07-14-2013, 13:46 | #1 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 579284 Status: Offline Thanks Meter: 6 | nokia n97 mini phone start up fail contact retailer here is mx key log:_____________ Phone type: RM-555 (Nokia N97 mini) SW version: V ICPR72_11w18 09-05-11 RM-555 (c) Nokia ApeCoreSw: v 30.0.004 Imei plain: 35197904812669-2 Product code: 0585427 Battery voltage: 3526 mV, current: 233 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 351979048126692 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
07-15-2013, 07:28 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Use this Method, Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-555.PM file, Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result. BR, ZUBER |
07-15-2013, 09:04 | #3 (permalink) |
Member: 579284 Status: Offline Thanks Meter: 6 | Sir not sucessess MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C086D89B Using device: USB Phonet and HTI, FW ver: 00.50, SN: 010001AC Connection status: EHCI:HUB:HUB:USB 2.00 (High-speed) Driver: nmwcdc, ver: 7.1.32.87 Module ver: 1.0.0.21724(14-05-2013), Library ver: 1.0.0.14397(09-05-2013) Phone type: RM-555 (Nokia N97 Mini) SW version: V ICPR72_11w18 09-05-11 RM-555 (c) Nokia ApeCoreSw: v 30.0.004 Using cached productData. PUBLIC ID: 1380000FEC90005232C809C8BD8DA59C5522CDD3 PRIVATE ID: 27CEDA9EC31E12D6A82F0905AFAD73A953A5BEEF Completed in 0.123 s Updating SUPERDONGLE_KEY ...OK Authenticating to SUPERDONGLE ... ERROR: Could not read E-FUSE from the phone. Please use FBUS connection ! |
07-15-2013, 09:27 | #4 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. You post Edited & not full Logs on your 1st Post, means you using USB, So use FBus Cable & repeat again. BR, ZUBER |
