Old 06-28-2010, 10:48   #1 (permalink)
Member: 90701
Thanks Meter: 134
Nokia N73 phone start up failed
Hi, got a nokia N73 it was sd currupted and Sec test failed. After I fixed sd this became ok, but sec test fail is still active. I have wrote the pm by sd authorization but still sec test failed and now phone became start up failed. Any solution, please help.
Thanks
LogS:
Phone Type: RM-133 (Nokia N73)
SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia.
Imei plain: 352916XXXXXXXXXX
Product Code: 0539295
ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133
ApeVariant: V 4.0839.42.2.1-08 27-09-2008 RM-133
Language Pack:
English,02 Uk
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 352916XXXXXXXXX
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 06-28-2010, 10:52   #2 (permalink)
Member: 1066949
Sonork: 100.1593801
Thanks Meter: 44
Smile so simple bro...1
simple go 2 pm then click super sd then load from then select pm file and check 1 and 309 block and then write and ur prblm is solve
The Following User Says Thank You to alonefriend07 For This Useful Post:
Old 06-28-2010, 10:53   #3 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Thanks Meter: 12,469
Brother i need ur rpl(full)backup
just post ur rpl file
Old 06-28-2010, 11:15   #4 (permalink)
Member: 90701
Thanks Meter: 134
Hi, here is the backup for this N73.
Old 06-28-2010, 11:22   #5 (permalink)
Member: 90701
Thanks Meter: 134
Hi, Thnks for your reply. Yes i have done the exact way but same thing.
Thnks
Old 06-28-2010, 11:49   #6 (permalink)
Member: 351924
Originally Posted by unicom View Post
hi, here is the backup for this n73.
just write this rpl then check security test-----------same failed?
Write again 1 and 309 pm via sx4 auth
not solved upload full pm with 308 again then check it
some time 308 over writing time sl or imei going to damaged restore this rpl
post result
u need fast help just add me msn i will clear this via teamvier
Old 06-28-2010, 11:50   #7 (permalink)
Member: 1334068
Thanks Meter: 6
  • Nokia N73 phone start up failed
Old 06-28-2010, 12:09   #8 (permalink)
Member: 1322811
Thanks Meter: 46
first step open mxky goo servise/ pm/load pm from file/super sd auth/write pm
pm juste for reper 1/309
Old 06-28-2010, 12:27   #9 (permalink)
sudsud's Avatar
Member: 420318
Sonork: 100.1661057
Thanks Meter: 65
check here bro : N73_without_NPC_DATA__made_by_MxKey.rar
try first to do : recover certificate
then try to write the above rpl to ur phone
Old 06-28-2010, 13:35   #10 (permalink)
..::SH@RIF®™::..'s Avatar
Member: 929782
Sonork: 100.1641069
Thanks Meter: 617
just. write pm file.
problem solve 100%
tested by me.............
Old 09-01-2010, 07:55   #11 (permalink)
Member: 1066949
Sonork: 100.1593801
Thanks Meter: 44
If u write pm so still ur set shows securty test fail ur prbl still same so u need to follwing these steps
1:rpl backup
2:reset npc
3:write npc file
4:again restore backup
5:then again write pm if ur securty erea corrupt
6:enjoy
Page generated in 0.20119 seconds with 11 queries
