Old 11-07-2009, 11:54   #1 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
Nokia n95 8gb rm-320 flashing problem:(
BUS CHECK
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.10913, Date: 05-11-2009
APE Data :
SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2]
ASIC MODE ID: 00
PUBLIC ID: AB39A4920782DBF886B9D1655084C925AB03C9BD
ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
EM1 ID: 00000295
EM2 ID: 00000B22
PUBLIC ID: 0E8000197E7600585AF15F8924336E35F7D6439E
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: A8C1D6713E691FF8
 SecondaryBoot: RAPIDOv11_2nd.fg [BB5]  version: 1.37.1 revision: 0.0 size: 0x3B80
 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 0001 0035  - 0000 6921 [AMD S29NS128N,128 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
 Algorithm: RAPIDOv11_algo.fg [XSR 1.5]  version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: 9C5EA53A1F6DBD7DF955715E780159991B4B6EA4
 SecondaryBoot: omap2420_m1_2nd.fg [BB5]  version: 1.41.0 revision: 0.0 size: 0x7C00
 Supported APE Ids: 24200703, 24200704, 24200705, 24200706
RX2 enabled.
FlashID0: 00EC 0040  - 0022 0000 [Samsung 2Gb DDP OneNAND,2 Gbits] type: NAND,APE
ALG [35]: OMAP2420 UNISTORE-II-1.5.1 ALG
 Algorithm: teflon_sam_nand_xsr151_m1.fg [OMAP2420 UNISTORE-II-1.5.1 ALG]  version: 1.57.0 revision: 0.0 size: 0x2E248
APE PAPUBKEYS is blank/erased.
Original Imei: 35698301146618
Original Product code: 0557135
Bluetooth ID: 001C9AED30EA
WLAN ID: 001CD4023CBA
Phone not responding !
FLASHING WITH FAST FLASH AND RX2 ENABLED
Processing file: RM-320_31.0.015_PR.C0R as MCU
 [BB5,XSR 1.5,BB5,OMAP2420 UNISTORE-II-1.5.1 ALG]  size: 69.48 MB
 Supported RAP Ids: 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103
 Supported APE Ids: 24200705
APE Data :
ASIC MODE ID: 00
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
RX2 enabled.
Total erase size: 123.00 MB
CMT NOR area [00080000-007CF385]
CMT NOR area [00000000-0005FFFF]
CMT NOR area [00880000-00FDFFFF]
APE NAND area [00000200-0000AFFF]
APE NAND area [0000B800-000AFFFF]
APE NAND area [00000000-00000FFF]
APE NAND area [0000D800-0000E9FF]
APE NAND area [00080000-000BFFFF]
APE NAND area [000E0000-0045FFFF]
APE NAND area [004C0000-0073FFFF]
APE NAND area [00A40000-06F3FFFF]
erased in 5.062 s
warning : erase sector address out of chip bound.
Flash programming ...
Error chk C7012D0103CD000090000000B1
RX2 not responding, please check BSI/cable/pinout !
Error while programming [00] at 0x00001000, Result: 0090
Flashing terminated with error(s) in 35.434 s
RX Buffer: C7012D0103CD000090000000B172
FLASHING WITH FAST FLASH ENABLED AND RX2 DISABLED
APE Data :
ASIC MODE ID: 00
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
RX2 enabled.
erased in 5.062 s
Flashing terminated with error(s) in 35.793 s
FLASHING WITHOUT FAST FLASH AND RX2 ENABLED
APE Data :
ASIC MODE ID: 00
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
RX2 enabled.
CMT NOR area [00080000-007CF385] erased in 5.031 s
CMT NOR area [00000000-0005FFFF] erased in 0.109 s
CMT NOR area [00880000-00FDFFFF] erased in 1.344 s
APE NAND area [00000200-0000AFFF] erased in 0.047 s
APE NAND area [0000B800-000AFFFF] erased in 0.047 s
APE NAND area [00000000-00000FFF] erased in 0.047 s
APE NAND area [0000D800-0000E9FF] erased in 0.063 s
APE NAND area [00080000-000BFFFF] erased in 0.062 s
APE NAND area [000E0000-0045FFFF] erased in 0.047 s
APE NAND area [004C0000-0073FFFF] erased in 0.063 s
APE NAND area [00A40000-06F3FFFF] erased in 0.265 s
Flashing terminated with error(s) in 36.980 s
ALWAYS GET THE ERROR. PLS HELP MX-TEAM.
WBR
sahil2000ind
Old 11-07-2009, 12:59   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
will be check.
br,
Old 11-07-2009, 16:42   #3 (permalink)
Member: 312779
Thanks Meter: 12
N96 RM-247 flashing problem
Old 11-07-2009, 17:26   #4 (permalink)
gprsman's Avatar
Member: 217461
Thanks Meter: 150
seam problem try 2 cable 7 pin
Old 11-07-2009, 21:47   #5 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
yes in N96
still test for new update here,please be patient.
about N95 8GB still checked here sorry
br,
Old 04-23-2010, 14:33   #6 (permalink)
Crazy Poster
Member: 1086738
Sonork: shamimtelecom
Thanks Meter: 24
nokia n 95 8gb. when I flash it, in computer it shows "prodect selection mismatch. no response from ape mcu." When I try to open this phone, it is on but it shows only logic upper key pad light. incomig and out going totally off and not showing LCD/LED lighting. please.......... help me sir.
Old 04-23-2010, 14:52   #7 (permalink)
Gubby_J's Avatar
Member: 131788
Thanks Meter: 69
Mx-key
Good Unlocker, but very-bad flasher at rear behind all Nokia flasher-Boxes and programs...
Old 04-25-2010, 16:36   #8 (permalink)
Crazy Poster
Member: 1086738
Thanks Meter: 24
ape ic. remove then ic pin modify & replace again.100% ok.
Nokia N95 8GB RM-320 dead after flash... spritstiv J.A.F. By Jafsupport.com 13 07-11-2013 09:50
i need good PCB from nokia N95 8GB RM-320 PSG Nokia Hardware & Hardware Repair 2 07-05-2009 05:42
Farsi product code for nokia n95 8gb rm-320 cpu2007 Nokia Base Band 5 ( BB-5 ) 8 04-15-2009 21:23
Nokia N95 8GB RM-320 V 20.0.016 fr3nsis Nokia Base Band 5 ( BB-5 ) 5 04-18-2008 17:03
Page generated in 0.22980 seconds with 9 queries
