Old 02-20-2010, 12:23   #1 (permalink)
MGT SOFTWARE's Avatar
Member: 53263
Sonork: gsm master
Thanks Meter: 326
nokia n96 contact retailer repaire successull,
with same proceedure of repairing contact service now you can re[air contact retailer.
1. i made fully back up, pm, certificate, and rpl,
2. go to pm read all neccessary data, reset pnc, will roose imei, do not worry, imei will turn to 1235,
3. erase flash then full flash , imei will still corrupted,
4. restore imei from back up , repair sd,
5. turn to pm load the pm, activate superdongle, then write pm
6. Reset the phone, check igf all security passed, if passed that is pn your phone is alive
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
APE Data :
SYSTEM ASIC ID: 008815D3 [Nomadik ver: 2.x]
ASIC MODE ID: 00
PUBLIC ID: 00A8D2248C463D3F113E17CBD32275F0C990CD44
ROOT KEY HASH: 0BBC4203E2D3B82504C75CB65E906A35
ROM ID: 137A9A3B33259D2C
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 0AB00119E5DA0158DD453D24B5AEF413ED6D7B0C
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 0020 8804 - 0000 6B21 [ST 58LR128U,128 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
RAP PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
SecondaryBoot: nomadik8815_2nd.fg [BB5] version: 1.43.0 revision: 0.0 size: 0xAD00
Supported APE Ids: 008815B0, 008815C0, 008815C1, 008815D0, 008815D1, 008815D3
FlashID0: 0020 00B1 - 0000 0000 [ST 1Gb NAND,1 Gbits] type: NAND,APE
ALG [35]: N8815 ALG STNFMS
Algorithm: nomadik8815_alg.fg [N8815 ALG STNFMS] version: 1.59.0 revision: 0.0 size: 0x37E78
APE PAPUBKEYS HASH: AD7799ABC45695918C0B8E955FAD5FF12650E6AE
Original Imei: 35486302658136
Original Product code: 0579958
Bluetooth ID: 0025CF373F9E
WLAN ID: 0025CF3829FE
Phone Type: RM-247 (Nokia N96-1)
SW Version: V ICPR72_08w41.2 25-11-08 RM-247 (c) Nokia
Imei plain: 35486302658136-6
Product Code: 0543722
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 354863026581366
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
The Following User Says Thank You to MGT SOFTWARE For This Useful Post:
Old 02-20-2010, 12:29   #2 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
thank you for good test report how about this in 5130c pasl3 data corrupted how to solve
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 15F00102BEED8C56DFC990B032D1E11A20490EFE
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: NOR,RAP
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Original Imei: 35933603859570
Original Product code: 0571957
Bluetooth ID: EC9B5BDAE4F7
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.90 23-09-09 RM-495 (c) Nokia
Imei plain: 35933603859570-3
Product Code: 0578115
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST failed!
SECURITY_TEST failed!
SIMLOCK_DATA corrupted!
Old 02-20-2010, 12:36   #3 (permalink)
Member: 53263
Sonork: gsm master
Thanks Meter: 326
still difficult because you can't by pass simlock, if unlock will be available then you can repair it, no any equipment or programmer repairing this type sl3 with new hash
Old 02-20-2010, 13:11   #4 (permalink)
shaazad's Avatar
Member: 1146078
Thanks Meter: 96
thanks brother keep it up.............
Old 02-20-2010, 13:15   #5 (permalink)
lilong_lee's Avatar
Member: 1070665
Sonork: 100.1636802
Thanks Meter: 572
thank you how about if you have same this 5130c pasl3 good condition and we can back up all section and write is it possible
Old 02-20-2010, 13:28   #6 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
5130 is SL3 phone
NOT SUPPORTED YET at moment
br,
nokia N96 Contact Retailer rafiqcell Nokia Base Band 5 ( BB-5 ) 3 02-21-2010 18:36
N96 Contact retailer After sd repair Not work!! !!!TaaTTalTi!!! Universalbox 6 12-02-2009 12:01
N96 contact retailer & Simlock info invalid repaired w/ UB taking 75 credits reignsmart Universalbox 6 11-22-2009 21:44
pls help nokia n96 contact retail provider aseer1 Nokia Base Band 5 ( BB-5 ) 3 11-15-2009 07:05
nokia 5800 contact retailer i need repair help me GAMMAHIGH Nokia Base Band 5 ( BB-5 ) 16 10-05-2009 07:28
Page generated in 0.20434 seconds with 10 queries
