04-16-2013, 13:33 | #1 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Cuba Age: 56
Member: 517318 Status: Offline Thanks Meter: 88 | flash a Nokia E71-2 RM-357 with RM-346 Please I need your help, I accidentally flash a Nokia E71-2 RM-357 with RM-346. make full erase and flash with original firmware RM-346 remains and has no network, which may be the solution. Greetings and thank you very much. mfeliu07 |
04-16-2013, 23:10 | #2 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | If you switch RM, you will need also FULL PM same as the RM you converted. > Load PM, Super SD auth (pop up answer NO), press write. |
The Following User Says Thank You to gbluez For This Useful Post: |
