Old 08-08-2012, 15:45   #1 (permalink)
MATELECOM1's Avatar
Member: 1707492
Thanks Meter: 562
Post Nokia x2-05 only vibrate solution???
i have flash new vr.. .60a but smee only vibrate black screen
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C085F5CD
Using device: USB ROM and HTI, FW ver: 00.50, SN: 0000DAA6
Connection status: UHCI:HUB::USB 1.10 (Full-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
Device synchronized.
CPU: XGOLD 213
Using embedded SBL from MCU.
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.46
EBL version: Quantum_Bootloader_10.46_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
CFI information:
Flash settings: 0/1024, size: 0x04000000
1 Block regions:
512 x 0x00020000 = 0x04000000
EBL ready !
Original IMEI: 35740604446381
RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_35740604446381_ back.RPL)
Processing file: rm772__08.60a.mcusw
Downloading item CODE:rm772__08.60a.mcusw_ebl_psi.fls, num block: 4, size: 25.50 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.328 s
Erasing area 0x40040000-0x4005FFFE ...OK
Programming completed in 0.344 s
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.344 s
Erasing area 0x40280000-0x41ABFFFE ...OK
Programming completed in 28.859 s
Checksum verified (0x053E)
Processing file: rm772__08.60a.ppm_d
Downloading item CUSTackage_d.ppm_ebl_psi.fls, num block: 1, size: 5.34 MB
Erasing area 0x41B40000-0x4209527A ...OK
Programming completed in 6.437 s
Checksum verified (0xE05B)
Processing file: rm772__08.60a_001.image_d_tele2_hr_9n8g1
Downloading item CUST:/build/rm772_sw_settings/temp/05 , num block: 1, size: 13.13 MB
Erasing area 0x42240000-0x43E1FFFE ...OK
Programming completed in 15.500 s
Checksum verified (0x5DA2)
Total time for flashing process(boot+erase+write) was 7 min 19.484 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...
Waiting for device boot up ...
Phone not found, retrying ...
Warning: Phone did not reboot to normal mode.
Old 08-08-2012, 17:12   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,260
Bro. Post Buscheck Logs, what was status before Flashing?
BR,
ZUBER
Old 10-25-2012, 18:36   #3 (permalink)
Member: 1677616
Thanks Meter: 5
any body help me plz i have problem in nokia x2-05 no display and show only white light .........................plz thanks in advance bc i am so tired friends
The Following User Says Thank You to sonofone143 For This Useful Post:
Old 10-25-2012, 19:20   #4 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,260
Don't ask for help, will not get Feedback without Logs.
BTW Run Selftest will get you the answer,
If not then Post Buscheck & Selftest Logs.
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 10-25-2012, 20:55   #5 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,130
CPU: XGOLD 213
Sending EBL ...OK
Boot mode: 0xCC
CFI information:
1 Block regions:
EBL ready !
Before Phone condition & Flash with Same product code I hope Positive Result.
BR.
Arsalan gsm2000.
The Following User Says Thank You to .::MASTER ALONE::. For This Useful Post:
Old 02-10-2013, 22:31   #6 (permalink)
Member: 1777688
Hi guys i have the very same pro
blem anybody can help me plzzz
Old 04-10-2013, 17:09   #7 (permalink)
Member: 1764155
Sonork: 2500
Thanks Meter: 3
hi guys i have same prob: help
The Following User Says Thank You to emmtech For This Useful Post:
Old 04-10-2013, 17:32   #8 (permalink)
Member: 1306485
Thanks Meter: 9
display problame .....................
Old 04-10-2013, 21:13   #9 (permalink)
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,130
What's Your Problem Clear Post 1st.
You Mean White Display?
BR.
Arsalan gsm2000.
Old 04-16-2013, 17:52   #10 (permalink)
Member: 956783
plz if anybody have a solution for this phone x2-05 plz let us know
Old 04-17-2013, 00:12   #11 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,058
start to check phone hardware, if after flashing over and over again got no result.
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 10-14-2017 20:29
Page generated in 0.43457 seconds with 9 queries
