Old 02-04-2010, 16:51   #1 (permalink)
imran_qasim's Avatar
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
Nokia N95 Blank Screen Problme
@All
i've Recieved one nokia n95 today which was power on Ook after that it restarts so i format FFS with low level but and then try to reset factory defaults but its failed after that phone give buzz and only show lights on and black or u can say blank screen. this is my 2nd fone with same problem after format so tell me what is the problem and what could be the solution.
Take Care
ENJOY
Old 02-04-2010, 16:58   #2 (permalink)
NeeMan's Avatar
Member: 767786
Thanks Meter: 320
normally buzzing sound when connected to pc indicates liquid damage. try clean up & then flash with high version.
Old 02-05-2010, 08:19   #3 (permalink)
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
if u read my problem carefully phone was powering on NORMALLY before only have problem is that it restart after powering on Completely, so i just FORMAT it and then i try Full Factory Settings Format was Ook but Full Factory Default Failed by MX-key i format it in LOW LEVEL.
Take Care
ENJOY
Old 02-08-2010, 16:59   #4 (permalink)
NeeMan's Avatar
Member: 767786
Thanks Meter: 320
you say buzz do you mean it vibrates if so full flash will sort it out
Old 02-10-2010, 08:27   #5 (permalink)
Member: 133436
Sonork: 100.1577364
Thanks Meter: 191
I think there is a flashing BUG in MXkey because my problem solved by Full Flashing Phone with another Box.
Take Care
ENJOY
Old 02-10-2010, 08:33   #6 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
txs for report.
can show us with log info,that easy to fix
about your problem
What is ENO software:
ENO software handles all basic functions inside the device.
It is required to be flashed into the device when Combo Memory is Changed
due to by some wrong operations like; Downgrade Phone wrongly,
Flash with wrong Firmware, Erase Phone with wrong file or
Phone is on White or Blank display.
After flash with ENO Firmware your phone will be normalized and
then you simply flash again with correct firmware package,
select any product code according to your choice and press Flash button.
br,
N95 Blank screen any suggestions??? FU_Too Nokia Base Band 5 ( BB-5 ) 3 07-17-2009 08:19
N95 Blank screen Waterdamaged BillSalih Nokia Hardware & Hardware Repair 1 01-07-2009 01:49
n95 blank screen tornado2008 Nokia Hardware & Hardware Repair 11 10-08-2008 00:30
Page generated in 0.17303 seconds with 9 queries
