03-31-2010, 14:31 | #1 (permalink) |
Freak Poster Join Date: Aug 2008
Member: 837069 Status: Offline Thanks Meter: 37 | nokia x3 problem flashing whit usb (Solved) Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010) Processing file: rm540__04.11.mcusw as MCU [BB5,XSR 1.6] size: 25.92 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Phone must be switched off, put USB cable to the phone. Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2BDB73D RAP SYSTEM ASIC ID: 000000010000022600000001020C192102034100 RAP EM0 ID: 00001040 RAP EM1 ID: 00001030 RAP PUBLIC ID: 27700208A5380E49FCF38A6BC82C42A3838D7B6E RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D RAP ROM ID: 67E82268F29CEA60 [ADL] Flashing CMT Update Server Data, ULO: 0x21FB bytes Flashing terminated with error(s) in 2.921 s plez help |
03-31-2010, 14:51 | #6 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | Quote:
try this method . or connect charger, | |
04-01-2010, 09:34 | #7 (permalink) |
Member: 837069 Status: Offline Thanks Meter: 37 | this problem is solved flashing x3 sucssufuly "Library version: 1.0.0.7687(12-02-2010), 1.0.0.12095(13-02-2010)" |
The Following User Says Thank You to khalid0909 For This Useful Post: |
04-01-2010, 11:10 | #8 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: AD
Member: 976728 Status: Offline Sonork: 1589709 Thanks Meter: 4,775 | last version in server Quote:
br, | |
10-09-2010, 00:35 | #9 (permalink) |
Junior Member Join Date: Aug 2010
Member: 1378614 Status: Offline Thanks Meter: 0 | plz helpme out sir from this problem i got this massage when i flashin nokia x3 from umskey(usbrom) Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010) Processing file: rm540__04.11.mcusw as MCU [BB5,XSR 1.6] size: 25.92 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Make sure USB cable, Battery and charger are removed from device. Insert USB cable,Battery back to device. Insert Charger or Press phone's power button Waiting for USB device ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2772F953 RAP SYSTEM ASIC ID: 000000010000022600000001020C192102034100 [RAPS2 ver: PA 4.x] RAP EM0 ID: 00001040 RAP EM1 ID: 00001030 RAP PUBLIC ID: 1DA0000992670E49DA37CDA03073B639040881F6 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D RAP ROM ID: 67E82268F29CEA60 [ADL] Loading CMT secondary boot code SecondaryBoot: rap3gv40_2nd.fg [BB5] version: 9.48.0 revision: 2.1 size: 0x3BC0 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,RAP FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP FlashID2: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,RAP [ADL] Loading CMT update server data Algorithm: rap3gv40_xsr17_alg.fg [XSR 1.6] version: 9.48.0 revision: 2.1 size: 0x7E232 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Update server code loaded. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2772F953 [ADL] Verifying communication to device OK. RAP PAPUBKEYS HASH: CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 37.69 MB Flash programming ... CMT PAPUBKEYS: CEFA9C4100686F9FC9B1B3778774A19500626C6F (RAP Certificate 193 v.1) written. Programming completed in 35.390 s Processing file: rm540__04.11.ppm_i as PPM [BB5,XSR 1.6] size: 6.53 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Erase size: 8.87 MB Flash programming ... Programming completed in 8.828 s Processing file: rm540__04.11.image_i_0582085_001 as CNT [BB5,XSR 1.6] size: 13.30 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Erase size: 75.06 MB Flash programming ... Programming completed in 18.328 s [ADL] Restarting phone ... [ADL] Pooling for ADL device [ADL] Timeout, no usb device found. [ADL] Phone flashing completed, but failed to verify communication to product! [ADL] Retrying in finalize phase... [ADL] Pooling for ADL device [ADL] Timeout, no usb device found. Flashing terminated with error(s) in 4 min 43.313 s RX Buffer: 800F7000 thanks |
10-09-2010, 05:34 | #10 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | USB_FLASHING_IN_JUST_2 min 0.938 s USB_FLASHING: ---------------- Library version: 1.0.0.8955(29-09-2010), 1.0.0.14639(29-09-2010) Due to USB protocol limitation, certificate backup will be skipped. NPC_DATA is empty. SIMLOCK_DATA saved OK SIMLOCK_KEY_DATA saved OK WMDRM_PD_DATA saved OK RF_DATA saved OK WARRANTY_DATA saved OK PROD_DATA saved OK BT_DATA saved OK LOCK_DATA saved OK LOCK120_DATA saved OK BB_DATA saved OK RPL saved to "C:\mobileEx\3.4\data\backup\BB5_35797703360864_BA CK.rpl" Processing file: rm540__04.11.mcusw as MCU [BB5,XSR 1.6] size: 25.92 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Battery voltage: 3781 mV Phone type: RM-540 Product code: 0584364 SW version: V 04.11 09-12-09 RM-540 (c) Nokia LanguagePkg version: V 04.11 09-12-09 RM-540 (c) Nokia MEC Version from phone: 04.11 Version from file: 04.11 [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2BB3DE96 RAP SYSTEM ASIC ID: 000000010000022600000001020C192102034100 [RAPS2 ver: PA 4.x] RAP EM0 ID: 00001040 RAP EM1 ID: 00001030 RAP PUBLIC ID: 3540011603540E499D446AEFADB6B5F7553D9345 RAP ASIC MODE ID: 00 RAP ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D RAP ROM ID: 67E82268F29CEA60 [ADL] Loading CMT secondary boot code SecondaryBoot: rap3gv40_2nd.fg [BB5] version: 9.48.0 revision: 2.1 size: 0x3BC0 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Secondary boot loaded. FlashID0: 0000 0000 - 0000 0000 [unused/removed] type: NOR,RAP FlashID1: 0000 0001 - 0000 0000 [unused/removed] type: NOR,RAP FlashID2: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: MuxOneNAND,RAP [ADL] Loading CMT update server data Algorithm: rap3gv40_xsr17_alg.fg [XSR 1.6] version: 9.48.0 revision: 2.1 size: 0x7E232 Supported RAP Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 [ADL] Update server code loaded. [ADL] Pooling for ADL device [ADL] Device found: nmwcdnsuc\Nokia USB Flashing Generic, ID: 2BB3DE96 [ADL] Verifying communication to device OK. RAP PAPUBKEYS HASH: CEFA9C410038BD7D17C4C6F107F1EC02C98CA69E Storing certificate [NPC, CCC, HWC, R&D] OK. Partitioning.... Partitioning complete Erase size: 37.69 MB Flash programming ... CMT PAPUBKEYS: CEFA9C4100686F9FC9B1B3778774A19500626C6F (RAP Certificate 193 v.1) written. Programming completed in 48.203 s Processing file: rm540__04.11.ppm_meaa as PPM [BB5,XSR 1.6] size: 6.14 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Erase size: 8.87 MB Flash programming ... Programming completed in 11.703 s Processing file: rm540__04.11.image_meaa_0584294_001 as CNT [BB5,XSR 1.6] size: 12.26 MB Supported RAP Ids: 020C192102034000, 0203192102034000, 020C192102034100, 0203192102034100, 0203192102054100, 020C192102054100 Erase size: 75.06 MB Flash programming ... Programming completed in 23.016 s [ADL] Restarting phone ... [ADL] Pooling for ADL device [ADL] Device found: nmwcdc\Nokia X3 USB Generic, ID: 1E265F72 [ADL] Verifying communication to device OK. Flashing completed in 1 min 57.610 s Phone Type: RM-540 (Nokia X3-00) SW Version: V 04.11 09-12-09 RM-540 (c) Nokia Imei plain: 35797703360864-5 Product Code: 0584364 Language Pack: - not available. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357977033608645 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF Total time to process is 2 min 0.938 s BR |
The Following User Says Thank You to mobile_hotman For This Useful Post: |
