Nokia x2-05 only vibrate solution??? 1 Attachment(s) i have flash new vr.. .60a but smee only vibrate black screen MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C085F5CD Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000DAA6 Connection status: UHCI:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.46 EBL version: Quantum_Bootloader_10.46_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35740604446381 RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_35740604446381_ back.RPL) Processing file: rm772__08.60a.mcusw Downloading item CODE:rm772__08.60a.mcusw_ebl_psi.fls, num block: 4, size: 25.50 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.328 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.344 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.344 s Erasing area 0x40280000-0x41ABFFFE ...OK Programming completed in 28.859 s Checksum verified (0x053E) Processing file: rm772__08.60a.ppm_d Downloading item CUST:package_d.ppm_ebl_psi.fls, num block: 1, size: 5.34 MB Erasing area 0x41B40000-0x4209527A ...OK Programming completed in 6.437 s Checksum verified (0xE05B) Processing file: rm772__08.60a_001.image_d_tele2_hr_9n8g1 Downloading item CUST:/build/rm772_sw_settings/temp/05 , num block: 1, size: 13.13 MB Erasing area 0x42240000-0x43E1FFFE ...OK Programming completed in 15.500 s Checksum verified (0x5DA2) Total time for flashing process(boot+erase+write) was 7 min 19.484 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Phone not found, retrying ... Warning: Phone did not reboot to normal mode. |
Bro. Post Buscheck Logs, what was status before Flashing? BR, ZUBER |
any body help me plz i have problem in nokia x2-05 no display and show only white light .........................plz thanks in advance bc i am so tired friends |
BTW Run Selftest will get you the answer, If not then Post Buscheck & Selftest Logs. BR, ZUBER |
BR. Arsalan gsm2000. |
Hi guys i have the very same pro blem anybody can help me plzzz |
hi guys i have same prob: help |
display problame ..................... |
You Mean White Display? BR. Arsalan gsm2000. |
plz if anybody have a solution for this phone x2-05 plz let us know |
