11-08-2011, 08:26 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: India
Member: 545012 Status: Offline Thanks Meter: 27 | nokia x2 flashing problem why? Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: E712B45 FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: E9700989029D9E899915F781B1582048E042A738 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase skipped. Flash programming ... CMT KEYS block sent CMT PAPUBKEYS: E9700989 [RAP Certificate v1 237] sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT ADA block sent CMT RAP3NAND block sent CMT ISA+DYNSW block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT UPDAPP block sent Programming completed in 19.735 s Processing PPM file: rm618__08.25.ppm_mh [BB5,XSR 1.6] size: 6.37 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase skipped. Flash programming ... Error while programming [00] at 0x02232000, Result: 0000 |
12-13-2011, 13:03 | #2 (permalink) |
No Life Poster Join Date: Apr 2010 Location: pakistan Age: 48
Member: 1275418 Status: Offline Thanks Meter: 432 | i also this mater MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C08451F2 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: nmwcdnsuc, ver: 7.1.32.70 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Processing MCU file: rm618__08.25.mcusw [BB5,XSR 1.6] size: 26.97 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1B57BC1 CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 0000000000381EAE7BD0F58990C751F430710841 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1B57BC1 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x0 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x0 bytes). Reading CMT HWC (0x0 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Invalid Certificate Data, backup will not be created. Error saving backup ! CMT PAPUBKEYS is blank/erased. Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 32.88 MB CMT FLASH,MuxOneNAND area [00000000-0001FFFF] CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-011BFFFF] CMT FLASH,MuxOneNAND area [011C0000-01CFFFFF] CMT FLASH,MuxOneNAND area [02500000-028FFFFF] Formating partition ... Flash programming ... WriteDevice failed: Overlapped I/O operation is in progress Error while programming [00] at 0x00020000, Result: 0000 Task failed at (0800001C)!!! Last RX buffer: 80 10 6F 00 |
