Old 02-10-2010, 08:48   #1 (permalink)
Member: 424066
Thanks Meter: 31
Nokia N81) SIMLOCK_TEST failed!
Phone Type: RM-179 (Nokia N81)
SW Version: V 06wk41v47.2 23-11-07 RM-179 (c) Nokia
Imei plain: 35865001101160-8
Product Code: 0556333
ApeCoreSw: 11.0.045
ApeVariant: 11.0.045, ApeTest: rm179_ENO_x_2007wk24v0.070
Language Pack:
- not available.
SIMLOCK invalid!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
sir how to slove this problem ps sir thanks
Old 02-10-2010, 08:49   #2 (permalink)
Cyclone Team<3's Avatar
Member: 1212935
Sonork: cylone team
Thanks Meter: 122
Tick "make simlock rpl" and "repair simlock"
Press "update Sp lock"
Old 02-10-2010, 08:50   #3 (permalink)
Umair Rashid's Avatar
Member: 421117
Sonork: +92 346 5544377 (PHONE)
Thanks Meter: 2,519
Done !!!
take a tea :.)
Br,
Umair
Old 02-10-2010, 08:51   #4 (permalink)
Member: 421117
Thanks Meter: 2,519
Originally Posted by Cyclone Team<3 View Post
repair simlock first...then repair sd.then Sd auth then write PM 1 and 309 all done!,,,,
No need of repairing SD.
Can't you see Superdongle KEy is VALID.
I advice you read Forum first..will learn more..
Br,
Umair
Old 02-10-2010, 09:12   #5 (permalink)
Member: 424066
Thanks Meter: 31
ApeCoreSw: 11.0.045
Language Pack:
- not available.
SIMLOCK seems to be valid
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST passed
Imei net: 358650011011608
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
thanksir my problem is gone again to very very thanks
Old 02-10-2010, 09:16   #6 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,773
your problem gone
but have this
then Repair SUPERDONGLE
br,
Old 02-10-2010, 09:17   #7 (permalink)
Member: 4813
Thanks Meter: 396
ApeCoreSw: 11.0.045
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
not done - check superdongle key
Old 02-10-2010, 09:19   #8 (permalink)
Member: 1212935
Sonork: cylone team
Thanks Meter: 122
have you alredy sd aurh then write pm 1 and 309...or write rpl without npc for same model..
SIMLOCK_TEST failed! leomuns MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 08-06-2011 15:32
nokia 5130 SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SE >>.123.<< MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 10-24-2010 12:05
nokia 5130 SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST failed! SE >>.123.<< MXKEY Nokia Flasher and Unlocker (by Alim Hape) 9 02-17-2010 05:29
Any Buddy repair SIMLOCK invalid!, SIMLOCK_TEST failed! or SECURITY_TEST failed! mohit_kripalu01 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-06-2010 11:36
SIMLOCK invalid!, SIMLOCK_TEST failed!, SECURITY_TEST failed! Raven21 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 01-27-2010 08:15
Page generated in 0.28857 seconds with 8 queries
