Old 03-21-2013, 16:23   #1 (permalink)
emilkawa's Avatar
Member: 112498
Thanks Meter: 33
nokia n8 do not power ON in normal mode after flash
hello.
Problem is because before flash phone was a live.
After flashing procedure phone is in test mode (I can see this on phone LCD together info about soft wer.: 111.040.1511). I can read phone info:
Version Info:
MCU SW version:  V 79_sr1_12w18.5 27-07-12 RM-596 (c) Nokia
HW version:  7465
UEM version:  35
UPP version:  35
RFIC version:    Alli_4.3.4
DSP version:   92_12w18
LCD version:  35
PPM version:  35
BT MCM version:  35
ADSP SW version:  35
Bootcode version:  256 n  256 i  111.040.1511
APE SW Core version:  111.040.1511
APE Variant version:  111.040.1511.03.01111.040.1511.C00.01
APE Test version:  0.162
Retu version:  35
Tahvo version:  00
APE HW version:  256
APE ADSP SW version:  256
APE BT version:  HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13.
WLAN ID:  00 2E 43 A0 15 CF 90
Bluetooth ID:  90 CF 15 9F A6 EE
Product Info:
Production serial number:  M1L065366
Product code:  059D5C3
Basic production code:  0596826
Product specific data:  000000000000000000000000000000000000
Long production SN:  0
Serial Numbers:
IMEI plain:  357398043137261
IMEI spare to net:  3A 75 93 08 34 31 27 06
IMEI SV to net:  33 75 93 08 34 31 27 46 F5
Other Info:
Model:  Nokia N8-00 (Classic Phone)
CS type:  GSM850/GSM900/GSM1800/GSM1900/WCDMA I/WCDMA II/WCDMA IV/WCDMA IV/WCDMA V/WCDMA VIII
Battery voltage:  3732 mV
Battery current:  190 mA
BSI: 98,5 KOhm
Imei net: 357398043137261
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
... I can write back my backups readed before flashing:
imei_PM.rpl:
Updating PRODUCTCODE (059D5C3)... OK
Updating PSN (M1L065366)... OK
Updating HWID (7465)... OK
Updating SIMLOCK(PA_SL3)...OK
Updating WMDRM_PD ...OK
missing NPC data in the RPL file, CERT write skipped.
Phone type: RM-596 (Nokia N8-00)
ApeCoreSw: 111.040.1511
Imei plain: 35739804313726-1
Battery voltage: 3734 mV, current: 186 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Counter: 0/3, 0/10
imei_CERT.rpl:
Imei: 35739804313726
MXKEY [FT SCR2000 0], SN: C080B930
Using device: USB Phonet
Connection status: EHCI:HUB:USB 2.00 (High-speed)
Driver: nmwcdc, ver: 7.1.32.75
Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
Battery voltage: 3710 mV
Warning battery voltage is less, phone might not detected after flash !
SW version: 111.040.1511
LanguagePkg version: 111.040.1511.03.01111.040.1511.C00.01
Waiting for USB device removal ...
High-speed usb flashing enabled.
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00000C35
CMT EM1 ID: 00000C30
CMT PUBLIC ID: 0BD00007C7D703442B874858BCF46A95A8F6D92D
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
 SecondaryBoot: RAPUv11_2nd.fg [BB5]  version: 11.14.0 revision: 3.0 size: 0x3B40
 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000  - 0000 0000  type: RAM, asic:CMT
Storage1: FFFF 0000  - 0000 0000  type: MMC, asic:CMT
Storage2: 0020 0050  - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001  - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 0020 0050  - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6]  version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 142E94D1
FUR: Adding Asic CMT as client OK.
Updating CMT  NPC ...OK
Updating CMT  CCC ...OK
Updating CMT  HWC ...OK
Waiting for device boot up ...
Device connected: nmwcdc\Nokia N8-00 USB Phonet, PORT_ID: 22753756
Verifying communication to device OK.
Battery voltage: 3721 mV, current: 194 mA
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
When I try to change to normal mode, display on phone is black and blinking white led next to microUSB conentor.
When reinstert batery and press power button, after 9 seconds, I feel the 3 times vibration signal and that's all.
I flashed phone many times (with ENO and without, only MCU, language only, etc.), can't find later software and stil the same.
What can I do next?
Emilkawa
Old 03-22-2013, 07:11   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
Do Quick Fix,
Go to Service Tab > Quick Fix > Tick Rap3NAND Erase > Click Do Selected Job,
If not solve, then Erase & Downgrade Phone with this Method: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/
Backup all necessary field before starting Erase,
Now Download your Product Firmware from version 111.030.609
Flash it with this Version, Write & Restore all Backup will solve.
BR,
ZUBER
Old 03-22-2013, 16:49   #3 (permalink)
emilkawa's Avatar
Member: 112498
Thanks Meter: 33
Originally Posted by .::ZUBER::. View Post
Bro.
Do Quick Fix,
BR,
ZUBER
didn't help but operation was succesful:
CMT Data :
EM0 ID: 00000C35
EM1 ID: 00000C30
ASIC MODE ID: 00
 SecondaryBoot: RAPUv11_2nd.fg [BB5]  version: 12.14.0 revision: 3.0 size: 0x3B40
TransmissionMode: DDR&TX2
 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6]  version: 12.14.0 revision: 3.0 size: 0xD4569
CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231
Flash programming ...
Prog.status for Asic CMT ...
 NAND: OK
Programming completed in 1.805 s
what do you mean "Backup all necessary field before" second solution.
I've got 2 files rpl. Is it enought?
Emilkawa
Old 03-23-2013, 07:29   #4 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro.
If Phone is SL3, then i recommend you to take Backup of Simlock RPL individually while Backing up RPL,
Reason, when Buscheck auto Backup RPL created with Software, but no Simlock included in it.
If User didn't Backup RPL All Section manually, face the problem of Invalid or Corrupted Simlock after Erasing SL3 Phone,
I think now you must have been clear about what i want to say.
BR,
ZUBER
Old 03-23-2013, 13:56   #5 (permalink)
emilkawa's Avatar
Member: 112498
Thanks Meter: 33
yes, it is clear, thanks
unfortunately during second solution during writing PM didn't write section 308.
Scanning local SX4 Card ...
No SX4 Card found.
SERVER->MXKEY - BLADE X at host2, agent version 1.2 revision 0.5
Using device: HTI, FW ver: 00.50, SN: 00004B76
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0 , NTMP ver: 6.1.7601.17514
SW version: V 79_sr1_11w42.5 25-11-11 RM-596 (c) Nokia
ApeCoreSw: 111.030.0609
Using cached productData.
PRIVATE ID: 6B5A161BE51DDF102629F4CDE7C78B8CF55F0A33
SUPERDONGLE authorized :)!
Writing PM from Node ...
Section: 1
 - Key: 0, size 10 bytes written.
 - Key: 1, size 94 bytes written.
 - Key: 2, size 110 bytes written.
 - Key: 4, size 10 bytes written.
 - Key: 6, size 110 bytes written.
 - Key: 7, size 450 bytes written.
 - Key: 8, size 10 bytes written.
 - Key: 13, size 110 bytes written.
 - Key: 15, size 30 bytes written.
 - Key: 16, size 30 bytes written.
 - Key: 17, size 30 bytes written.
 - Key: 18, size 30 bytes written.
 - Key: 19, size 30 bytes written.
 - Key: 22, size 24 bytes written.
 - Key: 26, size 10 bytes written.
 - Key: 27, size 36 bytes written.
 - Key: 28, size 110 bytes written.
 - Key: 29, size 10 bytes written.
 - Key: 30, size 36 bytes written.
 - Key: 31, size 24 bytes written.
 - Key: 32, size 216 bytes written.
 - Key: 33, size 36 bytes written.
 - Key: 35, size 24 bytes written.
 - Key: 36, size 24 bytes written.
 - Key: 38, size 216 bytes written.
 - Key: 39, size 36 bytes written.
 - Key: 40, size 24 bytes written.
 - Key: 41, size 216 bytes written.
 - Key: 43, size 36 bytes written.
 - Key: 44, size 216 bytes written.
 - Key: 45, size 216 bytes written.
Section: 4
 - Key: 1, size 200 bytes written.
 - Key: 3, size 10 bytes written.
 - Key: 4, size 8 bytes written.
 - Key: 5, size 8 bytes written.
 - Key: 9, size 5 bytes written.
 - Key: 28, size 2 bytes written.
Section: 8
 - Key: 0, size 2 bytes written.
 - Key: 1, size 16 bytes written.
 - Key: 2, size 16 bytes written.
 - Key: 3, size 128 bytes written.
 - Key: 4, size 128 bytes written.
 - Key: 8, size 8 bytes written.
 - Key: 9, size 8 bytes written.
 - Key: 10, size 32 bytes written.
 - Key: 11, size 4 bytes written.
 - Key: 12, size 4 bytes written.
Section: 11
 - Key: 0, size 4 bytes written.
 - Key: 1, size 4 bytes written.
 - Key: 2, size 4 bytes written.
 - Key: 3, size 4 bytes written.
Section: 31
Section: 54
Section: 96
Section: 120
 - Key: 0, size 944 bytes written.
 - Key: 1, size 160 bytes written.
 - Key: 2, size 130 bytes written.
 - Key: 3, size 112 bytes written.
Section: 122
Section: 153
 - Key: 0, size 68 bytes written.
 - Key: 1, size 68 bytes written.
 - Key: 2, size 68 bytes written.
 - Key: 3, size 68 bytes written.
 - Key: 4, size 68 bytes written.
 - Key: 5, size 68 bytes written.
Section: 193
 - Key: 2, size 8 bytes written.
 - Key: 3, size 32 bytes written.
 - Key: 4, size 32 bytes written.
 - Key: 9, size 64 bytes written.
Section: 308
Warning: failed to write 308 - 0 (1 bytes)
Warning: failed to write 308 - 1 (8192 bytes)
Warning: failed to write 308 - 3 (1 bytes)
Warning: failed to write 308 - 4 (1 bytes)
Warning: failed to write 308 - 6 (1 bytes)
Warning: failed to write 308 - 7 (1 bytes)
Warning: failed to write 308 - 9 (40 bytes)
Section: 309
 - Key: 1, size 2 bytes written.
 - Key: 2, size 12 bytes written.
 - Key: 3, size 36 bytes written.
 - Key: 4, size 12 bytes written.
 - Key: 7, size 12 bytes written.
 - Key: 17, size 12 bytes written.
Section: 313
 - Key: 0, size 800 bytes written.
Section: 322
 - Key: 0, size 1 byte written.
Section: 341
 - Key: 4, size 4516 bytes written.
 - Key: 10, size 4 bytes written.
 - Key: 11, size 1972 bytes written.
 - Key: 12, size 328 bytes written.
Section: 354
 - Key: 0, size 3 bytes written.
Section: 356
 - Key: 1, size 8 bytes written.
Section: 369
 - Key: 0, size 40 bytes written.
Section: 382
Completed in 18.355 s
but the phone seems to fit:
Battery voltage: 4770 mV, current: 0 mA
Language Pack:
- not available.
SUPERDONGLE_KEY[MX] seems to be valid
SIMLOCK_TEST passed
Counter: 0/3, 0/10
...unfortunately only until swithing to NORMAL mode.
I can see logo NOKIA on LCD , after this:
and after this is only black screen.
Can I do somethink else?
Emilkawa
Old 03-23-2013, 14:44   #6 (permalink)
Member: 727810
Sonork: 100.1627301
Thanks Meter: 167
flash with this file , today i also recoveri my ph with this file
RM 596 Scandinavia.rar
mcu= prd core
ppm=rofs2
cnt=rofs3
dont forget to say thanks.....
Old 03-25-2013, 04:23   #7 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Your CMLA keys corrupted.
Your option: downgrade to Symbian Anna.
Procedure: Backup-Erase-Flash lower version (version 25.x)
Exactly here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/
Old 03-25-2013, 17:09   #8 (permalink)
emilkawa's Avatar
Member: 112498
Thanks Meter: 33
Hi. How did you know about CLMA keys?
Soft ver 025.007 helped. I had problem with SECURITY_TEST (contact to retailer...) after downgrade and restore backups but REPAIR_SD fixed it.
During restoring PM didn't write section 308, is it normal?
Thanks a lot, Emilkawa
Old 03-25-2013, 17:16   #9 (permalink)
emilkawa's Avatar
Member: 112498
Thanks Meter: 33
mcu= prd core
ppm=rofs2
cnt=rofs3
I want to say thanks but your files from ver. 011.005 didn't help. Maybe I did something wrong but next I flashed with 025.007 and my problem is solved.
Thank you, Emilkawa
Old 03-25-2013, 17:43   #10 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
Hi,
This phone was ever erased and repaired before, and the keys are not original. That's why it won't start on Belle. You can ignore 308 write failed. Repair SD solved this problem.
The Following User Says Thank You to gbluez For This Useful Post:
Old 03-25-2013, 17:44   #11 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,589
From your screen shot... Nokia logo and "....." Dot Dot Dot indicates that
phone doesn't have CMLA KEY inside (only Belle firmware checks CMLA) on startup.
The Following User Says Thank You to ..::Angel::.. For This Useful Post:
Old 03-26-2013, 00:24   #12 (permalink)
emilkawa's Avatar
Member: 112498
Thanks Meter: 33
Originally Posted by ..::Angel::.. View Post
.....only Belle firmware checks CMLA....
How do you know that? I'm fascinated by your knowledge.
Best regards, Emilkawa
Page generated in 0.32855 seconds with 8 queries
