Old 04-05-2013, 15:42   #1 (permalink)
262068's Avatar
Member: 689645
Thanks Meter: 14
nokia n8 or c3
i have both two n8 or c3 set in securty lock condition and coustomer forget code so i flash both set on mx key in usb flashing both set take flashing ok but when i start phone its ask secutry code and defalt code give code error what is resion for it after full flash how can it possible tell me any solution for it.
Old 04-05-2013, 16:00   #2 (permalink)
262068's Avatar
Member: 689645
Thanks Meter: 14
both set after flashing shoeing test mode but not tacking full reset. this problem in only tease two sets in all other set after usb flasing full reset done esily what is resion .
Old 04-06-2013, 06:35   #3 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Follow Mxkey Rules: http://forum.gsmhosting.com/vbb/f550...ection-984366/
Where is your Logs ?
Post Buscheck, Reset operation Logs for assistance.
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 04-06-2013, 17:07   #4 (permalink)
262068's Avatar
Member: 689645
Thanks Meter: 14
hear is n8 flashing log
MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN:
Using device: USB ROM and HTI, FW ver: 00.50, SN: 0100EEEF
Connection status: EHCI:HUB:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.84
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
Processing MCU file: RM-596_111.040.1511_79u_prd.core.fpsx
[BB5,XSR 1.6] size: 125.50 MB
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00000C35
CMT EM1 ID: 00000C30
CMT PUBLIC ID: 09D00116A3A40344CEE03A29C6954221EB03420D
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 69B93C9
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x178 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35268404371135_CE RT.rpl).
CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231
Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK
Partitioning....
Partitioning complete
Erase size: 228.06 MB
CMT FLASH,MuxOneNAND area [00040000-0007FFFF]
CMT FLASH,MuxOneNAND area [000C0000-008BFFFF]
CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT SOS+DECOMP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: D172C324 [RAP Certificate 103 v1] sent
CMT GENIO_INIT block sent
CMT SOS+IVE3A block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 25.413 s
Processing PPM file: RM-596_111.040.1511_18.01_APAC_2_79u_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 38.31 MB
Erase size: 64.25 MB
CMT FLASH,MuxOneNAND area [09A40000-0DA7FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 8.293 s
Processing PPM file: RM-596_111.040.1511_C02.01_SEAP_79u_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 24.97 KB
Erase size: 15.16 MB
CMT FLASH,MuxOneNAND area [01378000-0139FFFF]
CMT FLASH,MuxOneNAND area [0DA80000-0E97FFFF]
CMT SOS+ROFS3 block sent
CMT SOS+IVE3B block sent
Programming completed in 0.056 s
Processing CNT file: RM596_APE_ONLY_ENO_11w36_v0.162.fpsx
[BB5,XSR 1.6] size: 4.38 MB
Erase size: 5 MB
CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF]
CMT SOS*ENO block sent
Programming completed in 0.893 s
Processing CNT file: RM-596_111.040.1511_U03.01_79u.uda.fpsx
[BB5,XSR 1.6] size: 119.13 MB
Erase size: 262 MB
CMT FLASH,MuxOneNAND area [0EA00000-1EFFFFFF]
Programming completed in 18.967 s
Total time for flashing process(boot+erase+write) was 1 min 10.674 s
Waiting for device boot up ...
Device connected: nmwcdc\Nokia N8-00 USB Phonet, PORT_ID: B9291A9
Open device failed: FFFFFFFF (4) The system cannot open the file
Warning: Phone did not reboot to normal mode.
Old 04-06-2013, 17:08   #5 (permalink)
262068's Avatar
Member: 689645
Thanks Meter: 14
after this flash phon show test mode on screen but when start its ask for securty cod
Old 04-07-2013, 15:46   #6 (permalink)
262068's Avatar
Member: 689645
Thanks Meter: 14
is any one know about that what is resion
Old 04-08-2013, 07:01   #7 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Something wrong with your Phone,
Your Phone not reboot in Normal Mode & needs to Erase ones,
Follow steps from here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/
Do all necessary Backup before Erase,
Your Phone will be Reset easily.
BR,
ZUBER
Page generated in 0.23551 seconds with 8 queries
