Old 09-09-2012, 09:11   #1 (permalink)
Athelcute's Avatar
Member: 885719
Sonork: 100.1604802
Thanks Meter: 412
Nokia N73 Security test field Product Manager plz Give Attention
product manager plz give attention about this
i tried all option but not getting sucess
super dongle auth thn write pm 1 & 309
repair sd thn write pm 1 & 309
recovert cart
finally option is pmm auth using server but server is down
i chk many time like some nokia 3110 security test field only solve using server auth
here is my post about Nokia 3110c success only by pmm auth using server auth
http://forum.gsmhosting.com/vbb/f550...at-do-1503500/
product supporters tried to help me in standalone
not getting success
finally success by pmm auth whn server is working
plz open server
connection server time out
and no product supporters help me no attention and my post delete without notification
here is my thread
http://forum.gsmhosting.com/vbb/f550...close-1531238/
Old 09-09-2012, 12:49   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Friend,
Their is no Personal Issue with you,
Keep control with Fingers on Key Board while posting,
You know better why your Post Deleted, due to irrespective with Product Officials.
(Forget It)
BTW, there is many Reasons for causes of Security Test Failed,
Specially in Nokia N73 due to:
-PM Area(1 & 309)
-Certificates
Mostly not solve by Repair SD writing PM Area(1 & 309) due to Corrupted Certificates.
So there are some Steps to be follow, which you will never fail to Repair Security Test Failed.
Security Test Failed can be solve easily if follow some steps:
Solution 1. Click Repair SD & Load PM from local RFBB when ask will solve. (If PM from local RFBB match)
Solution 2. Load any full saved PM, tick section area 1,309 & click write will solve, if not load another one. (Make habit of saving full PM of working phones)
Solution 3. Note: Only follow this step when something went wrong in phone & can't be solve by Repair SD from above Solutions.
1. first backup full RPL ( go > Imei and Security tab > Imei Rebuild > backup RPL)
2. erase old PM ( go to PM tab > click Erase )
3. Reset npc data ( go to IMEI and Security tab> reset NPC data)( must backup RPL before do this)
4. Erase pm again (go to PM tab > Erase )
5.Write RPL from backup ( go to IMEI and Security tab > IMEI Rebuild > restore IMEI)
6. go PM tab > Super SD Auth & Repair SD > than write good or modified pm ( must need pm 1 & 309)
7. erase PM again.
8. Recover CERT ( go to IMEI and Security tab> IMEI Rebuild > Recover Certificate)
9. apply full Factory Reset.
See Original Post here: http://forum.gsmhosting.com/vbb/f550...ailed-1471251/
BR,
ZUBER
Old 09-09-2012, 13:22   #3 (permalink)
achintya's Avatar
Member: 553420
Sonork: 100.1624012
Thanks Meter: 129
Originally Posted by .::ZUBER::. View Post
Friend,
(Forget It)
-PM Area(1 & 309)
-Certificates
7. erase PM again.
BR,
ZUBER
plz note that recover certificate option of this model not working on mx box.... so plz check and post solution>>> thanks.
Old 09-09-2012, 17:03   #4 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Last some N73 Security Test Failed solved by easiest way of above, so not used Recover Certificate option for many days,
Will check it & try to make it work, if something like that.
Thanks for report.
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Page generated in 0.16948 seconds with 9 queries
