Old 03-25-2010, 18:56   #1 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
Thanks Meter: 687
nokia n73 sucsess in startup faild
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
SecondaryBoot: helen3_2nd.fg [BB5] version: 1.35.0 revision: 0.0 size: 0x3500
Supported APE Ids: 17100700, 17100701, 17100702, 17100703, 17100704, 17100708
FlashID0: 00EC 00A1 - 0080 0015 [Samsung KAL00T00EM-DGYY/66,1 Gbits] type: NAND,APE
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
Algorithm: h3_sam_nand_xsr.fg [OMAP1710 UNISTORE-II-1.2.1 ALG] version: 1.49.0 revision: 0.0 size: 0x13AA0
APE PAPUBKEYS HASH: 5E8D0D504A0902E261268C14FCD8A2C9093523BC
Original Imei: 35686202634531
Original Product code: 0555266
Bluetooth ID: 0023B4595F81
Phone Type: RM-133 (Nokia N73)
SW Version: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia.
Imei plain: 35686202634531-7
Product Code: 0555266
Language Pack:
- not available.
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 356862026345317
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
Library version: 1.0.0.7920(18-03-2010), 1.0.0.12662(19-03-2010)
Product: V 05wk47v61.1 09-07-08 RM-133 (c) Nokia.
ApeCoreSw: V 4.0839.42.2.1 27-09-2008 RM-133
Using cached productData[0D900218EF187D5683331838604DF081F6F680B4] ...
Calculating SIMLOCK using security server ...
Completed in 1.047 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-133_356862026345317_SIM.RPL"
Updating SIMLOCK...OK
Reading Simlock info ...
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Calculating SUPERDONGLE using security server ...
Completed in 3.328 s
RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-133_356862026345317_SIMSD.RPL"
Updating SUPERDONGLE_KEY ...OK
using device: UFS_USB V2.8 (c) SarasSoft 2007.
Authenticating to SUPERDONGLE using security server ...
SUPERDONGLE authorized !
Writing PM from Node ...
Section: 1
- Key: 0, size 114 bytes written.
- Key: 2, size 98 bytes written.
- Key: 4, size 110 bytes written.
- Key: 6, size 98 bytes written.
- Key: 8, size 110 bytes written.
- Key: 13, size 98 bytes written.
- Key: 16, size 98 bytes written.
- Key: 18, size 98 bytes written.
- Key: 20, size 98 bytes written.
- Key: 22, size 16 bytes written.
- Key: 23, size 4 bytes written.
- Key: 24, size 84 bytes written.
- Key: 25, size 4 bytes written.
- Key: 26, size 110 bytes written.
- Key: 28, size 98 bytes written.
- Key: 29, size 6 bytes written.
- Key: 31, size 98 bytes written.
- Key: 33, size 36 bytes written.
- Key: 34, size 80 bytes written.
- Key: 44, size 182 bytes written.
Section: 309
- Key: 0, size 4 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
- Key: 22, size 12 bytes written.
Completed in 0.593 s
FULL FACTORY... OK
USER DATA... OK
LEAVE FACTORY... OK
SERVICE CENTER... OK
SOFTWARE UPGRADE... OK
PRODUCTION TUNING... OK
Reset User Code (to default:12345) ... OK
Completed in 5.250 s
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST passed
Counter: 0/3, 0/10
The Following 2 Users Say Thank You to jaleelkuttikkar For This Useful Post:
Old 04-04-2010, 17:53   #2 (permalink)
shami's Avatar
Member: 158181
Thanks Meter: 113
up load its pm.i need that file
Old 04-04-2010, 18:21   #3 (permalink)
Member: 644616
Sonork: 100.1608012
Thanks Meter: 257
here is modified pm download n enjoy
N73_RM-133.pm
Old 04-04-2010, 18:37   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
use "BB5 Secure Validation" , and paste log here
Added, BB5 Certificate Validation
Usefull to identify SECURITY_TEST problem specially if SUPERDONGLE is valid
Button located to [Phone Test->Various]
br,
The Following User Says Thank You to Andra For This Useful Post:
N73 show startup faild i flash but same aukonline HWK 5 07-03-2009 16:14
n73 phone startup faild Suazen Nokia Hardware & Hardware Repair 1 05-17-2009 14:55
Page generated in 0.15552 seconds with 9 queries
