Old 10-03-2012, 13:34   #1 (permalink)
Member: 1299153
Sonork: 100.1645596
Thanks Meter: 18
nokia X6 any body plzzz help
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 09C00111E6208E52F7E37AF86496EBE467A115E9
ASIC MODE ID: 00
ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.8.0 revision: 2.0 size: 0x3B80
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
TransmissionMode: DDR&TX2
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.8.0 revision: 2.0 size: 0x8B49D
FUR: Adding Asic CMT as client OK
CMT PAPUBKEYS HASH: E00DA77BF32983F864BC7671FE7709A29D8E2C08
Processing MCU file: RM-559_40.0.002_prd.core.C00
[BB5,XSR 1.6] size: 112.91 MB
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning ...OK
Erase size: 182.94 MB
CMT FLASH,MuxOneNAND area [00040000-00082FFF]
CMT FLASH,MuxOneNAND area [00083400-003FFFFF]
CMT FLASH,MuxOneNAND area [00400000-007FFFFF]
CMT FLASH,MuxOneNAND area [00800000-00D5FFFF]
CMT FLASH,MuxOneNAND area [00D60000-0B71FFFF]
Formating partition ...
Prog.status for Asic CMT ...
NAND: Status reported bad blocks.
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: E00DA77B [RAP Certificate 191 v.1] sent
CMT SOS*UPDAPP block sent
CMT SOS*ENO block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
NAND: OK
Programming completed in 5 min 4.328 s
Processing PPM file: RM-559_40.0.002_prd.rofs2.V12
[BB5,XSR 1.6] size: 20.28 MB
Erase size: 41.87 MB
CMT FLASH,MuxOneNAND area [07920000-0A2FFFFF]
NAND: OK
CMT SOS+ROFS2 block sent
NAND: OK
Programming completed in 56.406 s
Processing PPM file: RM-559_40.0.002_C03_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 5.31 MB
Erase size: 20.12 MB
CMT FLASH,MuxOneNAND area [0A300000-0B71FFFF]
NAND: OK
CMT SOS+ROFS3 block sent
NAND: OK
Programming completed in 14.937 s
Processing CNT file: RM-559_32.0.002_001_000_U001.uda.fpsx
[BB5,XSR 1.6] size: 7.81 MB
Erase size: 312.37 MB
CMT FLASH,MuxOneNAND area [0B720000-1EF7FFFF]
NAND: OK
NAND: OK
Programming completed in 25.344 s
Total time for flashing process(boot+erase+write) was 6 min 53.672 s
plzzzz help any bro
Old 10-03-2012, 14:23   #2 (permalink)
hand2hand's Avatar
Member: 1476841
Thanks Meter: 201
describe your problem 1st and which
Old 10-03-2012, 19:02   #3 (permalink)
.::MASTER ALONE::.'s Avatar
Member: 1587480
Sonork: 100.1618317
Thanks Meter: 2,165
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Partitioning ...OK
CMT ADA block sent
CMT KEYS block sent
NAND: OK
NAND: OK
NAND: OK
NAND: OK
NAND: OK
NAND: OK
NAND: OK
plzzzz help any bro
flash with USB method dear use highest version.
BR.
Arsalan gsm2000.
Page generated in 0.16225 seconds with 8 queries
