Old 02-06-2010, 13:32   #1 (permalink)
ABGSM's Avatar
Member: 413268
Thanks Meter: 76
Nokia N96 Rm247 still security test failed after sd repair --Last Update --
Hello to all
I try to repair superdongle in Nokia N96 , super dongle repaired successful but still security test failed ( with last update ) , i try all solution posted in mxkey section but always same error
need help urgently
Old 02-06-2010, 13:49   #2 (permalink)
ABGSM's Avatar
Member: 413268
Thanks Meter: 76
where is product supporter , need help urgently
Old 02-06-2010, 13:55   #3 (permalink)
Member: 783336
Thanks Meter: 21
write PM (1 and 309 ) with super sd auth s4x server
Old 02-06-2010, 13:57   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
kindly post with details info ,
LOG , RPL , PM
that very nice to help.
br,
Old 02-06-2010, 13:59   #5 (permalink)
Member: 733449
Sonork: 100.334100
Thanks Meter: 292
SECURITY_TEST failed solution
Originally Posted by ABGSM View Post
Hello to all
need help urgently
Repair simlock> repair sd>SUPER SD AUTH> just click write (pm for 1 & 309) do not click pm auth. otherwise u see ''Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request''
The Following 4 Users Say Thank You to somratjisan For This Useful Post:
Old 02-06-2010, 14:36   #6 (permalink)
ABGSM's Avatar
Member: 413268
Thanks Meter: 76
not solved
log :
Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V ICPR72_09w13.3 15-09-09 RM-247 (c) Nokia
ApeCoreSw: 30.101
SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13]
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: 4B9B75103E691FF8
Sending SecondaryBoot ...OK
Sending PreLoader ...OK
Sending CustomLoader ...OK
Restarting phone ...
Connecting to server[main.mxkey.biz] ...OK, secure login ...
Authenticating to SUPERDONGLE using security server ...
Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted !
Old 02-06-2010, 14:54   #7 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
how we can help u,if u not help us with details info here ??
br,
Old 02-06-2010, 14:55   #8 (permalink)
Member: 733449
Sonork: 100.334100
Thanks Meter: 292
1.write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309) 2.Repair simlock 3.repair sd 4. click SUPER SD AUTH and load pm file from your pc and tick field 1 & 309 then click write.
Old 02-11-2010, 11:01   #9 (permalink)
Sudan-Mobiles's Avatar
Member: 281857
Thanks Meter: 214
Product: V ICPR72_08w41.2 25-11-08 RM-247 (c) Nokia
ApeCoreSw: 12.043
ERROR: something went wrong while receiving packet from server (c:1)!
i have same prob.
Successfully Repaired 3110c Security Test failed after SD Repair romeoluv56 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 05-14-2012 12:37
3110C security test fail after sd repair now tested ok GSMaxx MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-06-2010 11:19
Security Test Failed after SD Repair adnann5 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 02-04-2010 06:58
Security test failed after sd repair.. Rin2 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 02-03-2010 16:37
FOR those who have SECURITY TEST FAILED after SD repair hasnain MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 02-03-2010 15:13
Page generated in 0.18692 seconds with 9 queries
