12-17-2012, 11:49 | #1 (permalink) |
Freak Poster Join Date: Jun 2010 Location: Pakistan Swat Mingora City
Member: 1334092 Status: Offline Sonork: 100.1608030 Thanks Meter: 52 | Nokia N73 won't passed security test...:( Here is logo.... Phone type: RM-133 (Nokia N73) SW version: V 05wk47v53.1 29-10-07 RM-133 (c) Nokia. ApeCoreSw: V 4.0750.31.2.1 Imei plain: xxxxx Product code: 0529607 Battery voltage: 4460 mV, current: 274 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: xxxxxxxx Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
12-17-2012, 16:10 | #4 (permalink) |
Registered User Join Date: Jun 2006 Location: Rawalpindi, Pakistan
Member: 296577 Status: Offline Sonork: 3422455 Thanks Meter: 126 | backup npc and pm file upload another ok pm file then do repair super dongle after that write pm file from 1 to 309 or full pm file all will be ok |
12-17-2012, 16:12 | #5 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. It's Certificate validation problem, In this situation you have to Erase Phone, So Backup RPL & Erase Phone, -Now Flash it. -Do Super SD Auth. -Write PM. -Restore IMEI. -Write RPL without NPC Data. -Do Repair SD if needed. -Do Reset All. May solve your Problem. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
12-18-2012, 06:54 | #6 (permalink) | |
Junior Member Join Date: May 2007
Member: 518249 Status: Offline Thanks Meter: 4 | Quote:
follow this instruction and your phone ok. | |
12-18-2012, 07:13 | #7 (permalink) | |
Freak Poster Join Date: Jan 2011
Member: 1488757 Status: Offline Thanks Meter: 98 | Quote:
bor..Repair SD..pm..file..write...1..309... | |
12-18-2012, 08:51 | #8 (permalink) | |
Member: 1334092 Status: Offline Sonork: 100.1608030 Thanks Meter: 52 | Quote:
12-18-2012, 15:07 | #9 (permalink) |
No Life Poster Join Date: May 2011 Location: Z3X ^ CM2 ^ MRT ^ OCTOPUS
Member: 1587480 Status: Offline Sonork: 100.1618317 Thanks Meter: 2,165 | We Happy Solved Your Problem Good Work. BR. Arsalan gsm2000. |
The Following 2 Users Say Thank You to .::MASTER ALONE::. For This Useful Post: |
