Old 02-29-2012, 18:49   #1 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
nokia n73 SECURITY_TEST : FAILED
plz help
how to solv this major problem
alredy full erase full flash restore imei pm erase write good pm restore varient data but not solv SECURITY_TEST : FAILED
plz guide
here is log
Phone type: RM-133 (Nokia N73)
SW version: V 05wk47v62 05-12-08 RM-133 (c) Nokia.
Imei plain: 35571802712240-5
Product code: 0577467
Battery voltage: 4859 mV, current: 107 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 355718027122405
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
at last i think flash file problem i want this product code [Product code: 0577467] flash file i alredy serch support area but not found plz uplode any one have
Old 02-29-2012, 19:03   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. nothing wrong with flash file & its not flash problem, for security test failed only click repair sd. thats all & have a good day.
Old 02-29-2012, 19:15   #3 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
dear sir i alredy click repiersd but not solv
[QUOTE][MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 6], SN: C086AF0F
Using device: HTI, FW ver: 00.50, SN: 00013A08
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
Using cached productData.
PUBLIC ID: 0FD00107F0187D568231FD494F23D3D3A8261383
PRIVATE ID: 090797AD46EDA7CDCE84D1F668EA5B4403BEE0B3
Updating SUPERDONGLE_KEY ...OK
Authenticating to SUPERDONGLE ...
SUPERDONGLE authorized !
Now you can write RFBB/PM data to the phone.
Done.
Writing PM from Node ...
Section: 1
- Key: 0, size 114 bytes written.
- Key: 2, size 98 bytes written.
- Key: 4, size 110 bytes written.
- Key: 6, size 98 bytes written.
- Key: 8, size 110 bytes written.
- Key: 13, size 98 bytes written.
- Key: 16, size 98 bytes written.
- Key: 18, size 98 bytes written.
- Key: 20, size 98 bytes written.
- Key: 22, size 16 bytes written.
- Key: 23, size 4 bytes written.
- Key: 24, size 84 bytes written.
- Key: 25, size 4 bytes written.
- Key: 26, size 110 bytes written.
- Key: 28, size 98 bytes written.
- Key: 29, size 6 bytes written.
- Key: 31, size 98 bytes written.
- Key: 33, size 36 bytes written.
- Key: 34, size 80 bytes written.
- Key: 44, size 182 bytes written.
Section: 309
- Key: 0, size 4 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
- Key: 22, size 12 bytes written.
Completed in 2.391 s
[QUOTE]
but after scan same problem
Battery voltage: 4922 mV, current: 91 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Old 02-29-2012, 19:25   #4 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
[QUOTE=ranagaurav;8191830]dear sir i alredy click repiersd but not solv
Done.
Section: 1
Section: 309
bro. then write this pm & dont scan phone, remove it>put battery & check.
Old 02-29-2012, 19:34   #5 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
[QUOTE=zuberchowdhry;8191850][QUOTE=ranagaurav;8191830]dear sir i alredy click repiersd but not solv
Done.
Section: 1
Section: 309
same problem not solv after write this pm same no any change
Old 02-29-2012, 20:01   #6 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
bro. now the only solution is:
1. Load File PM for rm-133 from C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb
2. click Repair SD
3. click NO if there is a pop menu to write rfbb
4. choose pm 1 & 309
5. click write
now your problem may be solve.
Old 02-29-2012, 22:04   #7 (permalink)
fatafi's Avatar
Member: 1669858
Sonork: 100.1609806
Thanks Meter: 27
we will waiting the result
maybe good
Old 03-01-2012, 03:14   #8 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
2. click Repair SD
5. click write
yes i do this plz see
Done.
Section: 1
Section: 309
Completed in 2.390 s
but result same
Battery voltage: 4994 mV, current: 103 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Old 03-01-2012, 03:16   #9 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
maybe good
very bad result bro
i alredy done maney handset but i cant do this
Old 03-01-2012, 03:22   #10 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
post self test logs please
Old 03-01-2012, 03:27   #11 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
Old 03-01-2012, 03:48   #12 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
backup RPL, all section
- full erase: (Flash, Advance tab)get addr, don't mark safe erase. ERASE!
- full flash (MCU,PPM,CNT use market drop down), write good PM, restore imei.
- load full pm, press Super SD Auth, press write (skip simlock? YES)
Old 03-01-2012, 03:54   #13 (permalink)
Member: 761864
Thanks Meter: 63
if your phone status is contact retailer, try to write modified CERTIFICATE (without NPC)
if problem still persist hardware problem for sure.
Old 03-01-2012, 05:36   #14 (permalink)
Member: 979698
Thanks Meter: 2
MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: xxxxxx
Using device: HTI, FW ver: 00.50, SN:xxxxxxx
Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012)
APE Data :
SYSTEM ASIC ID: 17100708 [OMAP1710 ver: 2.0]
ASIC MODE ID: 00
PUBLIC ID: 58480B92546025AB7E58720F7469B814D940E505
ROOT KEY HASH: 49A97E826B93BA20B7ED0B082475C00500000000
ROM ID: 1DFD66132C872FD4
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 1D20000129D50154C79615DD59EC118DB6C1FF69
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
eBB5ProtocolType: OLD
Storage0: 00EC 22E8 - 0000 6921 [Samsung K8S2815ETB,128 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
TransmissionMode: DDR&TX2
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
Storage0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: FLASH,NAND, asic:APE
Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0
APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
Original Imei: 35640601666231
Original Product code: 0529820
Bluetooth ID: 001BEE998D7F
Imei plain: 35640601666231-3
Product code: 0529607
Battery voltage: 4246 mV, current: 0 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 356406016662313
Counter: 0/3, 0/10
i have same case n i try many solution but not solved
Old 03-01-2012, 07:02   #15 (permalink)
Member: 423802
Sonork: 100.1604150
Thanks Meter: 16
full erase pm file then write new pm tested 1000000%
Page generated in 0.28452 seconds with 10 queries
