12-15-2012, 14:25 | #1 (permalink) |
No Life Poster Join Date: Dec 2012 Location: Anees Mobile JAND ATTOCK
Member: 1851480 Status: Offline Sonork: 100.1660354 Thanks Meter: 142 | nokia x2_02 faild on ufs box after faild on A.T.F ...BUT mxkey do thr job well Using device: USB ROM Connection status: UHCI:HUB:HUB::USB 1.10 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012) Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Device synchronized. CPU: XGOLD 213 Using embedded SBL from MCU. Sending EBL Loader...OK Sending EBL ...OK Getting EBL Version ... Boot mode: 0xCC EBL version major/minor: 10.46 EBL version: Quantum_Bootloader_10.46_M1S1 Protocol version suggested by phone: 3 Set baud rate to: 6.50 Mbit/s Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits] CFI information: Flash settings: 0/1024, size: 0x04000000 1 Block regions: 512 x 0x00020000 = 0x04000000 EBL ready ! Original IMEI: 35286905992844 IMEI_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35286905992844_ back.RPL" Processing file: rm694__11.84.mcusw Downloading item CODE:rm694__11.84.mcusw_ebl_psi.fls, num block: 4, size: 26.25 MB Erasing area 0x40000000-0x4001FFFE ...OK Programming completed in 0.391 s Erasing area 0x40040000-0x4005FFFE ...OK Programming completed in 0.547 s Erasing area 0x40060000-0x4015FFFE ...OK Programming completed in 1.625 s Erasing area 0x40280000-0x41B7FFFE ...OK Programming completed in 33.969 s Checksum verified (0xB615) Processing file: rm694__11.84.ppm_m_a Downloading item CUSTackage_m_a.ppm_ebl_psi.fls, num block: 1, size: 4.25 MB Erasing area 0x41C00000-0x4204033E ...OK Programming completed in 5.891 s Checksum verified (0x40FC) Processing file: rm694__11.84.image_m_a_059D1B3 Downloading item CUSTackage_m_a_059D1B3.image.fls, num block: 1, size: 13.75 MB Erasing area 0x42300000-0x43E1FFFE ...OK Programming completed in 21.344 s Checksum verified (0x1F63) Total time for flashing process(boot+erase+write) was 8 min 44.922 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 6193786 Verifying communication to device OK. Phone type: RM-694 (X2-02) SW version: V 11.84 13-09-12 RM-694 (c) Nokia Imei plain: 35286905992844-2 Product code: 059P1W7 Battery voltage: 3811 mV, current: 147 mA Cellular system: GSM ASIC ID: 0x0000, type: 11 Ppm Id: M_A Language Pack: - not available. Master code: 6366251562 Camera config: 115B6002004020, ver: Imei net: 35286905992844 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 800000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Market items is empty, please select the correct products path ! thanks by |
The Following User Says Thank You to Ali idrees For This Useful Post: |
