02-03-2010, 11:11 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: VIZAG,A.P,๑۩INDIA&
Member: 733702 Status: Offline Sonork: 100.1579452 Thanks Meter: 580 | Nokia x3 flashing problem GIVEN FOR ONLY UPGRADING. WHEN I AM CONNECTING THIS FOR FLASHING I GET THIS ERROR. NOW HOW CAN I UPGRADE THIS PHONE ????? Library version: 1.0.0.11893, Date: 26-01-2010 Processing file: rm540__03.60.mcusw as MCU [BB5,XSR 1.6] size: 25.93 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Phone must be switched off, put USB cable to the phone. Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 32D80BB2 RAP SYSTEM ASIC ID: 000000010000022600000001020C192102034100 RAP EM0 ID: 00001040 RAP EM1 ID: 00001030 RAP PUBLIC ID: 20200214A4380E4952BF83C7B25B1CBC0CF323B6 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D RAP ROM ID: 67E82268F29CEA60 [ADL] Flashing CMT Update Server Data, ULO: 0x21FB bytes Flashing terminated with error(s) in 12.672 s RX Buffer: 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 000000000000000000000000000000000000000000 |
The Following User Says Thank You to laxman kumar For This Useful Post: |
02-03-2010, 12:16 | #2 (permalink) |
No Life Poster Join Date: Oct 2005 Location: lahore
Member: 188574 Status: Offline Sonork: 100.1590742 Thanks Meter: 751 | try with usb cable. i hope you can flash with that easily. Br Naveed Yousaf |
The Following User Says Thank You to NAVEED74 For This Useful Post: |
02-03-2010, 12:26 | #3 (permalink) |
Member: 733702 Status: Offline Sonork: 100.1579452 Thanks Meter: 580 | with fbus cable only info ok Phone Type: RM-540 (Nokia X3-00) SW Version: V 03.60 21-10-09 RM-540 (c) Nokia Imei plain: 359367030*****-* Product Code: 0583926 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed TimeStamp: 2009-11-19T12:04:50Z SW Version: 03.60 Variant Version: 008 ProductProfile: RM540_0583926_03.60_008.spr Simlock: 0583926_simlock.bin Imei net: 359367030****** Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF flashing problem Version from phone: 03.60 Version from file: 03.60 Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11893, Date: 26-01-2010 Boot error: 03 00 72 00 UPP not responding ! - Repeat the procedure. Sometimes it is a matter of temporary communication problem or similar. - Check that all used cable are solid without any visible damage and have good contact. If possible, try with other cables. - On rare occasions phone might be damaged or dead. So, if possible, try with another phone. Read Certificate failed. NPC_DATA is empty. SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA saved OK pls help me.............. |
02-04-2010, 12:35 | #6 (permalink) |
Freak Poster Join Date: Feb 2005 Age: 52
Member: 114143 Status: Offline Thanks Meter: 55 | X3 flash success in Phoenix Flashing started Creating product data items list Product data items list created Backup not required Flashing phone Initializing Asic CMT: Verifying communication to device... Getting product info... Scanning image files... Unable to open and parse CmtUlo file C:\Program Files\Common Files\Nokia\Tss\Flash\MICROv10_alg2nd.fg Loading secondary boot code: 15296 bytes Secondary boot loaded Loading update server code: 516338 bytes Update server loaded Partitioning.... Partitioning complete Erasing.... Erasing complete Asic CMT: Start programming 47382 KB... Asic CMT: Programming data sent: 0% Asic CMT: Programming data sent: 10% Asic CMT: Programming data sent: 20% Asic CMT: Programming data sent: 30% Asic CMT: Programming data sent: 41% Asic CMT: Programming data sent: 50% Asic CMT: Programming data sent: 60% Asic CMT: Programming data sent: 70% Asic CMT: Programming data sent: 80% Asic CMT: Programming data sent: 90% Programming complete WARNING: Asic CMT: NAND status reported bad blocks Asic CMT: programming succeeded Asic CMT: Verifying communication to device... Waiting for communication response: 25 Waiting for communication response: 24 Waiting for communication response: 23 Waiting for communication response: 22 Waiting for communication response: 21 Waiting for communication response: 20 Waiting for communication response: 19 Waiting for communication response: 18 USB Flashing succeeded. Phone flashing completed. Waiting for phone to boot up Bootup successful Verifying communication to product (before flash finalizing) Communication verified Doing factorysets Factorysets complete Reading Dynamic Camera Configuration ID 1 Updating configuration of camera with ID 1 Loading default data to phone Loading default data to phone Getting Data Package Reading product state Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ProductProfile, version: 1.1 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item pre-delay data item pre-delay data item pre-delay Sub-procedure completed: Succeeded., result code: 0 Starting to backup/restore data item: ISSVariantActivator, version: 1.0 Data Item backup/restore completed: Succeeded., result code: 0 Starting backup/restore sub-procedure: data item post-delay data item post-delay data item post-delay Sub-procedure completed: Succeeded., result code: 0 Backup/restore result: 0 out of 2 items were not backed up Default data loading complete Stopping all operations, returning phone to default mode All operations completed Product flashing succeeded. |
The Following User Says Thank You to mohangbvk For This Useful Post: |
02-04-2010, 12:53 | #7 (permalink) |
No Life Poster Join Date: Aug 2005 Location: MY
Member: 172261 Status: Offline Thanks Meter: 364 | i've same problem when flash x3-00 via usb with mxkey, but it done in few mins with phoenix |
The Following User Says Thank You to andre128 For This Useful Post: |
02-04-2010, 14:38 | #8 (permalink) | |
Member: 733702 Status: Offline Sonork: 100.1579452 Thanks Meter: 580 | Mx key cannot flash this phone ?????? mx key cannot flash this phone ?????? mx key this is big thing for u that somebody is posted in your section that he flashed x3 by usb cable and he done it successfully. Sir pls i want answer that why mx key could not flash this handset ??? Quote:
02-25-2010, 13:52 | #11 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: punjab(india) Age: 45
Member: 467045 Status: Offline Sonork: 100.1603919 Thanks Meter: 1,705 | Quote:
The Following User Says Thank You to JINDALGSM™ For This Useful Post: |
02-25-2010, 13:59 | #12 (permalink) |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | unistall nokia connectivity cable driver from control panel restart PC, and install from MXKEY directory Code: C:\mobileEx\3.3\data\drivers\nokia Why we need NOKIA USB ROM as interface? One of the reason.... br, |
The Following 2 Users Say Thank You to Andra For This Useful Post: |
09-16-2010, 18:37 | #13 (permalink) |
Freak Poster Join Date: Sep 2008
Member: 860369 Status: Offline Thanks Meter: 9 | Nokia x_3 usb flashing by mx key. STEP BY STEP... FIRST: INSTALL NOKIA FLASHING USB DRIVER...OR .. INSTAL PC SUITE NEW VERSION.. SECOND: CONECT MX_KEY AS A NOKIA USB INTERFACE THIRD; SELECT GERATION JUST AS BB5 AND SELECT MODEL AND SELECT FLASH FILES. FOURTH: CLICK FLASH BUTTON AND POWR ON THE MOBILE..... NOW SEE BELOW LOGS.. AND ENJOY.... Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Processing file: rm540__08.50.mcusw as MCU [BB5,XSR 1.6] size: 26.10 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Polling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 172924E RAP SYSTEM ASIC ID: 000000010000022600000001020C192102034100 [RAPS2 ver: PA 4.x] RAP EM0 ID: 00001040 RAP EM1 ID: 00001030 RAP PUBLIC ID: 1400010D177B0E496174AFBF380C3DE5669D5061 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D RAP ROM ID: 67E82268F29CEA60 [ADL] Loading CMT secondary boot code SecondaryBoot: rap3gv40_2nd.fg [BB5] version: 9.48.0 revision: 2.1 size: 0x3BC0 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,RAP FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP FlashID2: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,RAP [ADL] Loading CMT update server data Algorithm: rap3gv40_xsr17_alg.fg [XSR 1.6] version: 9.48.0 revision: 2.1 size: 0x7E232 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Update server code loaded. [ADL] Polling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 172924E [ADL] Verifying communication to device OK. RAP PAPUBKEYS HASH: CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 37.69 MB Flash programming ... CMT PAPUBKEYS: CEFA9C4100686F9FC9B1B3778774A19500626C6F (RAP Certificate 193 v.1) written. Programming completed in 36.672 s Processing file: rm540__08.50.ppm_d as PPM [BB5,XSR 1.6] size: 6.53 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Erase size: 8.87 MB Flash programming ... Programming completed in 9.562 s Processing file: rm540__08.50.image_d_0580759_004 as CNT [BB5,XSR 1.6] size: 14.99 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Erase size: 75.06 MB Flash programming ... Programming completed in 21.110 s [ADL] Restarting phone ... [ADL] Polling for ADL device [ADL] Device found: nmwcdc\Nokia X3 USB Generic, ID: 3B9A072B [ADL] Verifying communication to device OK. Flashing completed in 2 min 39.719 s Phone Type: RM-540 (Nokia X3-00) SW Version: V 08.50 19-07-10 RM-540 (c) Nokia Imei plain: 35269104939682-3 Product Code: 0583978 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352691049396823 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 2 min 44.328 s FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 1.938 s Nokia USB ROM detached. MX_ KEY IS THE BEST FOR USB FLASHING.... |
The Following User Says Thank You to imran_alialmani For This Useful Post: |
nokia X3 flash files needed | SHAHID99 | Nokia Base Band 5 ( BB-5 ) | 16 | 09-28-2012 15:20 |
Nokia X3 Flashing | gerdzio | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 03-19-2010 19:50 |
:::: Nokia X3 Boot Problem After Flash Solved :::: | siyamack | Nokia Base Band 5 ( BB-5 ) | 5 | 02-18-2010 16:18 |
nokia x3 flash problem | ahmad5175 | Nokia Base Band 5 ( BB-5 ) | 8 | 01-25-2010 18:09 |
nokia X3 flashing problem | suffa | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 12-10-2009 19:19 |
