10-01-2012, 20:22 | #1 (permalink) |
Crazy Poster Join Date: Sep 2009
Member: 1118992 Status: Offline Sonork: 100.1622295 Thanks Meter: 3 | nokia only vibrat after flash..... Using device: HTI, FW ver: 00.50, SN: 00016640 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051105 [RAPIDOYAWE ver: 1.1x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 13E001020CB200524923DD334C60A7D1EE7D8670 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.8.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0231 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.8.0 revision: 2.0 size: 0x8B49D Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 7DC72D3FDC552426A4479BC820097D304CFB6C15 Processing MCU file: RM-625_51.9.002_prd.core.C00 [BB5,XSR 1.6] size: 95.02 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning ...OK Erase size: 158.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: Status reported bad blocks. Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 7DC72D3F [RAP Certificate version] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 4 min 22.532 s Processing PPM file: RM-625_51.9.002_prd.rofs2.V25 [BB5,XSR 1.6] size: 26.50 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 35.50 MB CMT FLASH,MuxOneNAND area [06DE0000-0915FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 1 min 16.047 s Processing PPM file: RM-625_51.9.002_C01_prd.rofs3.fpsx [BB5,XSR 1.6] size: 6.16 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 13 MB CMT FLASH,MuxOneNAND area [09160000-09E5FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS3 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 17.610 s Processing CNT file: RM625_51.1.002_000_001_U002.uda.fpsx [BB5,XSR 1.6] size: 14.88 MB Supported Ids: 4003192101011105, 400C192101011105, 4003192101021105, 400C192101021105, 400C192101031105, 4003192101051105, 400C192101051105 Erase size: 86.12 MB CMT FLASH,MuxOneNAND area [09E60000-0F47FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 44.125 s Total time for flashing process(boot+erase+write) was 6 min 52.203 s |
10-01-2012, 22:16 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | What is your Phone Product Code? I think your Flashed with Mismatch Firmware, If this, then Flash it with same Product of your Phone will solve it. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
