Go Back   GSM-Forum > Product Support Sections > Hard/Software-Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 07-08-2010, 07:48   #1 (permalink)
pawanmalhotra's Avatar
Member: 397892
Sonork: 100.1609899
Arrow nokia n95 8gb country unloking problem[SOLVED]
  • i try country unloking nokia n95 8gb with mx-key.but its show error in processing.after that phone in phone startup faild & show this eror....logs.......Phone Type: RM-320 (Nokia N95 8GB)
    SW Version: V 06wk41v51.3 13-02-08 RM-320 (c) Nokia
    Imei plain: ##########
    Product Code: 0557135
    Language Pack:
    - not available.
  • SIMLOCK invalid!
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST failed!
    SECURITY_TEST passed
    SIMLOCK_DATA corrupted!
    2. after rpl backup its show this......APE Data :
    SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2]
    ASIC MODE ID: 00
    PUBLIC ID: 174B333B59F90615E437D40F68D20E29B703B8D9
    ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
    RAP Data :
    SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
    EM0 ID: 00000295
    EM1 ID: 00000B22
    PUBLIC ID: 0240010F75940158316A116F7AA48626F66D44FA
    ASIC MODE ID: 00
    ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
    ROM ID: A8C1D6713E691FF8
    SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
    Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
    FlashID0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP
    ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
    TransmissionMode: 16Bit
    Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
    RAP PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4
    SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00
    Supported APE Ids: 24200703, 24200704, 24200705, 24200706
    FlashID0: 00EC 0040 - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE
    ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG
    Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG] version: 1.57.0 revision: 0.0 size: 0x2E248
    APE PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4
    Reading RAP NPC (0x1B8 bytes).
    Reading RAP VARIANT (0x0 bytes).
    Reading RAP CCC (0x160 bytes).
    Reading RAP HWC (0xD4 bytes).
    Reading APE NPC (0x200 bytes).
    Reading APE VARIANT (0x0 bytes).
    Reading APE CCC (0x200 bytes).
    Reading APE HWC (0x200 bytes).
    Flash Imei: ##########
    NPC_DATA saved OK
    CCC_DATA saved OK
    HWC_DATA saved OK
    SIMLOCK_DATA saved OK
    SIMLOCK_KEY_DATA saved OK
    SUPERDONGLE_KEY_DATA saved OK
    CMLA_KEY_DATA saved OK
    WMDRM_PD_DATA saved OK
    NPC_DATA saved OK
    VARIANT_DATA is empty.
    CCC_DATA saved OK
    HWC_DATA saved OK
    RF_DATA saved OK
    WARRANTY_DATA saved OK
    PROD_DATA saved OK
    BT_DATA saved OK
    LOCK_DATA saved OK
    LOCK120_DATA saved OK
    BB_DATA saved OK
    WLAN_DATA saved OK
    RPL saved to "C:\mobileEx\3.4\data\backup\BB5_############. rpl"
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiShare on FacebookTwitterStumble this Post!
The Following User Says Thank You to pawanmalhotra For This Useful Post:
Old 07-08-2010, 08:14   #2 (permalink)
Member: 1152038
repair simlock with mxkey 100% will work
Old 07-08-2010, 11:08   #3 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
this kind phone is "POWER HUNGRY" , need stable power and correcly BSI line value
try check your cable
br,
The Following 3 Users Say Thank You to Andra For This Useful Post:
Old 07-08-2010, 13:17   #4 (permalink)
Shakeel_pattoki's Avatar
Member: 437195
Sonork: 100.1590009
For safe unlocking always press (Unlock by Code) to avoid these kind problems.
Regards
Old 07-08-2010, 13:21   #5 (permalink)
kapilgupta's Avatar
Member: 681945
Originally Posted by pawanmalhotra View Post
  • i try country unloking nokia n95 8gb with mx-key.but its show error in processing.after that phone in phone startup faild & show this eror....logs.......phone type: Rm-320 (nokia n95 8gb)
    sw version: V 06wk41v51.3 13-02-08 rm-320 (c) nokia
    imei plain: ##########
    product code: 0557135
    language pack:
    - not available.
  • simlock invalid!
    Superdongle_key seems to be valid
    cmla_key seems to be valid
    wmdrm_pd seems to be valid
    simlock_test failed!
    Security_test passed
    simlock_data corrupted!
    2. After rpl backup its show this......ape data :
    System asic id: 24200705 [omap2420 ver: 2.2]
    asic mode id: 00
    public id: 174b333b59f90615e437d40f68d20e29b703b8d9
    root key hash: Ba8710a7e1cd5a2909b9a875db27aa2400000000
    rap data :
    System asic id: 000000010000022600010006400c192101021103 [rapido3g ver: 1.11]
    em0 id: 00000295
    em1 id: 00000b22
    public id: 0240010f75940158316a116f7aa48626f66d44fa
    asic mode id: 00
    root key hash: Caeebb65d3c48e6dc73b49dc5063a2ee
    rom id: A8c1d6713e691ff8
    secondaryboot: Rapidov11_2nd.fg [bb5] version: 1.37.1 revision: 0.0 size: 0x3b80
    supported rap ids: 0003192101002003, 000c192101002003, 4003192101002003, 400c192101002003, 4003192101011103, 400c192101011103, 4003192101021103, 400c192101021103, 4003192101031103, 400c192101031103, 4003192101011105, 400c192101011105, 400c192101021105, 400c192101031105
    flashid0: 0001 0035 - 0000 6921 [amd s29ns128n,128 mbits] type: Nor,rap
    extbusc: 0000 0000 0000 0000 0000 0000 0000 0000
    transmissionmode: 16bit
    algorithm: Rapidov11_algo.fg [xsr 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
    rap papubkeys hash: 9c5ea53a1f6dbd7df955715e780159991b4b6ea4
    secondaryboot: Omap2420_m1_2nd.fg [bb5] version: 1.41.0 revision: 0.0 size: 0x7c00
    supported ape ids: 24200703, 24200704, 24200705, 24200706
    flashid0: 00ec 0040 - 0022 0000 [samsung 2gb ddp onenand,2 gbits] type: Nand,ape
    alg [35]: Omap2420 unistore-ii-1.5.1 alg
    algorithm: Teflon_sam_nand_xsr151_m1.fg [omap2420 unistore-ii-1.5.1 alg] version: 1.57.0 revision: 0.0 size: 0x2e248
    ape papubkeys hash: 9c5ea53a1f6dbd7df955715e780159991b4b6ea4
    reading rap npc (0x1b8 bytes).
    Reading rap variant (0x0 bytes).
    Reading rap ccc (0x160 bytes).
    Reading rap hwc (0xd4 bytes).
    Reading ape npc (0x200 bytes).
    Reading ape variant (0x0 bytes).
    Reading ape ccc (0x200 bytes).
    Reading ape hwc (0x200 bytes).
    Flash imei: ##########
    npc_data saved ok
    ccc_data saved ok
    hwc_data saved ok
    simlock_data saved ok
    simlock_key_data saved ok
    superdongle_key_data saved ok
    cmla_key_data saved ok
    wmdrm_pd_data saved ok
    npc_data saved ok
    variant_data is empty.
    Ccc_data saved ok
    hwc_data saved ok
    rf_data saved ok
    warranty_data saved ok
    prod_data saved ok
    bt_data saved ok
    lock_data saved ok
    lock120_data saved ok
    bb_data saved ok
    wlan_data saved ok
    rpl saved to "c:\mobileex\3.4\data\backup\bb5_############. rpl"
bro
u just remove camera and then do this process
tested by me
because it need staible power and more power then our cable gives.. After removing camera handset will consume low power and will be having staible local/test ode
wbr
kapil gupta
The Following 2 Users Say Thank You to kapilgupta For This Useful Post:
Old 07-08-2010, 15:03   #6 (permalink)
Member: 397892
Sonork: 100.1609899
Arrow
    Language Pack:
    - not available.
  • SIMLOCK invalid!
    ASIC MODE ID: 00
    RAP Data :
    EM0 ID: 00000295
    EM1 ID: 00000B22
    ASIC MODE ID: 00
    NPC_DATA saved OK
    CCC_DATA saved OK
    HWC_DATA saved OK
    NPC_DATA saved OK
    CCC_DATA saved OK
    HWC_DATA saved OK
    RF_DATA saved OK
    PROD_DATA saved OK
    BT_DATA saved OK
    LOCK_DATA saved OK
    BB_DATA saved OK
    WLAN_DATA saved OK
[QUOTE=Andra;6056803]this kind phone is "POWER HUNGRY" , need stable power and correcly BSI line value
  • thanxx i will done.this time its unloked . try many times again & again its done.thanxxx ANDRA .for suggestion faulty cable.
Old 07-09-2010, 03:17   #7 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
very nice hear that
thanks for your report.
br,
ps : done , and closed.
The Following User Says Thank You to Andra For This Useful Post:
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 52 03-21-2012 09:34
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 24 02-14-2012 02:39
Powered by Searchlight © 2012 Axivo Inc.
- GSM Hosting Ltd. - 1999-2011
Page generated in 2.11235 seconds with 10 queries
