04-11-2011, 12:43 | #1 (permalink) |
No Life Poster Join Date: Apr 2010
Member: 1277468 Status: Offline Sonork: 100.1603661 Thanks Meter: 701 | nokia x2 security code...help (ANSWERED) i try to usb cable with mx key but show this error Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2D2E022C CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 000000000010E015ACC3E19E6F7BD94A9617DEDD CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Secondary boot loaded. FlashID0: 0020 0030 - 0000 0131 [ST NAND-1G] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0030 - 0000 0131 [ST NAND-1G] type: MuxOneNAND,CMT Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2D2E022C Open device failed: The system cannot open the file WriteDevice failed: Device Not Opened WriteDevice failed: Device Not Opened Waiting for device boot up ... Phone not found, retrying ... Phone not responding ! pl z help me any body br:. shabir97 |
04-11-2011, 12:52 | #3 (permalink) |
Registered User Join Date: Apr 2008 Location: sadiqsajan
Member: 759011 Status: Offline Sonork: 164643 (server.sonork.com Thanks Meter: 152 | x2 security code wrote x2 i remove the security code by using ufc v1 cable 3 resistor 7.1 here is pinout for x2 FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 3.532 s |
04-11-2011, 14:45 | #6 (permalink) |
Member: 1277468 Status: Offline Sonork: 100.1603661 Thanks Meter: 701 | my problum is solved thanks to all for help me Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2D2E022C CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 000000000010E015ACC3E19E6F7BD94A9617DEDD CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 10.10.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Secondary boot loaded. FlashID0: 0020 0030 - 0000 0131 [ST NAND-1G] type: NOR,CMT FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,CMT FlashID2: 0020 0030 - 0000 0131 [ST NAND-1G] type: MuxOneNAND,CMT Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 10.6.1 revision: 2.1 size: 0x9942E Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Device found: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2D2E022C Open device failed: The system cannot open the file WriteDevice failed: Device Not Opened WriteDevice failed: Device Not Opened Waiting for device boot up ... Device found: nmwcdc\Nokia X2-00 USB Phonet, PORT_ID: 6D2E223 Verifying communication to device OK. Phone Type: RM-618 (Nokia X2-00) SW Version: V 04.80 03-08-10 RM-618 (c) Nokia Imei plain: 35434604728124-0 Product Code: 0595304 Battery voltage: 32768 mV Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 35434604728????? Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 1.172 s thanks to mxkey team br:. shabir97 |
04-28-2011, 21:49 | #9 (permalink) | |
No Life Poster Join Date: Aug 2005 Location: Tinzawatine Age: 44
Member: 175273 Status: Offline Thanks Meter: 68 | Quote:
09-16-2012, 17:32 | #10 (permalink) |
Crazy Poster Join Date: Jul 2009 Location: bangladesh naogaon Age: 43
Member: 1071534 Status: Offline Thanks Meter: 9 | nokia x2-oo security code remove 1000% solve with mx-key try step by step 1000% your problem will be solve 1st= use mx_box 2nd=select usb mode 3rd= full flash latast version = flash ok then hilight survice option. 4th= full flash ok = clic survice option 5th= clic reset all all reset ok your problem solve dont forgate thanks. |
11-16-2012, 20:59 | #12 (permalink) | |
Junior Member Join Date: Nov 2012
Member: 1840412 Status: Offline Sonork: sam4u_waiting4u Thanks Meter: 0 | how to use Quote:
dear bro. hw to use this ? when i switch on my phone its ask for security code , what i do ? | |
11-16-2012, 21:28 | #13 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Use Nokia USB Rom as Interface, Click Buscheck & Connect USB Cable to Phone, Short Click to Power ON Switch, After Buscheck Info, Phone will appear in Test Mode, Service Tab will be Highlighted thereafter, Now you can Read User Code or Reset All, If not works, then very simple, Click Flash & Reset All. BR, ZUBER | |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
11-17-2012, 20:49 | #15 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | No need to Connect Switched ON Phone, Use Nokia USB Rom as Interface, Click Buscheck & Connect Phone to USB & Short Click to Power ON Switch, Will Scan Phone & will appear to Test Mode Automatically. BR, ZUBER |
