: DDR&TX2 SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 FlashID0: 00EC 0036 - 00A5 00C0 [Samsung KAL00R00EM-DGXX,512 Mbits] type: NAND,APE ALG [35]: OMAP1610 GBBM-1.8.1 ALG ExtBUSC: 0002 0000 0006 0000 0000 0000 0000 0000 Algorithm: h3_sam_nand_gbbm.fg [OMAP1610 GBBM-1.8.1 ALG] version: 1.33.0 revision: 0.0 size: 0xA908 Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708 APE PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D Original Imei: 35972600992841 Original Product code: 0530869 Bluetooth ID: 00174BBCF3C2 Phone Type: RM-180 (Nokia N72) SW Version: V 05wk07v48.1 28-08-07 RM-180 (c) Nokia. Imei plain: 35972600992841-4 Product Code: 0531463 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed Imei net: 359726009928414 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED i just tried to unlock and this is what happend SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V 05wk07v48.1 28-08-07 RM-180 (c) Nokia. ApeCoreSw: V 5.0741.4.0.1 08-10-07 RM-180 (C)Nokia ERROR: Missing SD BLOCK or PM corrupted ! Scanning local SX4 Card ... No SX4 Card found. SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 217.139.62.130 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Authenticating using security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 217.139.62.130 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Retrying ... SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1 Authenticating using [MX] security server ... Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 217.139.62.130 Bad phones ack, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request thanx in advance |
08-22-2010, 16:08 | #2 (permalink) |
Member: 1070908 Status: Offline Sonork: bogha Thanks Meter: 29 | i did that what happenned Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 1 (4 bytes) Warning: failed to write 1 - 2 (86 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 5 (4 bytes) Warning: failed to write 1 - 6 (86 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (86 bytes) Warning: failed to write 1 - 15 (4 bytes) Warning: failed to write 1 - 16 (86 bytes) Warning: failed to write 1 - 18 (86 bytes) Warning: failed to write 1 - 20 (86 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 25 (16 bytes) Warning: failed to write 1 - 29 (6 bytes) Section: 2 - Key: 0, size 340 bytes written. Section: 4 - Key: 0, size 1 bytes written. - Key: 1, size 16 bytes written. - Key: 2, size 44 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 9, size 5 bytes written. Section: 8 - Key: 0, size 12 bytes written. - Key: 1, size 12 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 8 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 2 bytes written. - Key: 8, size 2 bytes written. - Key: 9, size 2 bytes written. - Key: 10, size 2 bytes written. - Key: 11, size 2 bytes written. - Key: 12, size 1 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 1 bytes written. - Key: 15, size 1 bytes written. - Key: 16, size 1 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 1 bytes written. - Key: 19, size 2 bytes written. - Key: 20, size 2 bytes written. - Key: 21, size 1 bytes written. - Key: 22, size 1 bytes written. - Key: 23, size 4 bytes written. - Key: 24, size 4 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 1 bytes written. - Key: 30, size 1 bytes written. - Key: 31, size 1 bytes written. - Key: 32, size 1 bytes written. - Key: 33, size 1 bytes written. - Key: 34, size 1 bytes written. - Key: 35, size 1 bytes written. - Key: 36, size 1 bytes written. - Key: 37, size 1 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 4 bytes written. - Key: 45, size 4 bytes written. - Key: 46, size 1 bytes written. - Key: 47, size 16 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 20 bytes written. - Key: 51, size 10 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 20 bytes written. - Key: 54, size 10 bytes written. - Key: 55, size 1 bytes written. - Key: 56, size 1 bytes written. - Key: 57, size 1 bytes written. - Key: 58, size 1 bytes written. - Key: 59, size 1 bytes written. - Key: 60, size 1 bytes written. - Key: 61, size 1 bytes written. - Key: 62, size 1 bytes written. - Key: 63, size 1 bytes written. - Key: 64, size 1 bytes written. - Key: 65, size 1 bytes written. - Key: 66, size 2 bytes written. - Key: 67, size 2 bytes written. - Key: 68, size 2 bytes written. - Key: 69, size 2 bytes written. - Key: 70, size 2 bytes written. - Key: 71, size 2 bytes written. - Key: 72, size 2 bytes written. - Key: 73, size 2 bytes written. - Key: 74, size 2 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 78, size 2 bytes written. - Key: 79, size 2 bytes written. - Key: 80, size 2 bytes written. - Key: 81, size 2 bytes written. - Key: 82, size 2 bytes written. - Key: 83, size 2 bytes written. - Key: 84, size 2 bytes written. - Key: 85, size 2 bytes written. - Key: 86, size 2 bytes written. - Key: 87, size 2 bytes written. - Key: 88, size 2 bytes written. - Key: 89, size 2 bytes written. - Key: 90, size 2 bytes written. - Key: 91, size 2 bytes written. - Key: 92, size 2 bytes written. - Key: 93, size 2 bytes written. - Key: 94, size 2 bytes written. - Key: 95, size 2 bytes written. - Key: 96, size 2 bytes written. - Key: 97, size 2 bytes written. - Key: 98, size 2 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 2 bytes written. - Key: 101, size 2 bytes written. - Key: 102, size 2 bytes written. - Key: 103, size 2 bytes written. - Key: 104, size 2 bytes written. - Key: 105, size 2 bytes written. - Key: 106, size 2 bytes written. - Key: 107, size 2 bytes written. - Key: 108, size 4 bytes written. - Key: 109, size 4 bytes written. - Key: 110, size 1 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 4 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 16 bytes written. - Key: 116, size 4 bytes written. - Key: 117, size 2 bytes written. - Key: 118, size 2 bytes written. - Key: 119, size 857 bytes written. Section: 17 - Key: 0, size 4 bytes written. Section: 25 - Key: 0, size 64 bytes written. Section: 26 - Key: 0, size 16 bytes written. - Key: 1, size 32 bytes written. - Key: 2, size 68 bytes written. - Key: 3, size 6 bytes written. Section: 27 - Key: 0, size 15 bytes written. Section: 29 - Key: 0, size 6 bytes written. Section: 44 - Key: 0, size 1 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 88 - Key: 0, size 36 bytes written. Section: 95 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. Section: 96 - Key: 0, size 24 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 79 bytes written. - Key: 2, size 79 bytes written. - Key: 3, size 70 bytes written. - Key: 25, size 132 bytes written. Section: 117 - Key: 5, size 10 bytes written. - Key: 6, size 8 bytes written. - Key: 8, size 42 bytes written. Section: 118 - Key: 0, size 1 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. Section: 212 - Key: 0, size 2 bytes written. Section: 217 - Key: 0, size 32 bytes written. Section: 239 - Key: 0, size 2 bytes written. - Key: 1, size 1759 bytes written. Section: 248 - Key: 0, size 120 bytes written. Section: 307 - Key: 0, size 1 bytes written. Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Completed in 13.110 s then update sp lock Imei net: 359726009928414 Version: SIMLOCK SERVER VERSION 58 Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: FFFFFFFFFFFFFFFF BLOCK 1: 1=CORRUPTED Backup already exist. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Product: V 05wk07v48.1 28-08-07 RM-180 (c) Nokia. ApeCoreSw: V 5.0741.4.0.1 08-10-07 RM-180 (C)Nokia SYSTEM ASIC ID: 000000010000022600010006000C192101012200 [RAP3G ver: 3.01] ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FCEA7B19D Sending SecondaryBoot [rap3gv2_2nd.fg](0x3D00 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x0 bytes) ...OK but still sim card not valid |
08-22-2010, 16:16 | #3 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: \/\/ 0RLD \/\/ IDE
Member: 238374 Status: Offline Sonork: 100.1597005 Thanks Meter: 1,087 | Quote:
1.repair simloks 2.repair sd 3.super sd auth 4.write 1 and 309 data | |
The Following User Says Thank You to .::Dr.Gsm::. For This Useful Post: |
08-22-2010, 16:26 | #4 (permalink) |
Member: 1070908 Status: Offline Sonork: bogha Thanks Meter: 29 | really thanx thanx thanx now its working just Make SimLock RPL and done |
The Following User Says Thank You to boghastar For This Useful Post: |
09-05-2010, 15:54 | #7 (permalink) |
Member: 1070908 Status: Offline Sonork: bogha Thanks Meter: 29 | |
09-05-2010, 21:38 | #8 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Thats not a regional forum use default English language for better assistance. Moderator please closed this thread. No Regards, Vijendra Saini. |
