08-19-2011, 14:05 | #1 (permalink) |
Freak Poster Join Date: Aug 2006 Location: R A J A S T H A N
Member: 333796 Status: Offline Sonork: 100.1587155 Thanks Meter: 83 | Nokia N8 sussesfully flash by USB ( with backup sim lock n RPL) Connection status: EHCI:HUB:HUB:USB 2.00 (High-speed) Driver: nmwcdc, ver: 7.1.32.67 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Reading Important data ... Rpl backup already exist (C:\mobileEx\3.5\data\backup\BB5_35739804768753_BA CK.rpl). Processing MCU file: RM-596_022.014_79.92_prd.core.fpsx [BB5,XSR 1.6] size: 122.51 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Battery voltage: 3649 mV Warning battery voltage is less, phone might not detected after flash ! Phone type: RM-596 (Nokia N8-00) Product code: 0599255 SW version: 014.002 LanguagePkg version: 014.002.00.01014.002.24.01014.002.C03.01 Version from phone: 014.002 Version from file: 022.014 Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 609BCF CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPU ver: 1.1] CMT EM0 ID: 00000C35 CMT EM1 ID: 00000C30 CMT PUBLIC ID: 15A00014B6D60344713BCC281F4B4E184C0DD3EC CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B CMT ROM ID: E693EF0DAC22615B Loading CMT secondary boot code SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0050 - 0000 0232 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 609BCF FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x190 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x1D8 bytes). Reading CMT HWC (0xD4 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35739804768753_CE RT.rpl" CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231 Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK Partitioning.... Partitioning complete Erase size: 228.06 MB CMT FLASH,MuxOneNAND area [00040000-0007FFFF] CMT FLASH,MuxOneNAND area [000C0000-008BFFFF] CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT SOS+PMML block sent CMT PASUBTOC block sent CMT PAPUBKEYS: D172C324 [RAP Certificate 103 v1] sent CMT GENIO_INIT block sent CMT SOS*UPDAPP block sent CMT SOS*DSP0 block sent CMT LDSP block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Programming completed in 21.737 s Processing PPM file: RM-596_022.014_24.01_India_79.92_prd.rofs2.fpsx [BB5,XSR 1.6] size: 31.26 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 59.25 MB CMT FLASH,MuxOneNAND area [09F40000-0DA7FFFF] Flash programming ... CMT SOS+ROFS2 block sent Programming completed in 5.591 s Processing PPM file: RM-596_022.014_C03.01_India_79.92_prd.rofs3.fpsx [BB5,XSR 1.6] size: 10.30 KB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 15 MB CMT FLASH,MuxOneNAND area [0DA80000-0E97FFFF] Flash programming ... CMT SOS+ROFS3 block sent Programming completed in 0.123 s Processing CNT file: RM596_APE_ONLY_ENO_11w15_v0.148.fpsx [BB5,XSR 1.6] size: 4.05 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 5 MB CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF] Flash programming ... CMT SOS*ENO block sent Programming completed in 0.812 s Processing CNT file: RM-596_022.014_U03.01_79.92.uda.fpsx [BB5,XSR 1.6] size: 95.62 MB Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 Erase size: 262 MB CMT FLASH,MuxOneNAND area [0EA00000-1EFFFFFF] Flash programming ... Programming completed in 18.832 s Total time for flashing process(boot+erase+write) was 55.550 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia N8-00 USB Phonet, PORT_ID: 169F790D Verifying communication to device OK. Phone type: RM-596 (Nokia N8-00) SW version: V 92_11w25.1 01-07-11 RM-596 (c) Nokia Imei plain: 357XXXXXXXXXXXX-5 Product code: 0599255 Battery voltage: 3626 mV, current: 154 mA ApeCoreSw: 022.014 Language Pack: - not available. Detected as PA_SL3 phone. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357398047687535 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Nokia N8-00 USB Phonet detached |
The Following User Says Thank You to rekha1255 For This Useful Post: |
