Old 03-21-2011, 21:51   #1 (permalink)
Member: 1509193
Sonork: 100:1601936
Question Nokia X2-01 After Flash - Only White Screen and Turn Off (ANSWERED)
Please, need advice. I flash Nokia X2-01 (RM-709) with MXKey 3.4 (1.8) but now phone only white screen and turn off. Phone came with blinking Nokia.....
Thanks
Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011)
Nokia USB Flashing Generic detached.
Processing MCU file: rm709__07.11.mcusw
 [BB5,XSR 1.6]  size: 26.59 MB
 Supported Ids: 2200050920030000, 22000509200C0000
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB device ...
Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 241F64A6
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0]
CMT EM0 ID: 00005361
CMT PUBLIC ID: 0000000000964DBC8D66772223B90C11735AABC3
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E
CMT ROM ID: DE56D582BDDE7A3A
Loading CMT secondary boot code
 SecondaryBoot: bcm21351_usb2nd.fg [BB5]  version: 10.10.0 revision: 2.1 size: 0x3940
 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
Secondary boot loaded.
FlashID0: 0020 0030  - 0000 0131 [ST  NAND-1G] type: NOR,CMT
FlashID1: 0010 0011  - 0000 0000 [unused/removed] type: NOR,CMT
FlashID2: 0020 0030  - 0000 0131 [ST  NAND-1G] type: MuxOneNAND,CMT
Loading CMT update server data
 Algorithm: bcm21351_xsr16_usbalg.fg [XSR 1.6]  version: 10.6.1 revision: 2.1 size: 0x9942E
Update server code loaded.
Verifying communication to device OK.
Reading CMT NPC (0x168 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x160 bytes).
Reading CMT HWC (0xD4 bytes).
Rpl(Certificate) backup already exist (C:\mobileEx\3.4\data\backup\BB5_35484204612163_CERT.rpl).
CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09
Erase size: 33.88 MB
Flash programming ...
CMT PAPUBKEYS: 37955B6FC432998EF0DB240E332228384D19ED09 () written.
Programming completed in 5.593 s
Processing PPM file: rm709__07.11.ppm_ma1
 [BB5,XSR 1.6]  size: 5.74 MB
Erase size: 8.00 MB
Programming completed in 1.203 s
Processing CNT file: rm709__07.11.image_ma1_059C343
 [BB5,XSR 1.6]  size: 28.69 MB
Erase size: 75.31 MB
Programming completed in 5.828 s
Total time for flashing process(boot+erase+write) was 30.188 s
Waiting for device boot up ...
Phone not found, retrying ...
Nokia USB Flashing Generic ready.
Old 03-22-2011, 00:32   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
you are using older version of mobileEx.
please download mxkey new version, and do module update.
The Following User Says Thank You to gbluez For This Useful Post:
Old 03-22-2011, 06:00   #3 (permalink)
Registered User
Rizwan001's Avatar
Member: 410659
Thanks Meter: 18
bro
flash latest vertion use this links
Blue-Nokia.com by Obnoxy
The Following User Says Thank You to Rizwan001 For This Useful Post:
Old 03-22-2011, 07:44   #4 (permalink)
Member: 1509193
Sonork: 100:1601936
Done, Thanks.....
Old 08-24-2011, 17:22   #5 (permalink)
Member: 157878
Thanks Meter: 6
x2 white screen
Originally Posted by xwhyz View Post
Done, Thanks.....
how did you do it?
i have a similar problem. flashed wiith cyclone using firmware 7.11 no luck also 8.36 no luck please help somebody!!!!!!!!!!!!
Old 08-25-2011, 04:57   #6 (permalink)
Member: 1540810
Sonork: 100.1627394
Thanks Meter: 161
Nokia X2-01 as the latest flash file go to shrak-mobile to download the latest flash file for the phone the file you are using is old file good luck
Old 11-02-2011, 09:19   #7 (permalink)
RashidElectroni's Avatar
Member: 1520695
Thanks Meter: 18
NOKIA X2-01_V8.65_RM-709 100% TESTED
http://forum.gsmhosting.com/vbb/f299...709-a-1283668/
Old 11-02-2011, 10:23   #8 (permalink)
KKBaruah's Avatar
Member: 1540165
Sonork: 100.1606502
Thanks Meter: 29
Thanks
Erase size: 8.00 MB
Use latest ver of flash file
Phone is downgraded.
Old 11-03-2011, 08:18   #9 (permalink)
Crazy Poster
Member: 82271
Thanks Meter: 4
use latest flash file....v8.70.....
100000000000% work
Old 11-03-2011, 10:10   #10 (permalink)
Registered User
Member: 865598
Sonork: 100.1609492
Thanks Meter: 465
lestest flash file download...
www.shrak-mobile.com
Naeem123e
Old 11-28-2011, 10:02   #11 (permalink)
Member: 317599
Thanks Meter: 32
sir i flash mxk key set problam secrity code but daed
Old 11-28-2011, 10:20   #12 (permalink)
Member: 1407588
Thanks Meter: 27
mxkey flash but set white lcd after flashing
Old 11-28-2011, 11:15   #13 (permalink)
Nadeem Waris's Avatar
Member: 1080718
Sonork: 100.1596539 QQ-2710826805
Thanks Meter: 2,247
Thanks
Erase size: 8.00 MB
flash latest version
X2-01 RM_709 V 8.65 By SAGAR NADEEM.rar
SAGAR NADEEM
Old 11-28-2011, 12:00   #14 (permalink)
Member: 1407588
Thanks Meter: 27
x2-1 i flash 8.70but camra on stend by opretion faild
Old 05-14-2012, 12:14   #15 (permalink)
Member: 1638066
Thanks Meter: 170
X2-01 after flash set white blinking off problem flash with latest ver but same problem. it cames for security code problem.
MXKEY [FT SCR2000 0], SN: C0833895
Using device: USB ROM
Connection status: EHCI:HUB:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012)
Processing MCU file: rm709__08.65.mcusw
[BB5,XSR 1.6] size: 26.60 MB
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 12E37421
CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0]
CMT PUBLIC ID: 0000000000D215586628F8C693DF04687BBD8DED
SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940
eBB5ProtocolType: NEW
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
FUR: Adding Asic CMT as client OK.
Reading CMT R&D (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35194605691738_CE RT.rpl).
Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK
Partitioning....
Partitioning complete
CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
CMT FLASH,MuxOneNAND area [00020000-000203FF]
CMT FLASH,MuxOneNAND area [00060000-012FFFFF]
CMT FLASH,MuxOneNAND area [01300000-01DFFFFF]
CMT FLASH,MuxOneNAND area [02600000-029FFFFF]
Formating partition ...
CMT KEYS block sent
CMT ADA block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: 37955B6F [] sent
CMT UPDAPP block sent
CMT MCUSW block sent
CMT MCUSW1 block sent
CMT GENIO_INIT block sent
CMT ISA+DYNSW block sent
Programming completed in 8.227 s
Processing PPM file: rm709__08.65.ppm_c1
[BB5,XSR 1.6] size: 5.99 MB
Erase size: 8 MB
CMT FLASH,MuxOneNAND area [01E00000-025FFFFF]
Programming completed in 1.977 s
Processing CNT file: rm709__08.65_001.image_c1_tesco_uk_9k5r8
[BB5,XSR 1.6] size: 24.59 MB
CMT FLASH,MuxOneNAND area [02A00000-0753FFFF]
Programming completed in 8.281 s
Total time for flashing process(boot+erase+write) was 52.889 s
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 13:08
Page generated in 0.34970 seconds with 9 queries
