02-07-2011, 09:18 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: pakistan
Member: 373786 Status: Offline Sonork: 100.1601935 Thanks Meter: 130 | nokia phone start up faild contect the retailer SW Version: V 04wk47v43.1 26-05-05 RM-36 (c) Nokia. Imei plain: 35761700456094-2 Product Code: 0524374 ApeCoreSw: V 3.04.37 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 357617004560942 Version: SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF i did super sd auth n write pm many time but stil same problem |
02-07-2011, 09:35 | #2 (permalink) | |
No Life Poster Join Date: May 2005 Age: 40
Member: 146708 Status: Offline Sonork: 100.108221 Thanks Meter: 1,603 | Quote:
first pm auth, then write modified pm... | |
02-07-2011, 09:50 | #5 (permalink) | |
Freak Poster Join Date: May 2009 Location: Dhaka,Bangladesh Age: 33
Member: 1032486 Status: Offline Sonork: 100.1602339 Thanks Meter: 50 | try this Quote:
Bro,,, Press" * 3 and send key" then press power on key u can see formatting on phone screen after the process finish i hope ur phone will be fine.... | |
02-07-2011, 10:05 | #9 (permalink) |
Member: 373786 Status: Offline Sonork: 100.1601935 Thanks Meter: 130 | here is logs but security test failed Imei net: 357617004560942 Version: SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task Provider: Hutchison 3G UK Ltd. , Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2342000000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN, DATA=23420F BLOCK 2: 1=OPEN, DATA=23594F BLOCK 3: 1=OPEN, DATA=23420F BLOCK 4: 1=OPEN, DATA=23594F Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Product: V 04wk47v43.1 26-05-05 RM-36 (c) Nokia. ApeCoreSw: V 3.04.37 Using cached productData[1B80010BD77D46514604796A3442300F408F3313] ... Calculating SIMLOCK using security server ... SERVER->Served by MXKEY - BLADE X at host3, agent version 1.1 revision 0.5 Completed in 3.172 s RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-36_357617004560942_SIM.RPL" Updating SIMLOCK...OK Reading Simlock info ... Imei net: 357617004560942 Version: SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-07-2011, 10:08 | #10 (permalink) | |
Member: 373786 Status: Offline Sonork: 100.1601935 Thanks Meter: 130 | Quote:
SYSTEM ASIC ID: 17100701 [OMAP1710 ver: 1.1] ASIC MODE ID: 00 PUBLIC ID: 03973B691111AA5735A7F8D6C01358B5C3045F12 ROOT KEY HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 CMT Data : SYSTEM ASIC ID: 000000010000022600010006000C192101002100 [RAP3G ver: PA 2.0] EM0 ID: 00000232 EM1 ID: 00000341 PUBLIC ID: 1B80010BD77D46514604796A3442300F408F3313 ASIC MODE ID: 00 ROOT KEY HASH: E9EFF4BFAA5393217CA6B17755FC3E14 ROM ID: F28A211FAC901AEE SecondaryBoot: rap3gv2_2nd.fg [BB5] version: 1.21.0 revision: 0.0 size: 0x3D00 Supported Ids: 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200 FlashID0: 00EC 22FA - 0000 0011 [Samsung K8S6415ETA,64 Mbits] type: NOR,CMT ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D TransmissionMode: DDR&TX2 Begin Certificate Request ... [InternalErrorFault] CERT [0529340] data not available for this phone (case id=0xCE01) if i do recover cert give this error | |
02-07-2011, 10:10 | #11 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | dear brother why ru runing this thread very badly first check this log Phone Type: RM-36 (Nokia 6680) SW Version: V 04wk47v43.1 26-05-05 RM-36 (c) Nokia. Imei plain: 35761700456094-2 Product Code: 0524374 ApeCoreSw: V 3.04.37 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 357617004560942 Version: SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF check colour marked simlock,super dongekey and imei is perfect check last security test,this one is failed means 1 and 309 pm feild is damaged just use sx4 auth then select 6680 pm file ur problem not solved format phone same problem again? run self test option and post there u faced more problems just contact via messanger |
The Following User Says Thank You to SHIJILFONOTLY For This Useful Post: |
02-07-2011, 11:26 | #13 (permalink) |
Member: 373786 Status: Offline Sonork: 100.1601935 Thanks Meter: 130 | Phone Type: RM-36 (Nokia 6680) SW Version: V 04wk47_m_v14.2.1 09-11-06 RM-36 (c) Noki Imei plain: 35761700456094-2 Product Code: 0524374 ApeCoreSw: V 5.04.40 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357617004560942 Version: SIMLOCK SERVER VERSION 56 - Increased PMM size. Fix task Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF my problem is solve specially thanks to SHIJILFONOTLY he done on my pc thanks once again for ur help |
