02-05-2011, 12:00 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: saqi mobiles pirmahal pakistan Age: 36
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | nokia n96 flash problem Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011) Processing MCU file: RM-247_10.065_prd.core.fpsx [BB5,XSR 1.5,BB5,N8815 ALG STNFMS] size: 88.16 MB Supported Ids: 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101031103, 400C192101031103 Supported Ids: 008815C1, 008815D0, 008815D1, 008815D2, 008815D3 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 292B1DA2 Bootstrap failed, please remove USB cable and try again ! |
The Following 2 Users Say Thank You to saqi160 For This Useful Post: |
02-05-2011, 14:28 | #4 (permalink) |
No Life Poster Join Date: Jan 2009 Location: Middle East
Member: 950386 Status: Offline Thanks Meter: 114 | Yes cyclone box also has an issue flashing n96 if you flash it without adjusting the settings. It is only when you tick OLD PROTOCOL LOADERS that you can successfully flash the n96. So my answer to your problem is you might need to tick something on mxkey to flash the n96 successfully or there is something implemented in the old version of mxkey software that works with n96. When you find out the solution post it here for all to see. Kind Regards |
02-20-2011, 11:50 | #7 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Algeria Age: 46
Member: 78657 Status: Offline Thanks Meter: 71 | i have tried with all box and same problem. but problem solved with flashing with cracked phoenix, and select dead usb. |
The Following User Says Thank You to bilm25 For This Useful Post: |
02-26-2011, 09:56 | #10 (permalink) |
Member: 780173 Status: Offline Sonork: 100.1594488 Thanks Meter: 912 | i tri with jaf its show this error JAF version 1.98.62 Detected PKEY: 9000C81D Card life counter: 99.99% P-key nokia module version 01.02 FBUS INTERFACE NOT CONNECTED!!! USB Cable Driver version: 7.1.34.0 Changing mode...Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE APE Variant file: NONE Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-247\ Searching for default location of ini... Checking path: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\ Scanning ini files... Searching for default location of ini... Checking path: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\ FILES SET FOR FLASHING: MCU Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_prd.core.fpsx PPM Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_001.1_prd.language.fpsx CNT Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_098.1_prd.customer.fpsx APE Variant file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_100.1_prd.uda.fpsx Languages in ppm: English,French,German,Italian,Spanish,Portuguese Changing flashing settings... Searching for default location of ini... Checking path: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\ FILES SET FOR FLASHING: MCU Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_prd.core.fpsx PPM Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_001.1_prd.language.fpsx CNT Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_098.1_prd.customer.fpsx APE Variant file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_100.1_prd.uda.fpsx Languages in ppm: English,French,German,Italian,Spanish,Portuguese Changing flashing settings... Searching for default location of ini... Checking path: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\ FILES SET FOR FLASHING: MCU Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_prd.core.fpsx PPM Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_003.1_prd.language.fpsx CNT Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_098.1_prd.customer.fpsx APE Variant file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_100.1_prd.uda.fpsx Languages in ppm: English,Finnish,Swedish,Norwegian,Icelandic,Danish Changing flashing settings... Searching for default location of ini... Checking path: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\ FILES SET FOR FLASHING: MCU Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_prd.core.fpsx PPM Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_002.1_prd.language.fpsx CNT Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_098.1_prd.customer.fpsx APE Variant file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_100.1_prd.uda.fpsx Languages in ppm: English,French,German,Turkish,Dutch,Italian Changing flashing settings... Searching for default location of ini... Checking path: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\ FILES SET FOR FLASHING: MCU Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_prd.core.fpsx PPM Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_006.1_prd.language.fpsx CNT Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_098.1_prd.customer.fpsx APE Variant file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_100.1_prd.uda.fpsx Languages in ppm: English,Czech,Slovakian,German,Polish,Hungarian Changing flashing settings... Searching for default location of ini... Checking path: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\ FILES SET FOR FLASHING: MCU Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_prd.core.fpsx PPM Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_010.1_prd.language.fpsx CNT Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_098.1_prd.customer.fpsx APE Variant file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_100.1_prd.uda.fpsx Languages in ppm: English,Arabic,French Changing flashing settings... Searching for default location of ini... Checking path: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\ FILES SET FOR FLASHING: MCU Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_prd.core.fpsx PPM Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_010.1_prd.language.fpsx CNT Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_098.1_prd.customer.fpsx APE Variant file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_100.1_prd.uda.fpsx Languages in ppm: English,Arabic,French Changing flashing settings... Searching for default location of ini... Checking path: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\ FILES SET FOR FLASHING: MCU Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_prd.core.fpsx PPM Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_001.1_prd.language.fpsx CNT Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_098.1_prd.customer.fpsx APE Variant file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_100.1_prd.uda.fpsx Languages in ppm: English,French,German,Italian,Spanish,Portuguese Changing flashing settings... Searching for default location of ini... Checking path: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\ FILES SET FOR FLASHING: MCU Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_prd.core.fpsx PPM Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_013.1_prd.language.fpsx CNT Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_098.1_prd.customer.fpsx APE Variant file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_100.1_prd.uda.fpsx Changing flashing settings... Searching for default location of ini... Checking path: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\ FILES SET FOR FLASHING: MCU Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_prd.core.fpsx PPM Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_013.1_prd.language.fpsx CNT Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_098.1_prd.customer.fpsx APE Variant file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_100.1_prd.uda.fpsx Changing flashing settings... Searching for default location of ini... Checking path: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\ FILES SET FOR FLASHING: MCU Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_prd.core.fpsx PPM Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_010.1_prd.language.fpsx CNT Flash file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_098.1_prd.customer.fpsx APE Variant file: F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_100.1_prd.uda.fpsx Languages in ppm: English,Arabic,French Backing up CRT... Detected P-KEY: 9000C81D P-key nokia module version 01.02 Init usb communication... Reading IMEI... Failed! Aborting! Failed to backup CRT... Detected P-KEY: 9000C81D P-key nokia module version 01.02 Init usb communication... PRESS POWER ON NOW! Searching for phone...Found Sending APE boot... Loader version: 00.00.00 -> Revision: 0200 Patching APE boot step1... Patching APE boot step2... Patching APE boot step3... Sending ape boot... APE FLASHID: B1002000 Sending APE loader... Waiting for Update Server to boot... Sending CMT boot... Loader version: 08.24.00 -> Revision: 0200 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT FLASHID: 7E2C0100 Sending CMT loader... Reading CMT papub hash... Reading APE papub hash... ape papub hash not present... CMT blocks: 397, APE blocks: 3403 Partition CMT... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_prd.core.fpsx... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_010.1_prd.language.fpsx... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_098.1_prd.customer.fpsx... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_100.1_prd.uda.fpsx... Partition APE... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_prd.core.fpsx... Sending APE partition Data... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_010.1_prd.language.fpsx... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_098.1_prd.customer.fpsx... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_100.1_prd.uda.fpsx... Erase CMT... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_prd.core.fpsx... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_010.1_prd.language.fpsx... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_098.1_prd.customer.fpsx... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_100.1_prd.uda.fpsx... Erase APE... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_prd.core.fpsx... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_010.1_prd.language.fpsx... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_098.1_prd.customer.fpsx... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_100.1_prd.uda.fpsx... Write CMT... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_prd.core.fpsx... Sending CMT HASH for NOLO Sending CMT HASH for KEYS Sending CMT HASH for PRIMAPP Sending CMT HASH for PASUBTOC MATCH cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending... PAPUBKEYS already sent... PAPUBKEYS already sent... Sending CMT HASH for UPDAPP Sending CMT HASH for DSP0 Sending CMT HASH for MCUSW Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_010.1_prd.language.fpsx... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_098.1_prd.customer.fpsx... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_100.1_prd.uda.fpsx... Write APE... Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_prd.core.fpsx... Sending APE HASH for X-LOADER Sending APE HASH for KEYS Sending APE HASH for PRIMAAPP Sending APE HASH for SOS*UPDAPP Sending APE HASH for SOS+XZIP Sending APE HASH for PASUBTOC ape pub keys: 0, rootmatch: 1 ape->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending... Sending APE HASH for SOS+CORE Sending APE HASH for SOS+ROFS1 Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_010.1_prd.language.fpsx... Sending APE HASH for SOS+ROFS2 Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_098.1_prd.customer.fpsx... Sending APE HASH for SOS+ROFS3 Processing F:\softwear\Nkoia\RM-247(n96)\Products\RM-247\RM-247_10.065_100.1_prd.uda.fpsx... Rebooting... Pooling phone... Phone not found... Second try... Phone not found... Done! |
