Old 02-27-2012, 11:34   #1 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
Nokia N73 Rm-132 Contact Retailer
I need clone Rpl and Modifed Pm for Nokia N73 its Rm 132 type
Problem - Conact Retailer
Phone type: RM-132 (Nokia N73)
SW version: V 05wk47v62 05-12-08 RM-132 (c) Nokia.
Imei plain: 35897401906500-6
Product code: 0545141
Battery voltage: 4925 mV, current: 81 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 358974019065006
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
I do Every thing pm auto.1,309 and also full erase
I think there is problem with product code and cert
BB5 Cert Validation
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
TransmissionMode: DDR&TX2
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
Storage0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: FLASH,NAND, asic:APE
Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0
APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
Reading CMT NPC (0x168 bytes).
Original Product Code: 0554355
Reading CMT VARIANT (0xB8 bytes).
Product Code:
Product Code missmatch !
Reading CMT CCC (0x0 bytes).
Reading CMT HWC (0x0 bytes).
CCC And HWC Data Empty
i try online Recover Cert Option but Always failed coz Its Rm-132 data not availeble for this phone in server
Here is logs
APE Data :
SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0]
ASIC MODE ID: 00
PUBLIC ID: 8064D86D3B72C15FC3ED8F2F0781814568148181
ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000
ROM ID: 1DFD66132C872FD4
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006
010C192101013000
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1220000D987A0254F1E33BBEDEEA87F548A87EFA
ASIC MODE ID: 00
ROOT KEY HASH:
BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: FLASH,NOR, asic:CMT
Begin Certificate Request ...
[InternalErrorFault] CERT [0554355] data not available for this phone (case id=0xCE01)
may its need to repair manualy with clone Rpl
Plz help
Thanks In advance
Old 02-27-2012, 11:50   #2 (permalink)
deepakkumar39's Avatar
Member: 1464245
Thanks Meter: 176
atf ya infinity best tool repair 100% ok
Old 02-27-2012, 11:55   #3 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
dont mind its mx-key setion and i need solution for mx-key
i have just mx-key box
Old 02-27-2012, 11:55   #4 (permalink)
akhtarmughal's Avatar
Member: 617073
Sonork: 100.1611349
Thanks Meter: 316
bro write RPL with out NPC data write complete PM file with sx4 or unlock it
your problem will bi solved
hit thanks button if you like my post
Old 02-27-2012, 12:00   #5 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
I dont have rpl without npc data Its Rm-132
Old 02-27-2012, 12:37   #6 (permalink)
specta's Avatar
Member: 1149800
Thanks Meter: 211
i dont have rpl without npc data for rm-132 either.
what if u try these steps:
1. Load File PM for rm-132 from C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb
2. Klik Repair SD
3. click NO if there is a pop menu to write rfbb
4. choose pm 1 & 309
5. click write
based on my experience, u must do it at least five times success write the pm 1 & 309.
good luck bro
br
The Following User Says Thank You to specta For This Useful Post:
Old 02-27-2012, 12:59   #7 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
2. Klik Repair SD
5. click write
good luck bro
br
Alredy try this all
PLZ HELP ME
Old 02-27-2012, 13:07   #8 (permalink)
Gsmbizz's Avatar
Member: 745672
Thanks Meter: 555
2. Klik Repair SD
5. click write
good luck bro
br
Ohhh My *** Problem solved by this
2. Klik Repair SD
5. click write
Thanks you verry verry much bro ..my problem solved
Battery voltage: 4413 mV, current: 237 mA
ApeCoreSw:
V 4.0850.43.1.1
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST passed
Counter: 0/3, 0/10
SW version 4.0839.42.0.1 released for Nokia N73
Page generated in 0.27818 seconds with 10 queries
